Western Digital HDD firmware update
  • redwire
    • Dec 2010
    • 3912
    I need to update the firmware in a Western Digital black HDD WD1002.
    I scoured the WD website, support forums and can't find the utility software. WD seems to have deleted any references for firmware update procedure etc. ?
    Only found s/w for external Passport USB drives.
    Either I am stupid or WD has totally become a !@%^&!@Q corporation.
    • 31300
    Re: Western Digital HDD firmware update
    both.
    because you should have emailed custommer support and asked.
    • redwire
      • Dec 2010
      • 3912
      I contacted Western Digital phone support, and they no longer offer firmware updates or the firmware update utility for any of their internal hard drive products.
      Bad bugs, like the auto-parking in Red and Green drives have a dedicated .exe utility that you can use.
      • c_hegge
        • Sep 2009
        • 5219
        Why do you need to update the firmware? AFAIK, WD Blacks have never had problems with buggy firmware.
        • redwire
          • Dec 2010
          • 3912
          It looks like most WD HDD bugs are in the firmware settings on their HDD's. Figured it was best to update the f/w but you cannot do that...
          I have a WD1002FAEX 1TB HDD that works fine on an older SATAII M/B but on a newer SATAIII M/B, I keep getting system errors in Win7, only on boot-up and after waking from sleep:
          The driver detected a controller error on \Device\Ide\IdePort5. Event ID 11 ATAPI and it hangs a while.
          Western Digital Data LifeGuard and SMART report shows no evidence of any problem. The drive works fine otherwise.
          There's mention of a firmware settings mistake on some WD drives: http://www.sevenforums.com/performan...andomly-6.html
          I'm still looking for utility wdspd.exe to fix.
          Utility wdidle3.exe is a fix for the head autopark bug on the greens and reds that wears out the drives.
          You can't find these on WD's website, they don't even mention their problems or fixes anymore
          • Agent24
            I see dead caps
            • Oct 2007
            • 5095
            • New Zealand
            Have you tried upgrading (or downgrading) your SATA\AHCI\RAID drivers in Windows?
            I have had weird things with my SATA drives disappearing after resume from standby on my MSI 760GX-based board after the Radeon video driver package upgraded my AHCI drivers from the MSI specific ones to the generic AMD ones.
            I had to rollback to the ones from MSI at that point, although since then, the latest AHCI drivers from AMD since last year or so have worked fine.
            -David VanHorn
            • TheUser
              Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
              by TheUser
              Hello to everyone ,
              This is my first post here, and i would like to share with you a small story in case you can help me.
              Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
              All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
              I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
              02-10-2024, 02:07 PM
            • rumpumpel1
              ThinkPad X12 Detachable Gen 1: keyboard after firmware update without function
              by rumpumpel1
              Lenovo System Update offered me an update for the firmware of the Folio keyboard for my X12 Detachable Gen 1. The update got stuck and after 20 minutes I switched off the laptop. Since then, the keyboard and touchpad have been without function. Does anyone know how I can revive it?
              10-24-2024, 08:59 AM
            • dkneyle
              Sony KDL-46HX850 Can't upgrade/update firmware
              by dkneyle
              Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
              Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
              09-25-2024, 10:44 PM
            • piernov
              Infineon TPM firmware update files
              by piernov
              Infineon TPM firmware update files:
              Infineon_firmware_update.zip
              Code:
              TPM12_4.32.879.0_to_TPM12_4.34.1010.2.BIN
              TPM12_4.33.949.0_to_TPM12_4.34.1010.2.BIN
              TPM12_4.40.119.0_to_TPM12_4.43.257.0.BIN
              TPM12_4.40.119.0_to_TPM12_4.43.258.0.BIN
              TPM12_4.40.119.0_to_TPM12_4.43.259.0.BIN
              TPM12_4.40.119.0_to_TPM20_5.62.3126.0.BIN
              TPM12_4.40.119.0_to_TPM20_5.63.3144.0.BIN
              TPM12_4.40.119.0_to_TPM20_5.63.3353.0.BIN
              TPM12_4.42.132.0_to_TPM12_4.43.257.0.BIN
              TPM12_4.42.132.0_to_TPM12_4.43.258.0.BIN
              TPM12_4.42.132.0_to_TPM12_4.43.259.0.BIN
              10-25-2025, 10:09 AM
            • pp74
              Marantz NR1508 USB firmware update image
              by pp74
              Does anyone happen to have the latest firmware for the NR1508? Marantz took their update server down and customer support refuses to provide the image to flash over USB.
              Regards
              05-10-2025, 11:55 PM
