Norsat NewsLink laptop battery and charger
  • i4004
    • Oct 2006
    • 2029
    Re: Norsat NewsLink laptop battery and charger
    just to reiterate pcbonez and willa's points:
    change sox, trim nails.
    <wink>
    • pentium
      • Mar 2006
      • 2778
      Thanks.
      I'll get right on that.
      Find Nedry!
      Check the Vending machines!!
      <----Computer says I need more beer.
      • linuxguru
        • Apr 2005
        • 1564
        You can install Linux on a 2.5" IDE HD with a USB-to-IDE external 2.5" HD case or adapter, on any machine with a USB socket and a well-supported USB host chipset (just about any Intel, Via, ATI, ... chipset). The only tricky part is making it bootable, which requires fooling around with the grub.conf or lilo.conf and making it point to /dev/sda or similar.
        It may still barf while booting on the target machine, because of LBA/geometry problems - just play around with different grub/lilo options.
        FC3/FC4 will run fine even on PII/266, provided you use a lightweight window manager like XFCE.
        Edit: That's a mobile coppermine or tualatin, probably ULV (ultra-low voltage). In combination with a 440MX, it's a bulletproof platform.
        • pentium
          • Mar 2006
          • 2778
          Well, I really was thinking of just using Windows 2000 on it.
          The fact that the onboard video only has 8Mb of memory really limits down my Linux choices and I already have a system running Linux.
          I only need the thing to run Steam so I can play Half-Life, Counter strike and run a few other things like Word.
          Find Nedry!
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            8Mb does fine in a laptop.
            Mann-Made Global Warming.
            - Dr Seuss
            • pentium
              • Mar 2006
              • 2778
              True though it pretty much eliminates playing any newer games.
              Find Nedry!
              • 370forlife
                Large Marge
                • Aug 2008
                • 3113
                Manual shows Audio Out and MIC jack under cap on left side near power switch.
                Says: "Connects a Hi-Fi set."
                Spec section says:
                Integrated into Crystal codec CS4299, 20-bit stereo digital-to-analog
                and 18-bit stereo analog-to-digital converter, Windows Sound System
                compatibility and full-duplex capability.
                10.4-inch TFT XVGA LCD, resolution up to 1024x768, 18-bit color.
                8 MB (built-in on VGA chip).
                Integrated into ATI RAGE Mobility-M1, MotionComp capability,
                hardware aid for DVD playback and dual view support.
                VGA port via optional docking station.
                Ahhhhh HA HA HA HA
                The most evil sound card I have ever experienced. No drivers for it from windows, and good luck finding working drivers! Same thing was integraded into my old p3 vectra vl600 board, eventually got the original hp vectra vl600 disk from hp.
                And you could put XP on that. I have it running on my Dell inspiron 3500 with a p2/333 and 256mb ram, 4gb hard drive. Remember, xp will adjust how much ram it uses to how much you have, that laptop has 256, so xp uses about 120 when it runs. I can see why that picture said not to touch that one spot, thats where the processor is and it has no cooling device what so ever.
                • pentium
                  • Mar 2006
                  • 2778
                  Originally posted by 370forlife
                  Ahhhhh HA HA HA HA
                  I would go with XP if I just had at least 16Mb of video ram. 8Mb I think would just be a tad too little.
                  Well they did their best to spread it around.
                  The chipset on the other side has the same.
                  Find Nedry!
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    Ahhhhh HA HA HA HA
                    Manufactures site I linked to up above has sound drivers for it for NT4, W98, W2k, and XP.
                    They should work for you too if it's the same sound chip.
                    - Dr Seuss
                    • 370forlife
                      Large Marge
                      • Aug 2008
                      • 3113
                      8mb is more than enough for xp, that VL600 had a 8mb millenium G250 in it. My lappy has a 2.5mb video card!!!
                      • Wizard
                        • Mar 2008
                        • 2296
                        #31
                        That's very good heatsink design, big flat area to spread heat out via heat pipes.
                        Um, you can read the fine print on the CPU, it is not 100mhz. I think could be 600, 700, 800, 900 or 1GHz PIII.
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          100mhz ->> FSB
                          - Dr Seuss
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            By mfr specs it should be a 700Mhz on 100Mhz FSB.
                            - Dr Seuss
                            • pentium
                              • Mar 2006
                              • 2778
                              Yeah but I only have one copy of XP left (which I am saving for my PC) and I can install Windows 2000 sa many times as I want.
                              Find Nedry!
                              • PCBONEZ
                                Grumpy Old Fart
                                • Aug 2005
                                • 10661
                                This may or may not work but you could try:
                                Your chipset supports 4 banks of memory.
                                A 256Mb Low Density Module is 2 bank.
                                A SO-DIMM slot can handle 4 bank.
                                If they completed the wiring from slot to chipset for the other banks (even though they were only expecting 2 bank) then it might handle a 4 bank module even though it wasn't advertised.
                                At the time the laptop was built 512Mb SO-DIMM Modules didn't actually exist much (if at all) in the open market and so wouldn't be mentioned in the old documentation.
                                It's not unusual for them to build something with contingencies for expected new technologies but to not mention it in the documentation if the technology isn't officially released yet by the time the machine is sold.
                                If you can find a 4-bank 512Mb module (!I don't even know if they exist in SO-DIMM!) and that wiring is in place the chipset might handle it like two 256Mb modules in to side-by-side slots.
                                I say this because:
                                Was a long time ago so I don't remember all the specifics but I worked on a 2 RAM slot laptop where the docs said 256Mb/slot max and I got a single 512Mb to work as long as second slot was left open.
                                *If* you slot is fully wired,,, a 4 bank module 512Mb module *should* work.
                                No warranty expressed or implied. -
                                - Dr Seuss
                                • pentium
                                  • Mar 2006
                                  • 2778
                                  Hmmm, that might be worth testing.
                                  Now the thing would be I would have to find a compatible 512Mb SO-DIMM that if I found out does not work, I can return and just live with a 256.
                                  Find Nedry!
                                  • 370forlife
                                    Large Marge
                                    • Aug 2008
                                    • 3113
                                    http://www.newegg.com/Product/Produc...82E16820148030
                                    512mb
                                    http://www.newegg.com/Product/Produc...82E16820148027
                                    256mb
                                    • pentium
                                      • Mar 2006
                                      • 2778
                                      Okay then, now I just need the money.
                                      Find Nedry!
                                      • PCBONEZ
                                        Grumpy Old Fart
                                        • Aug 2005
                                        • 10661
                                        Those are both only 2 bank modules.
                                        http://www.crucial.com/store/partspe...E=CT64M64S4W75
                                        If you want to try 512Mb it would likely have to be 4 bank.
                                        If 4 bank even exists it will be rare and hard to find.
                                        256Mb pieces are fairly common and cheap on eBay anymore.
                                        Make sure it's 16 chips on the module and you should be okay.
                                        - Dr Seuss
                                        • pentium
                                          • Mar 2006
                                          • 2778
                                          Wait a sec, you found the drivers for this laptop?
                                          Could you help me out and supply a link to the page?
                                          Find Nedry!
                                            NVDC charger configuration...
                                            11-05-2024, 03:28 PM
                                            ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                                            Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                                            The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                                            for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                                            Narrow VDC applications where the system power source is
                                            either the battery pack or the regulated output of the charger.
                                            This makes the max voltage to the system equal to the max
                                            battery voltage instead of the max adapter voltage. Operating
                                            at lower system voltage can improve...
                                            11-05-2024, 04:43 PM
                                          • serious_electron
                                            Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
                                            by serious_electron
                                            Hello Everyone!
                                            I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
                                            06-28-2025, 02:57 PM
                                            Texas Instruments bq24745 bq24745RHDR bq24745RHDT Battery Charger IC for Laptop Computers Datasheet
                                            The bq24745 bq24745RHDR bq24745RHDT is a high-efficiency, synchronous battery charger with an integrated input-current comparator, offering low component count for space-constrained, multi-chemistry battery-charging applications. The input-current, charge-current, and charge-voltage DACs allow very high regulation accuracies that can be easily programmed by the system power-management microcontroller using the SMBus interface. The bq24745 charges two, three, or four series Li+ cells, and is available in a 28-pin, 5-mm x 5 mm QFN package.
                                            The bq24745 features dynamic power management...
                                            10-23-2024, 02:50 AM
                                          • flat-earther
                                            how to prevent a connected charger from draining battery when not charging?
                                            by flat-earther
                                            I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                                            So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                                            but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                                            So the battery is backfeeding the charger and being drained.
                                            How can I prevent...
                                            08-07-2025, 01:04 PM
