Change old low HDD to a CF card?
  • fzabkar
    • Mar 2009
    • 772
    Re: Change old low HDD to a CF card?
    Windows has no problems with multiple partitions on removable mass storage devices. I don't know why Mini Tool Partition Wizard Pro is telling you otherwise. In fact your observation that the 4GB "partition is NOT compatible with WinXP" doesn't make any sense at all.
    Can you show us the contents of sector 0 with a disc editor? That's where the partition table lives.
    I recommend DMDE (freeware):
    http://dmde.com/
    The "DeLock 91620 PATA to CF adapter" appears to be a passive, pass-through device that converts the pinouts, while the 3.3V LDO regulator just selects the supply voltage. Apparently the IDE interface is 5V tolerant, but I would still have chosen a 5V supply. That said, I can't see why this adapter would cause the drive to be detected as removable storage.
    Can you show us the CF card's Identify Device information? You could use a tool such as CrystalDiskInfo for this. This might tell us if the card looks any different than a regular HDD.
    • RJARRRPCGP
      • Jul 2004
      • 6304
      The DRM thing is a bunch of hooey! Otherwise, we wouldn't be able to install 7 and 8 from an SD card!
      The DRM reason statement reminds me of the pre-Vista-RTM DRM doomsday alarmists back in 2006 and probably shortly before that time, where the doomsday'ers claim that Microsoft was going to insert DRM so oppressive that you couldn't take screenshots anymore or backup Windows anymore!
      Back when or around the time that DRM doomsday'ers also claimed the TPM chip was going to eliminate fair use.
      That was back in the Internet Explorer 6 era!
      Now, we all know that the DRM talk were just monster rumors!
      The only thing new I see in the PC department right now that's not a rumor, is that Intel killed USB 2.0 support in Skylake! You're required to have a USB 3x driver on your Windows 7 USB device, to install Windows 7 from a USB device!
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
      • ChaosLegionnaire
        HC Overclocker
        • Jul 2012
        • 3266
        • Singapore
        there is an article on a mac website that talks about the lowdown on using cf to replace an ide drive.
        also, regarding overclocking, have u tried running the fsb and pci bus at stock speeds to see if it fixes the problems u were having? i'm an overclocker myself and being "stable" does not necessarily mean it is 100% "error-free" or "glitch/problem free"...
        the adaptor and/or the cf card may not like the overclocked pci bus. if it works fine with a hard drive, it does not mean that it will work fine with a cf card. in fact the faster the device, the more fussy it might be about an overclocked bus...
        • fzabkar
          • Mar 2009
          • 772
          I found the following article which explains how to use Linux to create a bootable Win XP environment on a CF drive:
          How to make any Compact Flash card or Microdrive boot Windows XP:
          http://www.instructables.com/id/How-...-Microdrive-b/
          As for why Windows sees the drive as removable, I consulted the ATA standard:
          The standard specifies that a true ATA HDD should clear bit #15 in word #0 of the 512-byte Identify Device information block. However, a CFA device sets this bit and reports 848Ah for word #0. A CFA device also sets bit #2 of word #83 to indicate that it supports the CFA feature set.
          These are the CFA ATA commands:
          a) CFA REQUEST EXTENDED ERROR CODE
          b) CFA WRITE SECTORS WITHOUT ERASE
          c) CFA ERASE SECTORS
          d) CFA WRITE MULTIPLE WITHOUT ERASE
          e) CFA TRANSLATE SECTOR
          f) SET FEATURES Enable/Disable 8-bit transfer
          In short ISTM that Windows XP can quite happily work with a CF card, even one that has multiple partitions, but cannot install itself on one.
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            Originally posted by trodas
            However, now to bad news. The CF card is completely useless, unless someone tell me how to change the removable bit to fixed. Period. You cannot use the CF card for anything w/o that.
            I'm quite mad at SanDisk - they should rename themselves as ScamDisk, because they are selling not CF cards, but CF compatible *) cards, with the *) exception for the possibility to change removable to fixed bit. I believe, that there is open possibility to lawsuit against SanDisk and any other CF card producing company, that produces products, that does not meet the CF card specifications. Because this is false advertising and misleading labeling of product. This is not a CF card, period.
            This is quite interesting because I realized something about a Sandisk Extreme USB 3.0 16GB stick I have.
            I bought it two years ago I think when Sandisk had the interesting idea of selling their USB sticks not as removable devices but as fixed disk devices.
            The problem with this is that even with the device set to "quick removal" in device manager in 9/10 cases you will get a Windows warning when trying to do a safe removal:
            And I have even enabled "Do not allow locations on removable drives to be added to libraries" in the local group policy under Computer Configuration -> Administrative Templates -> Windows Components -> Search
            But of course that only applies to removable devices and not fixed devices!
            So of course Windows manages to make the safe removal impossible:
            • fzabkar
              • Mar 2009
              • 772
              ISTM that the term "removable" is ambiguous in that it can describe numerous dissimilar storage devices. A removable CF card is not the same thing as a removable USB mass storage device.
              The ATA/ATAPI standard describes two types of devices, ATA and ATAPI. ATA devices are things such as HDDs and SSDs whereas ATAPI devices are optical drives, magnetic tapes and the like. ATA devices use ATA commands whereas ATAPI devices use SCSI commands which are encapsulated within an ATA PACKET command.
              In the case of ATAPI devices, the "removable bit" is bit #15 (and #14) of word #0 of the Identify Device information block. An ATA device clears this bit whereas an ATAPI device sets it. AFAICT, the problem is that a CF card uses ATA commands (with CFA extensions), but identifies itself as an ATAPI device.
              IIUC SanDisk has an ATCFWCHG tool that attempts to modify this Identify Device bit in the card's firmware. However, I suspect that this tool may not be universal, ie it may be restricted to "Athens" flash controllers.
              Years ago I modified the firmware in a Ricoh 2x CD burner. This ATAPI device was limited to PIO modes but its stablemate supported DMA. This made me wonder whether the firmware had been crippled to create artificial performance classes.
              I downloaded an official firmware update for my model, located the Identify Device / Identify Packet Device data block within the firmware image, flipped the DMA bits, recalculated the checksum, and flashed the modified file to the drive. The result was a marginal but consistent performance improvement, and the DMA box remained checked in Windows Device Manager.
              I suspect that a similar approach could work for the SanDisk CF card, although finding a firmware update might prove to be difficult, if not impossible.
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                • Romania
                #27
                I have a Compaq Evo N410c laptop running XP from a 16GB Transcend CF card. It's been running like that for over an year now.
                I used the Hitachi Microdrive Filter driver to get XP to install and boot off it. No firmware modifications or any of that. Or you can use GRUB to boot windows; the code that checks for the removable bit is in the bootloader, so by using GRUB you can bypass that.
                A working TV? How boring!
                • Per Hansson
                  • Jul 2005
                  • 5895
                  • Sweden
                  #28
                  fzabkar: Yea I know, I just thought it was kind of ironic:
                  Sandisk sells USB sticks set to fixed disk
                  And CF cards set as removable
                  Really logical
                  • trodas
                    • Jan 2006
                    • 770
                    • Czech republic
                    #29
                    goontron -
                    That my friend is a Windows problem.
                    Sure. OS should not care that much, if being installed on removable or fixed device. But since Win is very aggressvive on HDD usage, I can see why M$ decided that it is a good thing to use only not removable devices. Some swapping commands probably cannot be checking, if the HDD is "still there."
                    This is a DRM implementation to go along with the Windows antipiracy crap. Linux, DOS, Unix, Solaris, BSD, OSX, Android all work from removable media. So will Windows CE/Mobile/RT It's the rest of the versions that shit themselves.
                    I believe you are misinformed. DRM is all about pirating movies and music, not Windows. M$ is all about dominating the market, even if they have the handout Win for free. See the Win10 handing out... and aggressively pushing thru updates to get more and more computers infec... I mean installed.
                    fzabkar -
                    Simply not true. Just burn yourself CD with more sessions and show me, how Winblows see them all
                    Yes, Amiga OS or MacOC (never tried that in Linux) can do it. But not and never ever Winblows. They mount only one partition per removable device. I tried that, even I know it will not work and it again not worked.
                    Case closed.
                    Because it is the truth
                    I never made such "observation" and I agree that it does not make sense at all. I usually go for 4 or 8G for system partition (FAT32) and then NTFS for the rest of the drive (data).
                    So from my experience it works well that way.
                    I posted the data from HDAT2 program and I repeat them there. Enought, I hope?
                    I recommend DMDE (freeware): http://dmde.com/
                    When neeed, I give it a try.
                    And it does not. I never claim that, BTW. All I claim is, that the cursed card, as confirmed by SanDisk, is identifing itself as removable device. That I want desperately to change!
                    This wasalready answered, but once again: On the HDDguru forum I made a post (21/9/2015, 10:18) that clearly stated after your quoted request:
                    You can see the card's Identify Device data with a tool such as CrystalDiskInfo.
                    Sorry, nope. Next tool. This one did not let me choose the device:
                    As you can see, CrystalDiskInfo let me look only the fixed drives, NOT on the removable ones. As you can see on the screenshot, there is that 320G Seagate, the 32G CF card and 4G USB Voyager. Only the Seagate I can select, as you see in the menu.
                    Another fail for the removable device.
                    "It is dangerous to be right in matters on which the established authorities are wrong." - Voltaire
                    "I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway my config - my caps
                    • trodas
                      • Jan 2006
                      • 770
                      • Czech republic
                      #30
                      I run the HDAT2 in DOS and I get these infos:
                      HDATCOPY.TXT
                      [code]********************************************************************************
                      HDAT2 v5.0 (c) 2013 CBL 24.09.2015 17:43:41
                      Device information [SDCFXPS-032G]
                      Source Cylinders Heads Sectors Total sectors Size
                      ATA LBA28 62041 16 63 62537328 32.02 GB
                      CHS 62041 16 63 62537328 32.02 GB
                      INT13h/BIOS 1024 255 63 16450560 8.42 GB
                      Ext.INT13h 3892 255 63 0 0.00 KB
                      (* = invalid parameters)
                      Device model [ATA/SSD] SDCFXPS-032G
                      Manufacturer unknown
                      Orphan (not useable) sectors 62537328 [32.02 GB]
                      Translation/max. LBA mode ?/28-bits
                      Logical sector size [B] 512
                      Physical sector size [B] 512
                      Detect mode PCI
                      ATA I/O port Base/Control/IRQ 0170h/0376h/15
                      ATA/ATAPI Identify Device
                      Integrity word (optional)
                      -> Signature: failed [reported 00h, should be A5h]
                      -> Checksum : failed [reported 00h, should be 30h]
                      ATA major version 0000h
                      -> not reported
                      ATA minor version 0000h
                      -> not reported
                      Transfer mode: max. supported Ultra DMA 7/ATA166
                      Transfer mode: selected Ultra DMA 2/ATA33
                      Serial number OAZ071115134539
                      Firmware HDX9.03
                      Cache 1.02 KB
                      -> Cache type: dual port
                      General Configuration 848Ah = 1000010010001010b
                      -> Removable device
                      -> Protocol type: ATAPI
                      -> Device supports the CFA feature set
                      Specific Configuration 0000h
                      Maximum queue depth 1
                      Hardware Reset result 604Fh = 0110000001001111b
                      -> Device detected CBLID- above V[iH]
                      -> Device 0 Hardware Reset result 01001111b
                      -> device determined by: other method
                      -> diagnostics passed
                      -> did not detect the assertion of PDIAG-
                      -> did not detect the assertion of DASP-
                      -> responds when Device 1 is selected
                      Detected an 80-conductor cable YES
                      Multiword DMA transfer cycle time per word [ns]
                      -> Minimum: 120
                      -> Manufacturer's recommended: 120
                      Minimum PIO transfer cycle time [ns]
                      -> without IORDY flow control: 120
                      -> with IORDY flow control: 120
                      Security Status [vendor specific] 0000h = 0000000000000000b
                      Master Password Identifier (Revision Code) 0000h
                      -> Master Password Identifier feature is not supported
                      Time for Normal security erase unit not specified
                      Time for Enhanced security erase unit not specified
                      Extended number of user addressable sectors reserved
                      Capabilities
                      -> DMA supported
                      -> LBA supported
                      -> IORDY may be disabled
                      -> IORDY supported
                      -> Standby timer values shall be vendor specific
                      -> [14] shall be set to one
                      Command/Feature Sets supported ENABLED
                      Power Management feature set NO
                      Write cache YES
                      WRITE BUFFER command NO
                      READ BUFFER command NO
                      NOP command NO
                      Compact Flash (CFA) feature set NO
                      Advanced Power Management (APM) feature set NO
                      48-bit Address feature set YES
                      FLUSH CACHE command YES
                      FLUSH CACHE EXT command YES
                      Advanced Power Management (APM) level value 00h
                      Acoustic Management (AAM): vendors/current value 00h/00h
                      Read/Write LONG: ECC bytes 4
                      Read/Write MULTIPLE: sectors per DRQ data block
                      -> Maximum: 1
                      -> Current: 0
                      CFA power mode supported
                      -> Maximum current [mA]: 500
                      Free-fall Control Sensitivity not supported
                      Number of data blocks per DOWNLOAD MICROCODE mode 3 not supported
                      Transport Major revision number: support not reported
                      Transport Minor revision number not reported
                      SMART Command Transport (SCT) Command set not supported
                      Trusted Computing feature (TCG) not valid
                      Nominal media rotation rate [rpm] not reported
                      Device Nominal Form Factor not reported
                      DATA SET MANAGEMENT
                      -> The Trim function is not supported.
                      LBA Range Entry (DATA SET MANAGEMENT) [sectors] 0
                      Additional Product Identifier not supported
                      NV Cache
                      -> not supported
                      Extended INT13h
                      Extended INT13h support YES
                      Major/Vendor/Extension Version 2.1/0.0/0.0
                      -> EDD v1.1
                      Subset
                      -> Fixed disk access subset: YES
                      -> Device locking and ejecting subset: NO
                      -> Enhanced Disk Drive (EDD) subset: YES
                      -> 64-bit extension: NO
                      INT13h Identify Device support not detected
                      Device Parameter Table (DPT)
                      Information flags
                      -> The geometry returned in bytes 4-15 shall be valid
                      -> Bits 4-6 are not valid
                      Block size [B] 512
                      DPT Extension (DPTE) pointer F000h:A5D0h
                      Key to presence of Device Path (BEDDh) 0000h
                      Device Parameter Table Extension (DPTE)
                      Version 1.1 [11h]
                      Checksum
                      -> O.K. [reported DAh, should be DAh]
                      I/O Port base address 0170h
                      Control Port address 0376h
                      IRQ 15
                      Head register upper nibble
                      -> ATA DEV = Master
                      -> LBA enable = YES
                      BIOS Vendor specific 00h
                      ATA READ/WRITE MULTIPLE Block Count 1
                      DMA information 20h
                      -> DMA channel = 00h
                      -> DMA type = 02h
                      PIO information 04h
                      -> PIO type = 04h
                      BIOS selected HW specific option flags
                      -> Fast PIO access
                      -> Vendor specific translation
                      -> HPA Active
                      HDAT2 v5.0 (c) 2013 CBL 24.09.2015 17:44:11
                      • trodas
                        • Jan 2006
                        • 770
                        • Czech republic
                        #31
                        Dump IDENTIFY DEVICE [SDCFXPS-032G]
                        00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 0123456789ABCDEF
                        Ú--------------------------------------------------------------------ż
                        0000 ł 8A 84 59 F2 00 00 10 00 00 00 40 02 3F 00 BA 03 Š„Yň.....@?.ş ł
                        0001 ł 70 3E 00 00 20 20 20 20 4F 20 5A 41 37 30 31 31 p>.. O ZA7011 ł
                        0002 ł 35 31 33 31 35 34 39 33 02 00 02 00 04 00 44 48 51315493...DH ł
                        0003 ł 39 58 30 2E 00 33 44 53 46 43 50 58 2D 53 33 30 9X0..3DSFCPX-S30 ł
                        0004 ł 47 32 20 20 20 20 20 20 20 20 20 20 20 20 20 20 G2 ł
                        0005 ł 20 20 20 20 20 20 20 20 20 20 20 20 20 20 01 80 € ł
                        0006 ł 00 00 00 0F 00 00 00 02 00 00 07 00 59 F2 10 00 .........Yň. ł
                        0007 ł 3F 00 70 3E BA 03 00 01 70 3E BA 03 00 00 07 00 ?.p>ş.p>ş... ł
                        0008 ł 03 00 78 00 78 00 78 00 78 00 00 00 00 00 00 00 .x.x.x.x....... ł
                        0009 ł 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ł
                        000A ł 00 00 00 00 28 70 0C 74 00 40 20 00 00 34 00 00 ....(p t.@ ..4.. ł
                        000B ł FF 04 00 00 00 00 00 00 00 00 4F 60 00 00 00 00 ˙........O`.... ł
                        000C ł 00 00 00 00 00 00 00 00 70 3E BA 03 00 00 00 00 ........p>ş.... ł
                        000D ł 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ł
                        000E ł 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ł
                        000F ł 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ł
                        0010 ł 00 00 46 43 00 00 00 00 00 00 00 00 00 00 00 00 ..FC............ ł
                        0011 ł 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ł
                        0012 ł 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ł
                        0013 ł 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ł
                        0014 ł F4 81 00 00 00 00 12 00 00 00 00 00 00 00 02 60 ô...........` ł
                        0015 ł 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ł
                        0016 ł 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ł
                        0017 ł 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ł
                        0018 ł 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ł
                        0019 ł 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ł
                        001A ł 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ł
                        001B ł 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ł
                        001C ł 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ł
                        001D ł 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ł
                        001E ł 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ł
                        001F ł 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ł
                        Ŕ--------------------------------------------------------------------Ů
                        [/code]
                        HDETECT.TXT
                        Code:
                        HDAT2 v5.0 (c) 2013 CBL 24.09.2015 17:48:33
                        Options:
                        DASD devices detect:
                        HDD: 2/2/2
                        FDD: 1/1
                        CMOS check:
                        CMOS battery power   : 80h -> O.K.
                        POST diagnostics status: 00h -> O.K.
                        Shutdown/Reset status : 00h
                          -> Power-on or Soft reset
                        Floppy drive detect:
                        CMOS: 1 floppy drive(s)
                        BIOS: 1 floppy drive(s)
                        1. Floppy drive: 3« 1.44 MB
                        Checked 1 floppy drive(s)
                        PCI scan:
                        Bus= 0, Device= 7, Function=1
                        1. BaseClass: Storage, SubClass: IDE
                        BaseClass = 01h, SubClass = 01h, Programming interface = 8Ah
                        Bus = 0, Device = 7, Function = 1, Header type = 00h
                        Host: Vendor ID = 1106h, Device ID = 0571h, Revision = 06h
                        Host vendor name: VIA Technologies Inc
                        Subsystem: Vendor ID = 0000h, Device ID = 0000h
                        Subsystem vendor name: unknown
                        Address 4: I/O port = E000h-E00Fh
                        Primary  channel: I/O Port 01F0h, IRQ 14 (compatibility mode)
                        Secondary channel: I/O Port 0170h, IRQ 15 (compatibility mode)
                        Bus Master: supported, primary: enabled, secondary: enabled
                        Bus Master Control Register: E000h
                        Built-In Self Test: not supported
                        PCI ATA devices:
                        [0/0 01F0h/03F6h/14] ST3320620A
                        [0/1 01F0h/03F6h/14] disabled or not present
                        [1/0 0170h/0376h/15] SDCFXPS-032G
                        [1/1 0170h/0376h/15] disabled or not present
                        Detect on-board ATA/ATAPI devices:
                        [2/0 01F0h/03F6h/14] already detected
                        [3/0 0170h/0376h/15] already detected
                        [4/0 01E8h/03EEh/0] disabled or not present
                        [4/1 01E8h/03EEh/0] disabled or not present
                        [5/0 0168h/036Eh/0] disabled or not present
                        [5/1 0168h/036Eh/0] disabled or not present
                        [6/0 0100h/0306h/0] disabled or not present
                        [6/1 0100h/0306h/0] disabled or not present
                        Detect ASPI devices:
                        ASPI not found
                        Detect BIOS INT13h devices:
                        BIOS number 80h: already detected
                        BIOS number 81h: already detected
                        Detect OS:
                        Detected OS DOS, version 7.10 Microsoft
                        DOS is in HMA
                        List of detected devices:
                         1. '3« 1.44 MB' [ATA/FDD] 00h
                         2. 'ST3320620A' [ATA/PATA] 80h
                         3. 'SDCFXPS-032G' [ATA/SSD] 81h
                        15134539.BIX
                        included
                        What does look interesting is the Firmware HDX9.03 line. Time to ask SanDisk, if the provide updates on their firmware, because that would give us the flash tool for flashing it...
                        • trodas
                          • Jan 2006
                          • 770
                          • Czech republic
                          #32
                          RJARRRPCGP -
                          Indeed. However it depedns on what SD card. I fear that the removable bit could be in play there as well... or maybe Win7/8 does not check on that anymore?
                          Yea, that sounded ridiculous, but maybe this and the fact, that Vista was downfall saved us all from DRM world or pain? Who knows
                          Back when or around the time that DRM doomsday'ers also claimed the TPM chip was going to eliminate fair use. That was back in the Internet Explorer 6 era! Now, we all know that the DRM talk were just monster rumors!
                          But afer few really annoing copy protection it made me switch from buying into pirating movies, so... it is not all rumors there. But that is OT in this thead a lot.
                          ChaosLegionnaire -
                          Neat article, but there is the important bit: "If your PowerBook supports CardBus, it is the way to go." It talks about Mac's. I need Windows and various versions and with two partitions and with WinNT 4.0 SP1 support.
                          No and I never will even try that, because the card is registering as removable device because of the epic fail in the firmware of the card. It have absolutely NOTHING to do with overclocking. Besides, on another two mainboards are either stock speed (MSI K7TM Pro), or the PCI bus is not overclocked a bit (ASRock 775Dual-VSTA), so there you have the answer. Of course it is no different on any of the computers. Period.
                          For me, it usually works the other way around. If old HDD cannot cope with 41.7MHz PCI bus, then I'm not surprised at all. But when CF card made it w/o problems - well, that is also expected
                          And yes, it is working well at such clocks. Recently, I tried the AMD K5-75 and it can go to only 60MHz FSB, so I was well within the limits of PCI clocks and it still won't work at all, because of the cursed damned removable bit.
                          Seems like that I need such hacking guys: http://flashboot.ru/
                          fzabkar -
                          Yes, that is known. However I need that it can itstall itself and I need that it support two partitions and also I need that WinNT 4.0 SP1 works fine there. So tricks with drivers does not interest me, because that will add another layer and for Pentium 1 that means slow-down. I need every bit of speed!
                          Per Hansson -
                          LOL ... Well, check http://flashboot.ru - these guys seems to know pretty well what to do and change of this bit should not be a problem for them. I think.
                          SanDisk seems love to do the oposite what users want/expect.
                          But of course that only applies to removable devices and not fixed devices! So of course Windows manages to make the safe removal impossible:
                          There is no words to describe this level of incompetence. While I would KILL for a fixed CF card from SanDisk, being stuck with the removable crap, you have a USB stick that is fixed and as almost everyone, you need it to be removable. ScamDisk!
                          However maybe I have solution for you!
                          I found myself two ways, ATM, that attempted to flip the removable / fixed bit on my SanDisk CF cards. I have own a oldie SanDisk 5V and 0.5GBy big CF card (SDCFH-512) too. The second tested card was the SanDIsk Extreme PRO 32G (SDCFXPS-032G) CF card.
                          1 - there is a program called BootIt v1.07, that offer the flipping between the removable and fixed devices:
                          http://www.getusb.info/flip-your-bit...e-local-drive/
                          It does promise that it will work (despite showing my 32G CF card as 18G) and it even claim to work:
                          ...but the device stays as removable. Both my CF cards cannot be changed. It should work good on USB drives... but it does not work on both mentioned CF cards.
                          2 - there is program called atcfwchg.com:
                          http://www.ehow.com/how_7811193_set-...ixed-mode.html
                          Again it claim to flip the removable bit to fixed on CF card, connected thru PATA to CF card adapter into a PATA interface. The usage is shell and it is simple:
                          atcfwchg /P /F
                          That should set the CF card, that reside on the primary IDE channel to fixed mode. In reality it output this error:
                          D:\>ATCFWCHG /P /F
                          NAND Athens ID Drive Config Word (Fixed/Removable) Change Utility Version 1.4.
                          Fail (error #20)
                          D:\>
                          So changing the "most important bit" on any CF card is not possible for these SanDisk cards, witch make them virtually useless for any PC usage, as for example, two partitions are not possible on removable device under Windows, while it is not a problem on fixed device...
                          There are also "solutions", like a diskmod-0.0.2.2, witch is basically a driver that trick Windows into treating all devices as fixed. Yet that is not going to help me to be able to install Windows on the CD card, therefore I cannot attest on it's functionality of quirks or bad things that happen, when you use it. I saw video of this driver working well on Win 8.1, but since the change is not permament ON THE DEVICE and it is just a Win patch, then it does not interest me one bit.
                          So far, I'm clueless. Hopefully the information I gather will help someone... On SanDisk forum this message I posted disappeared very quickly (under 20 min)... so, beware, users. SanDisk does not sell CF cards, but compatible CF cards with the exception that the most important change you are forbidden to do it and they will even actively seek and eradicate all informations regarding the topic...
                          • fzabkar
                            • Mar 2009
                            • 772
                            fzabkar -
                            Simply not true. Just burn yourself CD with more sessions and show me, how Winblows see them all .
                            ISTM that I've been having trouble understanding just what is "removable". After some research into the various standards, I've come to understand that it is not the device itself that is removable, as the nature of USB would suggest. Instead, the removable bit reflects the type of media. That's why Windows can see multiple partitions on a USB HDD (fixed media) but not on flash drives (removable media).
                            I've posted my findings here:
                            http://forum.hddguru.com/viewtopic.p...221916#p221916
                            What is clear is that a firmware based solution for USB mass storage devices would be inappropriate for ATA/ATAPI devices.
                              • 31204
                              it's down to the formatting, if you create a partition table on a usb stick you cant have as many as you want.
                              the problems are really just windows and how it (miss)handles stuff.
                              like refusing to format large drives in FAT32 even though old versions of windows or dos had no problems with it.
                              • ChaosLegionnaire
                                HC Overclocker
                                • Jul 2012
                                • 3266
                                • Singapore
                                #35
                                the non-formatting of >30GB drives as fat32 is an intentional behaviour by m$ on winxp and later versions of windows to force ppl into using ntfs for larger drives. which they claim ntfs is more efficient on but that claim is highly disputable and in doubt.
                                similarly, m$ also intentionally disabled the capability for folder defragmentation on fat32 in winxp and later. im guessing this is also to "cripple" fat32 so ppl will use ntfs instead. even though the win9x defragmenter can defrag fat32 folders just fine. this is the reason why i keep old hardware! for the win9x defragger that works so much better for me instead of the win nt defrag library which is kinda lame cuz they crippled it...
                                  • 31204
                                  i use this on xp machines - dont know what it will do with fat32 though.
                                  http://ultradefrag.sourceforge.net/en/index.html
                                  • Per Hansson
                                    • Jul 2005
                                    • 5895
                                    • Sweden
                                    #37
                                    I tried Lexar's BootIt in XP but it was not even able to see the Sandisk USB stick.
                                    That other program ATCFWCHG as you say seems to work only for CF cards.
                                    I also looked on the flashboot.ru site but it seems like the Sandisk is a lost soul, I've looked before and the only conclusion then was you would have to make an RMA...
                                    Take note for example that there exists "industrial" CF cards you can buy, they should always be set up as "fixed disk"
                                      • 31204
                                      why not try something NOT sandisk?
                                      i like to use Transcend CF cards when replacing harddrives.
                                      • fzabkar
                                        • Mar 2009
                                        • 772
                                        SanDisk's tool changes the Identify Device configuration word from 848Ah to 044Ah.
                                        Code:
                                        1283:16C1 BF0006    MOV	DI,0600             | if removable, then
                                        1283:16C4 833E280801  CMP	WORD PTR [0828],+01       | write 0x848A to 0x630
                                        1283:16C9 740A     JZ	16D5               |
                                        1283:16CB C6453084   MOV	BYTE PTR [DI+30],84       |
                                        1283:16CF C645318A   MOV	BYTE PTR [DI+31],8A       |
                                        1283:16D3 EB08     JMP	16DD               |
                                        1283:16D5 C6453004   MOV	BYTE PTR [DI+30],04       | else write 0x044A to 0x630
                                        1283:16D9 C645314A   MOV	BYTE PTR [DI+31],4A       |
                                        • Th3_uN1Qu3
                                          Believe in
                                          • Jul 2010
                                          • 6031
                                          • Romania
                                          #40
                                          I have used Transcend too with success (see my above post).
                                          • Christos Tsiligiannis
                                            Marian Trace Alpha sound card repair help
                                            by Christos Tsiligiannis
                                            Hello to the forum.
                                            My name is Christos, I am new to the forum here and i am posting from Greece.
                                            So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                                            To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                                            So i tried asking for a schematic from the company and they would not give me one. Instead they...
                                            11-18-2024, 05:26 AM
                                            HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook Specification for Upgrade or Repair
                                            This specification for the HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) boardview and 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon...
                                            09-06-2024, 08:30 AM
                                          • FZG
                                            EVGA Nu Audio Sound Card - Not Working
                                            by FZG
                                            I have an EVGA Nu Audio sound card that is not working properly and I need some help diagnosing the fault (preferably by someone who owns this card and is willing to take some measurements).
                                            The card sort of powers up (LED lights are coming on and the relais is clicking, some voltages are present) but it is not detected in Windows. I tried installing in two different PCs and tried several driver versions but the card was never detected anyway. So I thought this is probably not a driver / software-issue and then disassembled the card to take some measurements.
                                            I found...
                                            03-07-2025, 11:44 AM
                                          • benwaterson
                                            Gigabyte Aorus 1080ti - card not initialising
                                            by benwaterson
                                            Hi there.
                                            Have searched various forums but haven't come across the exact issue I am having.
                                            Bought the 1080ti with a fault (randomly shutting down, black screen , fans full speed etc). Previous owner had replaced thermal pads but many were too thick on inspection.
                                            I tested the card in windows, all loaded up ok. Put some load on the card and it crashed. GPU was reporting 92 degrees C at the time.
                                            Switched the stock cooler out for an AIO water cooler from my 1080 FE, booted the card back up - temps were much better and allowed some load to be applied...
                                            02-05-2022, 11:42 AM
                                            Postcard 32 4-Bit 4-Digit Diagnostic Card PC Analyzer Manual
                                            Diagnostic Card is a powerful diagnostic tool for technicians and administrators to troubleshoot
                                            various problems of IBM compatible PCs. It is easy to install, yet extremely powerful to use. With
                                            Diagnostic Card in hand, you no longer have to go through tedious and time consuming process of
                                            trying to figure out what is wrong with your PC hardware. Diagnostic Card will tell you exactly
                                            what is wrong with your PC in just seconds. It saves you time and money.
                                            Our new and improved design...
                                            11-01-2024, 06:29 AM
