Toner counter reset for Samsung M2825ND
  • steamboat
    • Oct 2025
    • VietNam
    Hi there, I was hoping I could find the firmware to reset the toner counter of
    Model: Samsung M2825ND
    Serial number: ZD4EB8GF3B0033P
    Firmware version: V3.00.01.20
    Toner CRUM serial: CRUM-14030352356
    Thank you for your time!
    09-07-2024, 05:50 AM
  • GeckoGreen
    Samsung service bulletin: need firmware file for PN63C550 TV
    by GeckoGreen
    I'm hoping someone with access to the Samsung GSPN can help me. I need someone with access to download a firmware file for my PN63C550 TV, as it will fix a problem per the Samsung service bulletin.
    You can reference Samsung bulletin #:ASC20130528001 and I need the [2D63]LOGIC.bin file please.
    The full service bulletin is linked here: https://www.avsforum.com/attachments...3-pdf.1080602/
    Will you please help me get the [2D63]LOGIC.bin file for my TV?
    05-17-2025, 02:47 PM
  • sikocan
    NP930XED Samsung Galaxy Book2 Pro Laptop PD Firmware Loop
    by sikocan
    I hope this message finds you well. I wanted to share a recent experience I had with a laptop that had a Type-C Port issue, specifically related to a PD (Power Delivery) controller problem. After replacing the damaged PD controller chip with a new one I purchased from AliExpress, the laptop now charges properly and negotiates power as expected, allowing the device to power up. I've replaced this chip twice just in case.
    However, it seems that the laptop's BIOS is detecting an older version of the PD Firmware on the newly installed chip. As a result, it attempts...
    01-11-2024, 01:47 AM
  • Mirenia
    Samsung UEMU6199U - no Standby - bad Firmware?
    by Mirenia
    I've got a Samsung UEMU6199U which has no Standby LED and no reaction if try turning it on.
    Voltages on the power supply board is okay. Backlight test is also okay.
    I read about a corrupt firmware on IC1604 on some models, did a dump of this IC and turns out: First sectors are empty.
    So I think my TV has exactly this issue.
    Can someone please fix the dump?
    And how do you do that?
    As I understand you fill in the empty sectors and leave the rest as it is. But where do you get the "information" of what you...
    05-12-2025, 06:13 AM
    09-06-2024, 11:40 PM
