MSI GE 65 - 9SF - Bad flash issue
  • L36
    Hi All,
    Having an issue with a bricked MSI GE65 - Model 9SF. Bricked BIOS, did not do a full BIOS dump backup including ME region (rookie mistake). Resorted using to the latest BIOS available from MSI to flash the BIOS via CH341A for this laptop.
    Problem - I initially flashed a ME update that came out for this laptop as a separate update. Thus, before bricking the laptop the ME version was 12.0.94.2380. PMC version 300.2.11.1025 on the system. The MSI latest BIOS I'm trying to flash back via CH341A contains ME version 12.0.40.1433. PCM version 300.2.11.1024.
    The issue I'm facing now is no POST. Power LED blinks few times and turns off. System will not power on at all anymore until I CMOS reset. Cycle repeats again.
    Any thoughts how I can progress? Is there a way to insert the updated 12.0.94.2380. PMC version 300.2.11.1025 ME into the BIOS I'm trying to flash that has ME version 12.0.40.1433. PCM version 300.2.11.1024?
    I do have the original MSI ME BIN file version 12.0.94.2380. PMC version 300.2.11.1025 but have no idea how to properly roll this into the BIOS I'm trying to flash.
    Any assistance greatly appreciated.
    Full model number: MS-17E2
    SKU: GE65 Raider 9SF-653US-BB9988H32GXXDX10MA
    Serial: K1905N0007637
    Make: MSI
    Motherboard Version: I'm unable to locate any stickers or PNs on the motherboard itself.
    • 20818
    RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
    You MUST:
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
    • L36
      You MUST:
      My apologies. Updated original post.
      • peste
        • 12755
        • ROMANIA
        try..https://www.msi.com/Laptop/GE75-RAIDER-9SF/support
          by Vesko356
          08-11-2023, 03:27 AM
        • abhorsen
          Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
          by abhorsen
          Hey guys,
          Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
          Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
          Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
          07-06-2023, 10:22 AM
        • bestrafer
          Lenovo L460 LAN issue after BIOS dump flash
          by bestrafer
          Hello everyone.
          I have L460 Type 20FV (2 X 8MB bios chips) with no boot issue after BIOS update (black screen with restarts, common issue on this model + BIOS update).
          BIOS dump(s) from this post https://www.badcaps.net/forum/showpo...7&postcount=27 makes the laptop boot absolutely fine, no delays, etc..
          But there is an exclamation mark in the device manager for the LAN card right after fresh OS installation - LAN naturally doesn't work. I saw requests like "BIOS: fix LAN" on other sites.
          Could someone point on a direction...
          01-31-2023, 01:14 PM
        • macabook
          πŸ› οΈ MSI GP75 Leopard MS-17E71 – No Display, Deep BIOS/EC Troubleshooting
          by macabook
          🧩 Initial Issue
          07-24-2025, 02:17 PM
        • TJ65
          Samsung Galaxy Tabpro S BIOS and Micom Version doesn't match
          by TJ65
          i made out of two broken Samsung Galaxy Tabpro S one that works partially.
          The one Mainboard had a broken screen output but working hdmi (usb c adapter) output and the other didnt start at all.
          I switch the bios chips and now the tablet starts but very very slow and it takes some trys to get it starting.
          The problem is, that the micom Version doesn't match with the bios version, see picture.
          How can i update the Micom Version? The Samsung bios update wont work.
          With https://github.com/tavinus/SamsungBIOSTools i could extract the newest bios update...
          01-09-2025, 01:35 PM
