Hi guys;Today i was surprised with this win 10 version 1511 update and it just reinstalled the whole system, though all my files were preserved,it scared me a bit cause the update was the same way when you upgrade and it did it by itself without questions asked, hope it will not disrupt system, after a few hours so far so good,have had the same update?
Win 10 version 1511?
Re: Win 10 version 1511?
It's like a Service Pack, so big update...
1511 means November 2015 update..."The one who says it cannot be done should never interrupt the one who is doing it." -
Yeah... Windows 10 is being constantly updated. Like Per Hansson said, it's kind of like a service pack but they don't call it that anymore.
I could see how it would be weird if you didn't expect it, since it looks the same as when you first install the OS.Comment
by TheUserHello to everyone ,
This is my first post here, and i would like to share with you a small story in case you can help me.
Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...02-10-2024, 02:07 PM -
by sikocanI believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
SN: PF3G1REP
MODEL: 20KW-00J1AU
PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
Channel: BIOS Requests ONLY!
by iZakreHello everybody!
To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
The thing is that I had installed TeamViewer and could log into the computer... -
by DaJetziI have an ASUS R900V notebook, MB version K95VM, which, after a BIOS update, shows a black screen and no longer boots; only the fan is running.
I got BIOS version 234 from https://www.asus.com/de/supportonly/...helpdesk_bios/
After the update failed, I read the memory contents of the EEPROM Winbond W25Q64VF and found the following lines: "EFI_SUCCESS K45VM.bin".
I then looked at the downloaded update, unpacked the zip file, and found the actual update named "K45VMAS.234". I was actually expecting something related to K95VM.
Somewhat confused,...1 PhotoToday, 01:04 AM -
by L36Hi All,
Having an issue with a bricked MSI GE65 - Model 9SF. Bricked BIOS, did not do a full BIOS dump backup including ME region (rookie mistake). Resorted using to the latest BIOS available from MSI to flash the BIOS via CH341A for this laptop.
Problem - I initially flashed a ME update that came out for this laptop as a separate update. Thus, before bricking the laptop the ME version was 12.0.94.2380. PMC version 300.2.11.1025 on the system. The MSI latest BIOS I'm trying to flash back via CH341A contains ME version 12.0.40.1433. PCM version 300.2.11.1024.
The...-
- Loading...
