LeCroy LC Series Oscilloscope LCD Conversion
  • japlytic
    • Oct 2005
    • 2086
    Over a year ago, I decided to convert my LeCroy LC Series oscilloscope to an LCD display.
    The fit of an 8.4 inch LCD (Mitsubishi AA084VC03 to be exact) in the bezel was just about perfect, and I crafted the brackets to fit the LCD in the oscilloscope from scrap sheet metal, which was then covered in electrical tape.
    Other parts used were a compatible VGA LCD controller and its corresponding AC power supply.
    To hide the shiny metal surround of the LCD assembly, I placed electrical tape on the LCD screen before carefully painting the surround black (the tape was then removed when the paint was completely dry).
    However, the front panel controls can be accessed through a gap in the bezel, and the AUTO button (adjusts picture size to the video source) should only be performed when a test pattern is displayed through the service menus of the oscilloscope (active video area extremities are used).
    Overall, the end result was quite good.
    Re: LeCroy LC Series Oscilloscope LCD Conversion
    Very nice!
    I take it the LeCroy internally uses VGA signalling for its CRT tube?
    Did you have any issues with the VGA signal timing/resolution on the LCD?
      • 31301
      LeCroy are pc based.
      • tibimakai
        • Jan 2012
        • 3680
        How hard it would be, to upgrade a Rigol DS1054 to a bigger screen?
          • 31301
          probably impossible,
          afaik the rigol uses a digital matrix panel, not a "monitor" panel.
          • keeney123
            Lauren
            • Sep 2014
            • 2536
            Nice looking scope.
            • RetroComputingGrotto
              IBM LTO 7 Tape Drive - Dust Sensors??
              by RetroComputingGrotto
              I have a Quantum SuperLoader robotic tape library that uses an IBM LTO 7 tape drive which is constantly complaining that it needs cleaning. If you insert a cleaning tape, it performs the clean and resets the cleaning counter to 0 hours. It should only require cleaning every 50 or so working hours but after as little as just 1 hours use it requests cleaning. We've purchased a new cleaning tape along with new LTO backup tapes but that has not resolved the problem.
              I have taken the library apart and can see no noticeable signs of dust inside. I have removed the tape drive from the...
              09-19-2024, 01:54 AM
            • howardc64
              by howardc64
              Problem
              08-04-2024, 10:36 PM
            • triplefour
              LG 75UN8570AUD panel issue fixed with tape.
              by triplefour
              I've been seeing a lot of the new TVs (samsung and LG only i think) maybe 1-2 years old suffering from sudden panel death and have been over 50% successful bringing them at least most of the way back to functionality if not all the way, with the tape masking of the LVDS pins method.
              add this one to the list. the issue was on the left side of the panel and i ended up blocking just 3 pins on the connector that joins the two panel boards that make up the left side of the panel (it has 4 boards total) i didnt get the picture back to 100% perfect. i spent hours fiddling with which pins to block...
              07-17-2023, 10:22 PM
            • CDNBrewer
              Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
              by CDNBrewer
              Hello Everyone,
              I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
              Symptoms:
              • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
              • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
              • I swapped the Left and Right surround
              08-05-2025, 09:29 PM
            • karatzdi
              Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
              by karatzdi
              I know some might say... just buy another one. Sell it as parts..!
              So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
              Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
              Spent some time downloading the Service...
              06-11-2024, 08:38 AM
