K8M800 - Dumbest BIOS ever?
  • bigbeark
    • Jan 2010
    • 661
    I have two of thee boards, one by ECS, the other an MSI K8M Neo-V.
    They are socket 754 using a VIA chipset. They have two SATA connectors.
    The BIOS does not support SATA DVD Drives. Oh, it will say it sees the Drive, but you can't reference it in the BIOS meaning it will spin up but you can't boot with it. If you attach a SATA HDD, it is reported as an IDE device There seems to be some wierdness if you try to use 2 SATA drives together. It only sees one drive. I can't tell if this is a defect or just the BIOS.
    The BIOS Setup also does not give you any ideas what it will support.
    I installed a SCSI card and Drive and it recognized that and showed it in the BIOS settings. But it doesn't show the device as acceptable until you actually install it.
    I looked at MSI's BIOS update documents and they say you can't use a floppy to update the BIOS, but they then talk about how to create a BOOT floppy,
    Anyone done any BIOS updates on one of these?
    The boards seem quite fast otherwise.
    • 31002
    Re: K8M800 - Dumbest BIOS ever?
    did you try customising the bios?
    • pfrcom
      Oldbie
      • Jun 2006
      • 1230
      Originally posted by bigbeark
      MSI K8M Neo-V
      Don't try MSI's godawful tools for a BIOS update or you're likely to end up with a paperweight
      Instead choose BIOS from here
      http://www.msi-computer.co.jp/suppor...Neo-V&x=14&y=5
      then update under DOS
      FWIW (first) Zip file contains BIOS image, update utility & instructions
      If it was me though, I'd probably try the second download, seeing it's last of the v.3 series
      better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
      • bigbeark
        • Jan 2010
        • 661
        How do you do that?
        Do you mean within the existing BIOS setup? It allows you to select from 50 "types" of harddrive. Never seen anything like it, instant confusion.
          • 31002
          search this string "Phoenix BIOS Editor v2.2.0.1 & Keygen"
          • bigbeark
            • Jan 2010
            • 661
            I checked this out and I think it's beyond my comfort zone, though very interesting.
            It seems mainly to allow tweaking performance parameters. I did not see anything about adding new device types.
            The key here is that the board treats "serial devices" as if they were IDE devices. I think the VIA 8237 is an older chipset that was developed when there was no SATA, and the new BIOS just "emulates" SATA.
            I do have an IDE DVD burner that I can use. I may also experiment with USB booting and see if that works.
            • bigbeark
              • Jan 2010
              • 661
              Blow Taps for the MSI Neo-V. The BIOS stopped recognizing SATA completely. I put a SCSI card and Drive in it instead. It recognizes the SCSI drive but pops up a message saying it's incompatible with PATA: "Hit F1 to continue". So it boots the OS on the SCSI, but the light stays on on the PATA DVD. The BIOS disables the IDE device so it can boot SCSI. So your choice is either SCSI or PATA. In effect the machine is now an all-IDE box. Yes, I could try a different PCI slot, but really, I have a life!
                • 31002
                you need a scsi card with a bios on it.
                • bigbeark
                  • Jan 2010
                  • 661
                  BIOS Version on Adaptec 29160N card is 2.57, as reported by the BIOS on bootup!
                  The VIA motherboard BIOS is at fault here!
                    • 31002
                    not so sure,
                    btw - the latest bios for that card is atleast 3.10 because i have a few.
                    the phoenix/award bios btw has lots of menu's in it that are disabled.
                    the editor can turn them on.
                    some of them relate to the boot devices.
                    • mikeybass
                      by mikeybass
                      04-23-2025, 04:30 PM
                    • akwky
                      by akwky
                      Hi!
                      04-14-2025, 01:56 PM
                    • al3m0di
                      Update bios EFCN58WW to EFCN59WW
                      by al3m0di
                      Update bios EFCN58WW to EFCN59WW for solving The Connected AC adapter has a lower wattage than the recommended AC adapter
                      I have a Lenovo Legion 5 15imh05a device that I bought used online. It came with a 20V 8.5A 170W charger.
                      The BIOS version is EFCN58WW.
                      When I turn on the device, it displays the message:
                      "The Connected AC adapter has a lower wattage than the recommended AC adapter..."
                      The device rarely charges the battery, and even when it does, it doesn't show that it's charging.
                      I've tried
                      07-29-2024, 10:32 AM
                    • trix11
                      Dell Precision T1650 MT Workstation bricked after BIOS update
                      by trix11
                      I have a Dell Precision T1650 MT workstation (of the following spec.) that was bricked yesterday when attempting to update the BIOS from A27 to A28 per:
                      - https://www.dell.com/support/home/en...-t1650/drivers > Dell Precision T1650 System BIOS
                      - Dell Precision T1650 mid tower Workstation
                      - Xeon E3-1225 V2
                      - 32Gb PC3-12800E RAM
                      - 4Tb SATA HDD
                      - motherboard: Dell part: 0C3YXR CN-0C3YXR-72200-39C-01GR-A02
                      I see now that others have experienced like issues e.g.:
                      - https://www.dell.com/community/Prec...
                      10-24-2022, 10:35 PM
                    • Julian Bailey
                      BIOS update wont complete - Dell Latitude 7420
                      by Julian Bailey
                      Hi all
                      Anyone come across this issue where a BIOS flash will only part complete?
                      It will update the system BIOS and Primary EC BIOS fine but fails to update the Intel TBT Retimer, Intel TBT Retimer 2 and ME Firmware.
                      NVMe m.2 drive isnt detected in the BIOS, but you can get into the BIOS fine and it all works in there as intended.
                      The drive works fine in another laptop.
                      Link to a video I made of what its doing here:
                      Any ideas on how to overcome this?
                      Cheers...
                      06-02-2025, 01:39 PM
