Wine (Windows emulator for Linux) Thumbs Up!
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    #41
    Re: Wine (Windows emulator for Linux) Thumbs Up!
    Might as well put in my $.05. I had someone come to me with an encrypted /home/<user> dir... There was cryptowall 2 in the ./wine dir. He also had an old Windows hard drive over USB set as a virtual drive. It was encrypted. It can ascend into a dir, but not decend past the wineroot. It's essentially a chroot jail security wise from what I understand.
    Follow the white rabbit.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8711
      Watch out, as said, if you have mapped drives, it can touch each of these. Technically it's not a chroot but rather Wine will only know about any drives it has mapped. I think by default, the Z: drive is mapped to your home directory, and I'm sure cryptolocker would have fun with that.
      You could unmap Z: but I would imagine people have mapped drives for convenience, but in this case it would be a curse.
        • 31293
        Originally posted by Spork Schivago
        another possibility is Wine crashed but didn't terminate all the child processes associated with Wine and just kept running in the background.
        that i have had, but it usually leaves the wine window open.
        • SteveNielsen
          Retired Tech
          • 2327
          I don't think drive mapping vs UNC is relevant, as long as the FS privileges are there the location is accessible.
          • goontron
            5000!
            • Dec 2011
            • 4108
            • US
            #45
            That's filesystem dependant.
            • Spork Schivago
              • Mar 2012
              • 4734
              • United States of America
              #46
              I'll fire up my Linux system in a few days. Haven't had it running for a while now. I've been busy working on various stuff on this Windows machine of my wife's. I'll run some tests. First, I'll see if Wine is running in the background. It shouldn't be. Then I'll start a Windows executable and then exit. Then I'll check to see if Wine is still running.
              -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
              • SteveNielsen
                Retired Tech
                • 2327
                As far as I know there are no current file-systems in use that do not support common network/drive/directory/path naming conventions or the equivalent, and certainly not any that are supported by Linux, therefore in regard to Wine it is irrelevant. All that is necessary for any file operations is appropriate file rights.
                  • 31293
                  i'm not so sure,
                  if i open a file browser in wine/win and browse outside of the defined "drives" i can see the file, but it wont load - i get an error message.
                    • 31293
                    gives me an idea, i wonder if wine can run/fool malware-bytes etc
                    • goontron
                      5000!
                      • Dec 2011
                      • 4108
                      • US
                      #50
                      I was thinking farther along the lines of missing Unix permission capabilities....
