What's enhanced DPI with Laser printers?
  • Spork Schivago
    • Mar 2012
    • 4734
    • United States of America
    #41
    Re: What's enhanced DPI with Laser printers?
    Originally posted by stj
    i would have taken that to the petrol station and tried to blow it out with the air line.
    It was a nightmare man! Got toner all over my hands just moving it to my office. Ended up putting it in a plastic bag and just leaving it on the shelf. The same guy was trying to get into the IT department. My boss at the time (girlfriend of the company's owner), she was great and real nice, she gave him a job, doing tape backups. We lost the RAID array on one of the servers, the main server. We called it the Terabox because it had a terabyte worth of 50GB (or so) hard drives in it. They got some error message about something becoming corrupt and it wouldn't turn on. We tried various things but at one point in time, someone made the call to grab the tape backups and restore a bunch of stuff so the other companies we worked with had access to their stuff while we were trying to fix it. We went to the tapes, every single one empty. We call the guy to find out why there were no tape backups. He said the drive just started giving some error message, asking something about formatting, and he just hit yes, instead of telling anyone. That was terrible! Everyone was freaking out. I ended up fixing the problem though. The ext3 filesystem just lost the journal and all I had to do was mount it as ext2 to access the data, then I was able to just to recreate the journal. I ended up getting a promotion, an award and the only money bonus ever handed out in the whole entirety of the business because of that! Still got the picture of me accepting the award some wheres.
    -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
      • 31087
      Originally posted by Spork Schivago
      I see the one we have is listed as being Linux compatible and it's wireless. I wonder how true this actually is.
      you should download the manual.
      the one i have says that you cant scan over ethernet either, only usb.
      not sure if that's a driver problem or just that there is no standard for scanning over networks.
      • diif
        • Feb 2014
        • 6978
        • England
        #43
        Not sure if you're joking or for real ?
          • 31087
          for real, i use air-lines for all kinds of cleaning.
          it's not like there is anything to lose trying.
          • Spork Schivago
            • Mar 2012
            • 4734
            #45
            Okay. Will do. I mean it's not a big deal if I can't. It'd just be nice. Not too much native Linux support for printers and stuff. And by that, I mean companies that actually support Linux. I know there's a lot of Linux support out there, ie, open source drivers, etc, that the community has created.
            I contacted Linksys about one of their print servers, hoping they'd release the source code so I could make it Linux compatible. They said they outsourced for some of the source code to China and don't have permission to release it. I thought that was too bad. Maybe when I get smarter, I can tear apart the print server, see what type of chip is on there and try dumping the contents. Then I can try figuring out the format or whatnot and work on creating an open-source version. That'd be great. Kinda like what they do with the OpenWRT stuff.
            • Spork Schivago
              • Mar 2012
              • 4734
              #46
              It's probably dangerous if you breath that toner stuff in, isn't it? You'd probably have to use some sort of breathing apparatus so you don't accidently get any in your lungs. Might not be good for the environment either though.
              • diif
                • Feb 2014
                • 6978
                • England
                #47
                Teeth maybe ? would make my day pissing off a pikey lol
                Ok, so the crazy side of me says, "yeah, blow it away from you it would be cool and fun and it's not my garage or clothes or car it might go on, right ?".
                The sensible side says "its not worth pissing people off just to prove how much of a mess you know laser toner and their "empty" cartridges can be"
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  #48
                  Like any dust you don't want to breathe it in, but the EPA don't describe it as either a carcinogen or a mutagen.
                  • Spork Schivago
                    • Mar 2012
                    • 4734
                    #49
                    I know what a carcinogen is, but what's a mutagen? Sounds like the stuff the TMNT's got into when they were just normal turtles! Probably something real bad though, right? Like something that mutates your cells at a molecular level or something.
                    • keeney123
                      Lauren
                      • Sep 2014
                      • 2536
                      You know that usually compressor lines have oil in them to lubricate the air power tools being used? I would use a vacuum to suck up the majority of it and then put a partial mask on and take it outside and use compressed clean air in a can to plow out the remainder.
                        • 31087
                        the airline for tyre inflation is outside, and not lube-injected.
                        your just blowing toner across the tarmac.
                          • 31087
                          brother drivers
                          http://support.brother.com/g/b/downl...s_eu_as&os=127
                          btw, put the bitch online via ethernet and it will do a standalone firmware update
                          • diif
                            • Feb 2014
                            • 6978
                            • England
                            #53
                            From Wikipedia. "In genetics, a mutagen is a physical or chemical agent that changes the genetic material, usually DNA, of an organism and thus increases the frequency of mutations above the natural background level. As many mutations can cause cancer, mutagens are therefore also likely to be carcinogens."
                            • Spork Schivago
                              • Mar 2012
                              • 4734
                              #54
                              Wow, and we have chemicals that can actually change DNA? That's insane!
                                • 31087
                                milliwave scanners at the airport will rip your DNA appart,
                                microwave energy can damage your DNA if you spend all your time sitting next to a router or under a fone-tower.
                                just apply common sense.
                                • Spork Schivago
                                  • Mar 2012
                                  • 4734
                                  #56
                                  I didn't know routers used microwaves. Are you sure about that? I don't know what milliwave scanners are. Are they those new TSA scanners at the airport? Wife and I had to go through them once. It was that, or we had to let them feel us up a little bit while they searched us for weapons and everything.
                                    • 31087
                                    gigahertz band.
                                    2.4Ghz to be precise.
                                    and yes, milliwave scanners are the "RapiScan" booths sold by rabbi chertof's company to homeland security - while he was in charge of it!!
                                    dont worry, they tested them on palastinians for several years and none of them died from cancer.
                                    just bullets and bomb-shrapnel!!
                                    /flame away/
                                    • Compgeke
                                      • Feb 2014
                                      • 524
                                      Don't use a vacuum or air compressor on toner, if a spark ignites it it'll start a fairly nice fire. Here's a youtube video on how fast it burns: https://www.youtube.com/watch?v=fMnTloEr-kQ
                                      Cold water and paper towels is the way to go. Sure, it takes a bit longer but it's better than either making a huge mess by blowing it or starting a fire from static electricity. Xerox mentions this in one of their MSDS sheets, stating to use a vacuum with a conductive hose and fully sealed motor.
                                      Just a heads up though, the odds of dumping toner on a printer like a brother is very unlikely, unless you do something stupid like smash a cart with a hammer. It usually only happens in printers that take loose toner (like screw in a bottle or pour a bottle in) or when a waste drum overfills on printers without a cutoff.
                                      Both HP and Brother list their toner as being carcinogenic in the MSDS for their toner.
                                      Links:
                                      • diif
                                        • Feb 2014
                                        • 6978
                                        • England
                                        #59
                                        Links:
                                        That's listing carbon Black as a possible carcinogen. Laser toner is a combination of things and the data sheet even mentions it's not carcinogenic in this form.
                                        Your Brother link isn't working.
                                        • SONY_E-WASTER
                                          KONICA MINLTA C250P (laser) all prints have unwanted vertical CMYK lines
                                          by SONY_E-WASTER
                                          Hello I'm a rookie tinkerer hopping to find some knowledge about these big color laser printers and copiers.
                                          The specific model I would like to fix.
                                          KONICA MINOLTA C250P this is the printer only version of the full office photo copier. I have a one of the full office copier version for part too (that one gives an error for the yellow laser).
                                          https://photos.app.goo.gl/cwVu2KYB6Yva5Ais6
                                          I'm adding a link above to a picture of print out form the C250P with visible vertical lines of CYAN YELLOW and MAGENTA mostly on the right side of the 11x17 print....
                                          02-03-2022, 08:02 PM
                                        • Dannyx
                                          Hilti PD30 Laser Range meter Error 276
                                          by Dannyx
                                          Good day folks.....wow, seems like forever since I posted anything here Still alive and well, thank you I guess you could say I've become more independent and able to work stuff out on my own. This one though goes way over my head and I doubt is fixable, but maybe some bright spark out there has an equally bright idea.
                                          So: my Hilti PD30 laser meter quit on me just the other day. It was working fine, I set it down for a while and when I tried using it again it gave me an E276 and wouldn't do anything else. I tried taking out the batteries, all that standard stuff but nothing...
                                          07-30-2023, 05:05 AM
                                        • dansity
                                          Power DeWalt 12V laser measure from power supply
                                          by dansity
                                          i got a Dewalt laser measure which uses the 12V batteries to operate. The laser measure is faulty and I want to attempt a repair, never fixed such thing before. You might see a different topic if I fail with the repair
                                          However I do not have dewalt batteries nor want to buy one for 140EUR as the laser tool might have some chance that it is very hard to repair or unrepairable.
                                          I want to power it from my PSU.
                                          The tool has 3 input pins, on the battery it is marked with B-, B+ and ID/TH.
                                          i want to know what is the third pin exactly and what do I need...
                                          10-29-2023, 03:04 AM
                                          I would like an explanation of how a laser can measure a product on a conveyor belt
                                          by sam_sam_sam
                                          I saw this on
                                          “How do they do it “
                                          The laser was measuring the diameter and the height of the product and the weight of the product and it was a straight line laser light across the the conveyor belt ( this is all that was shown in the video clip of the laser that was used )
                                          What type of product is this that can do this
                                          I want to thank anyone that knows what of laser this is
                                          04-24-2022, 07:55 AM
                                          Modifying a Engraving Laser Module with out a TTL Module
                                          by sam_sam_sam
                                          I bought this laser module a few years ago and did not do anything with because I did not have a TTL module so it sat in project box to do something with at a later date
                                          Well the later date has happened now
                                          What I did to this module is disconnected the cooling fan and going to use with a fan temperature speed controller ( out of a surplus computer switching power supply )
                                          Well now I have found a 15 watt TTL module that I just bought from AliExpress which I should have in a few weeks
                                          Some time later when I have learned to use a laser engraver...
                                          07-25-2020, 02:26 PM
