Gone but not forgotten
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Gone but not forgotten
    cut pin 4 on cic.did it to every one i had open.
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      Yes, Jetway is indeed still alive and well. They make custom ITX ISFs for a reasonable price. All polymer caps, good fan, lots of 40mm fan slots, external PSU. Pretty well built honestly. I always liked the look of their older boards. And you could get them free because of all the Sacons they used
        master hoarder
        • May 2008
        • 12170
        • Bulgaria
        Originally posted by Wester547
        They must have really underspec'd it in order for a low-end C2D to heat the VRM up. I'm thinking three FETs per phase, two phase, two chokes, very small copper pads, all free standing FETs...
        Wasn't so much underspecced as just a bad design. The CPU VRM is 3-phase with 3 FETS per phase (which is pretty much the standard for most non-gaming boards). The only thing that wasn't specced right was the copper pads for the FETs - they were quite small. But I'm thinking some of the passives for the PWM controller were just right at the limit, because the board must have worked okay at one point.
        In a way, I don't blame the board for only accepting "good" brands.
        I agree. But sometimes, I just want the board to work - even if it has to be with crappy parts (which I usually use as a test PC). For that matter, ECS is wonderful. They always seem to accept any kind of RAM you put in them. I have two 1 GB Buffalo -branded PC3200 DDR sticks that won't work in any board except my ECS P4VXASD2+. That said, they only run at DDR 100 and 133 MHz, but crash at 166 and 200 MHz. I can also run these sticks in my Jetway N2PAP LITE motherboard, but first I have to start the PC with some good RAM and manually set the RAM speed to 100 or 133 MHz. Then save CMOS, shut down, and finally install those crappy Buffalo sticks.
        Now if only it were the same way for crappy PSUs.
        That'd be cool. But probably easy to get around.
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • Hakuu
          by Hakuu
          Hi There,
          More Details
          TV Model - LG OLED77G1PUA
          07-12-2023, 02:37 PM
        • jb_Bak
          by jb_Bak
          CN6401
          Pin 01 NC
          Pin 02 NC
          Pin 03 "BL_ON": 0V
          Pin 04 "N/C"
          Pin 05 "STBY 3.3V": 3.5V
          Pin 06 "GND": N/C
          Pin 07 "AC_OFF"...
          09-27-2021, 04:52 PM
        • canadaboy25
          Panasonic TC-P54VT25 No image. A or D board?
          by canadaboy25
          I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
          The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
          I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
          01-17-2021, 01:06 AM
