Abit SA6 successfully recapped - Overclocking
  • wigyori
    • Jan 2005
    • 25
    Originally posted by RuKK
    And just because I can..
    Geez, you're crazy running at 180FSB Nice job anyway
    -w-
  • RuKK
    • Feb 2005
    • 34
    Hehe it'll be crazy trying to get NIC/hdds to run at 45mhz PCI, and a video card to run at 90mhz agp
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16956
      HAIL ENGINEERING SAMPLES!! I was able to get a few to run at almost 200FSB!! Gawd I miss those days!! Overclocking is sooo dead nowadays.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • RuKK
        • Feb 2005
        • 34
        Yeah, nothing quite like trying to make 50mhz pci stable hmm? Damn I loved my Abit KR7A-Raid.. 1ghz AXIA tbird and a 256mb stick of crucial pc2100.. all the vmods.. *sniff* With a peltier I bet I could get this 667 p3 stable at 900 or so.. I've got upto 1.9v in the bios to play with.. What ram do you suggest for those kinds of speeds?
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16956
          I have a batch of Corsair true PC150 which I used for those experiments. It ran hot as hell, but was always reliable at speeds well above 150MHz
          Team : 49813
          Join in!!
          Team Stats
          • RuKK
            • Feb 2005
            • 34
            Did you heatsink it? Probably more expensive than DDR but I'm almost tempted to go looking
            • RuKK
              • Feb 2005
              • 34
              Whoa.. bunch of posts just dissapeared in this thread.. Or is it just me? :o
              //edit nevermind.. just moved from forums. Thought I'd broken the rules and gotten my thread deleted for a second there
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16956
                Nope... I split the overclocking part to general, since we all launched way off topic on the overclocking tangent.
                Team : 49813
                Join in!!
                Team Stats
                • RuKK
                  • Feb 2005
                  • 34
                  Oh ok, yeah.. I'm blind. And its late >_>
                  Hmm I've heard that Crucial pc133 will do 150+, think theres a good shot at that? Its alot cheaper than getting real pc150 or pc166 stuff. Also, what about running a tualatin? I know the board doesnt support them, but the s370 tualatin 'adapters' are so cheap.. Good idea?
                  • Topcat
                    The Boss Stooge
                    • Oct 2003
                    • 16956
                    I've had very good luck pushing crucial CAS2.5 beyond 150. At 155+ it would get flaky. CAS2 wasnt much good beyond 140.
                    Team : 49813
                    Join in!!
                    Team Stats
                    • RuKK
                      • Feb 2005
                      • 34
                      Is that the best option while remaining cheap? What about samsung? Also, how did you keep your hard drives uncorrupted at nearly 50mhz pci? A 66mhz raid card?
                      • Topcat
                        The Boss Stooge
                        • Oct 2003
                        • 16956
                        what chipset is that board? The board I did this on (Iwill DVD266u-RN) had manual settings for the PCI and AGP dividers, so I could ramp the FSB, and change the divider to get it as close as possible to the stock PCI clock setting, which was nice, and no corrupted data.
                        If you don't have those settings, there's not much you can do about it.
                        Team : 49813
                        Join in!!
                        Team Stats
                        • RuKK
                          • Feb 2005
                          • 34
                          Its a i815. All I have is dividers upto 133mhz fsb. I ran upto 190 fsb on my KR7A with the same dividers and never had a problem with quantum or seagate hard drives. How high did the dividers on the DVD266u-RN go? Thats a dual s370 board based on a via chipset, right?
                          • RJARRRPCGP
                            • Jul 2004
                            • 6304
                            I'm still overclocking to keep up with newer processors.
                            If I can't afford an Athlon 64 PC system to build, probably going to get a later Athlon XP model.
                            Overclocking Athlon XPs (T-bred and Barton) are even easier than Athlon T-birds even with a locked multiplier. Because it's easy to increase the FSB frequency with nForce2 and Via KT400 or later.
                            So much for an Athlon T-bird 900 mhz processor I have still working, because I wasn't even able to get 1050 mhz stabily.
                            ASRock B550 PG Velocita
                            Ryzen 9 "Vermeer" 5900X
                            Arc A770 16 GB
                            eVGA Supernova G3 750W
                            Alienware AW3423DWF OLED
                            • ArtMov
                              [HELP] Asus g732lv ami bios overclocking lock reseting after reboot
                              by ArtMov
                              Hi guys, i have a problem , my bios resets disabled overclocking lock setting to enable after reboot, please tell me which function can be responsible for restoring the stock config for this option, loading parameters from nvram and so on, like bios ,protection, from asus. My bios made me angry) Set default parameter to disable in amibcp 5 , doesn't help(
                              1. I made overclocking lock disabled the default in amibcp
                              2. I changed the varoffset to the wrong one, but it led to the programmer, it was very tedious and nervous, I really regretted it, my chip is on the back of the...
                              03-31-2023, 01:30 PM
                            • ziplock
                              Abit BE6-II motherboard
                              by ziplock
                              Greetings,
                              I have an Abit BE6-II motherboard that posts sporadically with the bare minimum components installed - CPU, RAM, PSU, and a Keyboard. I know it posts when the speaker beeps. Re-seating the components has no effect.
                              I thought the sporadic posting might be capacitor related. Upon inspection, non of the caps are bulged or leaking and they are all original. So, I pulled them ALL. While the ESR is OK, over half of them are leaking current between 1 and 2 mA. The biggest offenders are way out of spec, like a 1500uf / 6.3V measuring 2600uF and many of the 820uF caps...
                              04-20-2025, 02:09 PM
                            • Foetuss
                              Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
                              by Foetuss
                              Hi all
                              Hope this is in the correct place.
                              I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
                              Could use some double checking to see if I'm not doing something stupid .
                              Pictures of the boards are attached.
                              What I will be replacing with what : (planned)
                              Soltek Golden ::
                              4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
                              6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
                              01-18-2025, 11:44 AM
                              ABit IP35 Pro Motherboard Schematic
                              ABit IP35 ProABit IP35 Pro Motherboard Schematic
                              A motherboard based on the Intel P35 Bearlake-P+ RAID chipset....
                              10-31-2024, 02:06 PM
                            • tbalint3
                              Abit ST6-Raid repair
                              by tbalint3
                              Hello All,
                              I am trying to repair an old Abit ST6-R motherboard.
                              The symptoms are the following:
                              I got it in a non-working state. I was told that it sometimes turned on, but many times just the CPU fan was spinning and no other signs of life, the board didn't POST, and now it doesn't POST at all.
                              It was full of bulged electrolytic capacitors, so I replaced all of them with new Low-ESR ones, but it didn't solve the problem.
                              If I install a CPU in the S370 socket, only the fans are spinning and no POST. There are no beep codes even if the RAM DIMMs...
                              09-01-2024, 10:03 AM
