Printer identification from printed documents
  • Spork Schivago
    • Mar 2012
    • 4734
    • United States of America
    Are laser printers the only printers that use steganography? I have a Brother MFC-L8850CDW LED laser printer. I've read a blue LED light will sometimes show yellow dots that represent the serial number or some other tracking information.
    I'm curious if there's any other types of printers that leave tell tale signs of what printer was used to print the document. For example, let's say I have two different documents printed somewheres between 1993 - 1996. I can see on one of them, using a magnifying glass, it looks like every line was printed with little tiny dots. Each and every character seems to be made up of just little tiny dots. They're not perfectly round. They bled a little. The other document though, using the magnifying glass, it looks like it was printed using square lines (like when you draw a vertical line using a drawing program). Each letter with the second document are all made with the square lines. Each letter in the first document seem to be made with little tiny dots.
    Do they tell any of you guys what type of printers might have been used to print any of these documents?
    -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
  • Spork Schivago
    • Mar 2012
    • 4734
    Re: Printer identification from printed documents
    One dot on the dotted document seems to measure 1/32 of an inch. So, there'd be 32 dots per inch, from what I can tell. I believe the "dotted" document was printed with a dot-matrix printer.
    https://upload.wikimedia.org/wikiped...ample_text.png
    It looks very similar to that, just the quality of these disk labels seem to be a bit higher. Any idea what dot-matrix was common in the 90's that could print floppy disk labels?
    I can scan images if someone would like to try and take a guess at what printer was used.
      • 30979
      HP *Jet series and Canon where around in the early 90's, i had a canon.
      not sure when Epson got into colour inkjets.
      i wonder if the yellow dot has an equiv trick on black-only printers.
      dont forget the more unusual and expensive stuff btw.
      like wax or plastic printers like the tektronix phasor sublimation printers.
      https://en.wikipedia.org/wiki/Solid_ink
      • Spork Schivago
        • Mar 2012
        • 4734
        Okay, Thanks Stj.
        Also, I do believe black-only printers had something equivalent. Microprint or something like that.
        • mmartell
          • Oct 2013
          • 3189
          I'm curious as to why you would like to track down the printer that made 20+ year old labels ?
            • 30979
            i think he wants to id the font used
            • Spork Schivago
              • Mar 2012
              • 4734
              Yes. I'd like to be able to recreate exact duplicates. That's only part of the reason though. It seems impossible to contact the original owner and I'd like to create a website that lists various things about this software set. If I cannot figure it out, it's okay, but I'd like to try. It's been fun and I think I'm finally getting somewheres. So far, I can add to the site, when most of the versions were released. I have all the older shareware versions and the last two registered versions. I know what compiler (for the most part) was used, how the EXEs were packed and I've broke the custom archive file format.
              I thought it'd be nice to be able to say the manual was printed on a LaserJet IIID using the Times New Roman font. The picture on the front was created using Paint Brush.
              Even if I can't figure that stuff out, that's fine. It'd be nice to be able to at least create exact copies of the manual and disk labels and share them with other people.
              • re-atari
                Anycubic Photon 5.5 3D printer 25Q32 flashrom dump needed
                by re-atari
                Hello all, as the title says, I'm very much in need of a valid firmware dump of a Anycubic Photon 5.5 3D resin printer. It's stored in a Winbond 25Q32, so it's 4Mbyte.
                Here's a little background for my request. A few weeks ago I bought this 3D printer from a guy who had moved on to a PLA printer. I got it at a vey reasonable price, as it was in a defective state. The seller told me that he had experienced a power failure during a firmware upgrade, after which the printer appeared to be dead. He thought the firmware was corrupted in such a way that the printer was now bricked. As he...
                02-03-2025, 06:49 PM
              • Artefil
                HP officeJet 8012e ... A printer update will be installed to fix this problem
                by Artefil
                One of the partner I'm mostly working with, brought his Officejet 8012e, facing a problem I'm failing finding a solution.
                On the Officejet 8012e, there's only one USB connector on the back, for connecting the printer to a computer.
                The screen displays the following message :
                "a problem has occured with one of the printer's critical system files. A printer update will be installed to fix this problem"
                But even if the printer is connected through wifi to the network, nothings happen, and the printer stays idle for days.
                Have you ever...
                09-28-2023, 05:11 PM
              • прямо
                Need dump for 58mm Thermal Printer
                by прямо
                a friend gave me this printer because it's no longer working.
                It powers on, but won't do a self-test print and when connected via USB to Windows, Device Manager says No Printer Attached under USB Hubs tree.
                The red light doesn't blink either with no paper inside.
                I think the firmware maybe corrupted. If someone has a similar printer and can provide a firmware dump, I really appreciate it.
                Printer model: Panda PRJ-58U
                Flash memory: Boyamicro BY25D16ASSIG
                03-15-2024, 09:12 PM
              • flat-earther
                HP F4180 stopped working please help troubleshoot
                by flat-earther
                I was doing a large print job with my HP Deskjet F4180, and after about 50 pages the printer stopped in the middle of a page and the black ink light started flashing.
                So I went to refill the black ink cartridge with a syringe, but found out it still had a lot of ink.
                I tried to print a page again but every time it would print only a bit of the page and immediately stop with the black ink light flashing again.
                I tried two other black ink cartridges, and the problem still endured, so I knew this problem had to be with the printer itself.
                I ran HP Print and Scan...
                05-11-2025, 02:21 AM
              • Curious808
                Brother HL-2140 laser printer: printer error (solved)
                by Curious808
                SOLVED. I removed the printer in settings, replugged and let it reinstall and it worked this time.
                Windows 10
                Attempt to print and immediately get a Windows pop-up saying "Error printing". The document appears in the printer queue window with Status "Error-printing".
                Turned off printer. Unplugged, waited, replugged. Ran the Windows troubleshooter. Removed and reinserted toner cartridge. Checked for paper jam. No printer error lights. Reinstalled driver. Restarted the Spooler service. Rebooted...
                06-22-2023, 11:11 PM
