Look what a customer gave me
  • TechGeek
    Computer Geek
    • Jan 2015
    • 2254
    Re: Look what a customer gave me
    oh NOooooooooooooooooooooooooo
    Permanently Retired Systems:
    Kooky and Kool Systems
    sigpic
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5045
      • US
      Originally posted by stj
      FR - universal fix!
      2000hrs endurance on those taepos, planned obsolescence at its finest
      is 0.085mOhms to 0.056mOhms too much difference? although 750 to 950ma is ok. This isn't a pc power supply. FC is closer but only 3000hrs for this one, as where the FR is 6000.
      Should be ok.
        • 31303
        should be fine.
        • mecha1166
          Anyone here fix a tv and customer cracks panel when they get it home?
          by mecha1166
          About 2 times a year, a customer will do this. We fix the tv, put it on test play, and customer sees it working. They see me pull power and video wire. Sometimes I pick up tv, right in front of them, and carry it out to their vehicle while they are next to me. I set it in their tv gently, and tell them the tv is very fragile, be careful with it. I let them close the door/trunk. That day, or a few days later, they tell me there is a crack inside the tv. Normally I tell them transportation is their responsibility and normally that is the end of it. Has anyone had a customer that was not buying this...
          03-29-2024, 11:27 AM
        • ilkysmt
          Dell Inspiron 15 Gaming 7567 LA-D993P Rev1.0 Watt Problem
          by ilkysmt
          When the customer brought the device, only the charging port was broken. The charging port was replaced, and the PR114 33-ohm resistor, which transmits the psid voltage, broke. However, the device then gave a low-wattage warning and reduced performance with the original 130W charger. When I tried it with another customer's 240W charger, the warning disappeared, and the device functioned properly.
          I opened the original charger and checked the internal ID IC. There was no problem. Then, just to be sure, I ordered the 330W DS2501 IC. When it arrived, I tried it again, and the warning...
          11-13-2025, 08:15 AM
        • Comp_Pro
          Macbook 820-00850 20V 54mA No Power
          by Comp_Pro
          I'm trying to diagnose this board with no power.
          The board was originally brought in for water damage. Corrosion was not very bad and the board was successfully repaired by a quick ultrasonic cleaning. All corrosion was very surface level and no solder repair was needed at all. No oxidized components can be seen. Customer took the laptop home and it worked fine until it was brought back for warranty. Customer was watching youtube when it suddenly shut down. Customer says last time she tried turning it on it would turn on after a very long while but gave some...
          02-28-2023, 11:18 AM
        • Prabuth
          always showing this message AC adapter = Unknown
          by Prabuth
          The customer gave me this for changing the old battery, and then I replaced the new battery. always showing this message. I changed many chargers and programmed the new BIOS as well. Does someone have any idea for this message?
          08-28-2025, 01:26 AM
        • reformatt
          by reformatt
          07-31-2025, 08:37 PM
