Well, I have several socket 462 boards, 3 of them are Asus, one GigaByte, one MSI etc. Also, I have processors: 2x Duron 750, 2x AthlonXP 2000+ and one Athlon Thunderbird 1200. (Every cpus are tested with good board)
Every board works fine with Durons 750, except Asus A7V8X-x. That board boot only with one of Durons (?!) and works fine and stable. Other processors never post! (I tried every possible combination of various hardware, jumpers, bios reset, flash etc.)
One board, GigaByte, have jumpers for multiplier and bus speed while others are jumperless. When I set that board manually, it posts with every cpu, but not on theirs default settings. Sometimes I can run cpu even faster, for example Athlon 2000+ boots on 11.5x100, 11.5x133, even 11.5x166, but not 12x100! Also, I can run Athlon 2000+ with multiplier 5-7 and 9.5-11.5 but not 7.5-9!
Does anybody knows why socket 462 boards works fine with Duron 750, but not with faster CPUs? I have 8 boards with same behavior! Is it possible that bad caps causes that problem? Is it repairable?
I tried to recap three boards, but results are the same. I am so confused
What should I do?
Thanks!
What should I do?
Thanks!
