KONICA MINLTA C250P (laser) all prints have unwanted vertical CMYK lines
  • SONY_E-WASTER
    • May 2021
    • 8
    Hello I'm a rookie tinkerer hopping to find some knowledge about these big color laser printers and copiers.
    The specific model I would like to fix.
    KONICA MINOLTA C250P this is the printer only version of the full office photo copier. I have a one of the full office copier version for part too (that one gives an error for the yellow laser).
    https://photos.app.goo.gl/cwVu2KYB6Yva5Ais6
    I'm adding a link above to a picture of print out form the C250P with visible vertical lines of CYAN YELLOW and MAGENTA mostly on the right side of the 11x17 print.
    I have very little experience with laser copy machines/ printers but I did take a look at the basics, like the long stick with felt at the end to clean the laser window, and the sticks you pull in and out of the image drums to clean them.
    I took a look at the transfer belt and it did not look damaged and the same lines were on the transfer belt along with the image.
    I have NEW in the box original konica minolta image drums and toner. I suspect the image drums might be the problem, likely the wiper blade in the roller maybe has a split or many splits? on each different color allowing a lines of toner to remain in the image roller after it has been wiped.
    I'm unsure about how to proceed also because the is a mess of color toner everywhere where the toner cartridges and image drums go. I imagine that's from regular use or from the printer being moved over the years. I haven't tried to clean it out with knowing how to do it.
    I'll patiently wait for advice on how to proceed from more knowledgeable users. Any help will be greatly appreciated.
  • SONY_E-WASTER
    • May 2021
    • 8
    Re: KONICA MINLTA C250P (laser) all prints have unwanted vertical CMYK lines
    I've*been doing more test prints and the various PURE cyan magenta and yellow vertical lines seem to be random not appearing in the same place and interestingly cover the entire length of the paper, while some faint (mixed with subject color) lines only appear where there is an image. So I no longer think it's a wiping blade issue on the image drums.
    • Mckenziex1
      • Apr 2023
      • South Africa
      • Technology Knowledge
      Hi Drum unit may be scratched or the charge rollers could be damaged. have you checked the cleaning blade on the IT belt perhaps?
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
      • Stanley1843
        Screen Display Vertical Multicolor Lines
        by Stanley1843
        Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
        06-29-2024, 11:54 AM
      • jmartins
        LG 55UC970V-ZA: vertical bands/lines appear after ~2 seconds, then clear, repeating
        by jmartins
        I have an LG 55UC970V-ZA (around 10 years old). The picture is normal right after power-on, but after ~2 seconds vertical bands/lines appear across the screen. Then it clears again, and the issue repeats in a cycle (roughly every 2 seconds).
        Symptom (repeatable):
        - After power-on, the picture is normal for about ~2 seconds.
        - Then vertical bands/lines appear across much of the screen.
        - It happens on everything, including the LG boot logo and the TV’s own menus/OSD, built-in apps, and all HDMI inputs.
        - Power-cycling (unplugged...
        01-10-2026, 07:58 PM
      • jeyoung12
        Samsung QN50Q60t lines on screen
        by jeyoung12
        Hi all
        I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
        My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
        This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
        It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
        So....i don't know what end of the C ribbon to work with...
        02-26-2024, 10:38 AM
      • pni
        LG 49uf695v vertical coloured lines
        by pni
        Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
        11-14-2025, 03:15 AM
