Why my s462 boards posts only with Duron 750?
  • LeGrr
    • Sep 2007
    • 6
    Well, I have several socket 462 boards, 3 of them are Asus, one GigaByte, one MSI etc. Also, I have processors: 2x Duron 750, 2x AthlonXP 2000+ and one Athlon Thunderbird 1200. (Every cpus are tested with good board)
    Every board works fine with Durons 750, except Asus A7V8X-x. That board boot only with one of Durons (?!) and works fine and stable. Other processors never post! (I tried every possible combination of various hardware, jumpers, bios reset, flash etc.)
    One board, GigaByte, have jumpers for multiplier and bus speed while others are jumperless. When I set that board manually, it posts with every cpu, but not on theirs default settings. Sometimes I can run cpu even faster, for example Athlon 2000+ boots on 11.5x100, 11.5x133, even 11.5x166, but not 12x100! Also, I can run Athlon 2000+ with multiplier 5-7 and 9.5-11.5 but not 7.5-9!
    Does anybody knows why socket 462 boards works fine with Duron 750, but not with faster CPUs? I have 8 boards with same behavior! Is it possible that bad caps causes that problem? Is it repairable?
    I tried to recap three boards, but results are the same. I am so confused
    What should I do?
    Thanks!
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Why my s462 boards posts only with Duron 750?
    first make sure those boards officially support the procs you have.
    some will only support athlon xp with certain board rev. and bios.
    • gdement
      • Jan 2007
      • 690
      The 2000+ definitely won't work on everything, it's a newer core that would require an updated BIOS to even POST on older boards. As for the weird missing multipliers, I don't know what causes that but I've heard of it. Isn't that chip supposed to run 133x12.5 (not 12)?
      I think there's a compatibility breaking point around 12.5x. They added another bit to the multiplier table and there can be some issues crossing the boundary. I'm vague on the details but multipliers like 7.5-9 might be getting mapped to something else that doesn't work.
      But the Tbird 1200MHz ought to work on everything. Unless it's a mixup with bus/multiplier settings. But even if it's a 133mhz bus model it should still be able to run at 100x9 on older boards. If it isn't unlocked then you'll need to have the multiplier correct for it to POST.
      It's possible a BIOS flash might fix some things with processors that the old BIOS doesn't fully understand.
      If a motherboard is marginally stable, it's possible for it to barely run using a slower processor but not be able to handle something faster. But it's unlikely you're having that same scenario with several boards.
      As for the Asus that only works with 1 of your Durons... I have 2 guesses.
      1) There's a difference in the stepping of those Durons, causing one of them not to be supported (BIOS flash might fix it)
      2) The board is running really badly, and one of the Durons is just more tolerant than the other.
      3) Maybe there's something funny with the contacts on the ZIF socket, and/or the CPU pins? Perhaps some corrosion on one of the Durons that the Asus' socket isn't quite able to get through? I know, this is unlikely, but just a guess.
      • LeGrr
        • Sep 2007
        • 6
        Thank you for replies,
        Well, every board is compatible with all processors, some of them worked for years with that processors, especially GigaByte board GA-7VAXP with XP2000+. That board survives power surge about one year before stop posting with XP2000.
        Athlon 1200 boots on that GA-7VAXP board at 100MHz bus on automatic multiplier settings, on manual it run on various multipliers, but below 9.
        And for Asus that works with only one Duron
        I tried almost everything. Detailed washing, treating socket with contact sprays, air blowing etc. I also washed "faulty" Duron. Nothing happens
        What part of the motherboard is responsible for cpu recognition?
        • stevo1210
          • Oct 2006
          • 4156
          The part that I think is responsible is the BIOS and the Northbridge though I may be wrong.
          • ugamazing
            Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
            by ugamazing
            I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
            We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
            12-17-2024, 07:05 PM
          • ugamazing
            Apple M1 Boards & Exclamatory Error?
            by ugamazing
            We've now created a stack of 10 boards that have the same issue, which we suspect to be CPU-related. The issue is very simple--the board will not boot to anything, only showing the exclamatory sign inside a circle. No amount of DFU/restore, wipe/erase, etc, will resolve the issue. No boards have physical damage. We went ahead and replaced the SSD nands on two boards (one 02020, one 02016) and the issue remained exactly the same. We are considering replacing the CPU on one of the boards using a locked CPU, just so we can see if it resolves the issue.
            Has anyone else run into this...
            02-20-2025, 09:24 AM
          • TuanTongbadcaps
            Change CPU multiplier through BIOS editing
            by TuanTongbadcaps
            Is there a way to change the CPU multiplier through editing the laptop's BIOS. I have a Latitude 7300 using Intel core I7-8665U CPU which has default multiplier settings between x4.0-x48.0. The problem with the device is that as soon as Windows boots up, the processor temperature is always high (usually in the range of 97-100 degrees Celsius), the multiplier is in the range of x46.0 - x48.0 even though no applications enabled. On a desktop we can change many things related to core voltage, multiplier or base frequency. but on laptop models using U suffix processors this is not available. I would...
            07-22-2024, 07:57 PM
          • ugamazing
            Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
            by ugamazing
            I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
            08-31-2022, 07:34 AM
          • hopkok
            Legion 5 PRO, 3 boards, same problem, NM-D562 Rev. 3.0 motherboard
            by hopkok
            Hi friends, last week I got 3 same boards for repair (NM-D562 Rev. 3.0), same problem, power button light up, but motherboard wont start.
            3,3V_alw and 5V_alw, 1,8V_alw and 0,75V_alw presented on all 3 boards, no other voltages. 1,2V missing and if I checked schematic right, I need 1,2V and than can be +3VS and +5VS generated after getting SUSP_N signal from KBC? or vise versa?
            I checked for low resistance on coils, no low resistance.
            Anyone with same issue like me?
            Thanks for any help.
            05-24-2025, 04:21 AM
