I can't seem to find this info anywhere - SX280 max CPU
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    What's the max CPU that can be used in a Dell SX280? I've been searching for over 2 hours....someone has to know... I know they won't support dual cores, but will they run the 2mb L2 cache and 64-bit supported cpu's?!?
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
  • Wizard
    • Mar 2008
    • 2296
    Re: I can't seem to find this info anywhere - SX280 max CPU
    what's chipset?
    Due to small size they can only can handle so much watts.
    Secondly lot of dual cpu P4s are prescott which is too high watts for small factor (over 100W)
    and let alone the single core P4 prescott of celeron 2.4 (73W) and P4 2.66 both 533 fsb at 84W. That is why I strictly choose Northwood P4 for good power and HT feature (800Fsb and 2.8GHz, 68W). The most these can handle is northwood 3.0GHz.
    Over 3.0GHz prescott, the watts rapidly climbs past 100W mark.
    Cheers, Wizard
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16958
      I've seen a few of them with 3.4's in them... It's an Intel 915G Express Chipset.
      Team : 49813
      Join in!!
      Team Stats
      • Wizard
        • Mar 2008
        • 2296
        Socket 775 only hmm!
        P4 651 = 3.4GHz later generation prescott 65W rev D0
        P4 651 = 86W both are 2MB cache, prescotts
        P4 650 = 3.4GHz - 2MB prescott 84W
        But there are older 1MB prescott cpus that are hungry too:
        P4 550 (3.4GHz 84W 1MB 84W
        P4 550(3.4GHz - 1MB) 115W
        P4 551 (3.4GHz - 1MB) 84W
        You can see quite spread of P4s in watts and knowing big names like Dell, tend to use coolest CPU usually especially in small cases. You would have to check those SX280 3.4 CPU type with a CPU ID utility. If it say rev D0 then it is cool cpu.
        BTW: google: "erols process spec" without quotes and click first link.
        PS what's is your going price for SX270 that needs recapped? as I don't have funds to buy working ones but at good price and can fix too.
        Cheers, Wizard
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16958
          All the 270's I get I repair, I don't sell broken units. I do have a couple of them here that are missing various parts (hdd's and opticals).
          The chipset is the 915G, supports 800fsb. I ended up with 4 sx280's, one without a CPU, so I was going to jam the fastest thing I could in it.
          Team : 49813
          Join in!!
          Team Stats
          • Wizard
            • Mar 2008
            • 2296
            Okay. 800 fsb? not all these P4 I listed uses 800 so that narrows to few especially with socket 775. Some came with 1066 fsb.
            P4 D (dual cpu) is way too much power and I think requires different chipset too.
            Cheers, Wizard
            • arneson
              • Sep 2005
              • 1267
              http://www.youtube.com/watch?v=T6kbB8BtV6I
              This guy at the end shows 3.4gig and 3gig of ram right about 5:15 he shows upgraded specs.
              Jim
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16958
                FWIW, I stuck a 3.4GHz/800fsb/1mb CPU in one with the A9 BIOS, it would post, bitch about an incompatible CPU, and halt itself....
                Team : 49813
                Join in!!
                Team Stats
                • Wizard
                  • Mar 2008
                  • 2296
                  Try 3.2 or 3.0. Is A9 bios the latest?
                  Cheers, Wizard
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    maybe edit the bios to insert the microcode for your chip?
                    • kc8adu
                      • Nov 2003
                      • 8832
                      • U.S.A!
                      btw it looks like there are a few bad caps showing in that very crappy video.
                      all the sx boxes are hard on caps.run way too hot.
                      • Topcat
                        The Boss Stooge
                        • Oct 2003
                        • 16958
                        Yes they are. This 280 was full of bad panasonics when I got it. The extreme heating, plus the fact that this machine ran 24/7, they roast even good brand caps. As tough as the good brand caps may be, they're not indestructible!
                        I may see what I can do with the BIOS, it's been a while since I hacked one, so it may be worth a shot. A GX280 will run the same 3.4, and the SX280 is the same chipset, so they have it disabled likely for power reasons.
                        Team : 49813
                        Join in!!
                        Team Stats
