Yeah, nothing quite like trying to make 50mhz pci stable hmm? Damn I loved my Abit KR7A-Raid.. 1ghz AXIA tbird and a 256mb stick of crucial pc2100.. all the vmods.. *sniff* With a peltier I bet I could get this 667 p3 stable at 900 or so.. I've got upto 1.9v in the bios to play with.. What ram do you suggest for those kinds of speeds?
Hmm I've heard that Crucial pc133 will do 150+, think theres a good shot at that? Its alot cheaper than getting real pc150 or pc166 stuff. Also, what about running a tualatin? I know the board doesnt support them, but the s370 tualatin 'adapters' are so cheap.. Good idea?
I've had very good luck pushing crucial CAS2.5 beyond 150. At 155+ it would get flaky. CAS2 wasnt much good beyond 140.
Is that the best option while remaining cheap? What about samsung? Also, how did you keep your hard drives uncorrupted at nearly 50mhz pci? A 66mhz raid card?
what chipset is that board? The board I did this on (Iwill DVD266u-RN) had manual settings for the PCI and AGP dividers, so I could ramp the FSB, and change the divider to get it as close as possible to the stock PCI clock setting, which was nice, and no corrupted data.
If you don't have those settings, there's not much you can do about it.
Its a i815. All I have is dividers upto 133mhz fsb. I ran upto 190 fsb on my KR7A with the same dividers and never had a problem with quantum or seagate hard drives. How high did the dividers on the DVD266u-RN go? Thats a dual s370 board based on a via chipset, right?
HAIL ENGINEERING SAMPLES!! I was able to get a few to run at almost 200FSB!! Gawd I miss those days!! Overclocking is sooo dead nowadays.
I'm still overclocking to keep up with newer processors.
If I can't afford an Athlon 64 PC system to build, probably going to get a later Athlon XP model.
Overclocking Athlon XPs (T-bred and Barton) are even easier than Athlon T-birds even with a locked multiplier. Because it's easy to increase the FSB frequency with nForce2 and Via KT400 or later.
So much for an Athlon T-bird 900 mhz processor I have still working, because I wasn't even able to get 1050 mhz stabily.
ASRock B550 PG Velocita
Ryzen 9 "Vermeer" 5900X
Arc A770 16 GB
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
