UMC UM8881F datasheet needed
  • nicolae788
    • May 2015
    • 31
    • Romania
    I would highly appreciate if someone has in reach a datasheet for this IC. It's about the UMC UM8881F
    Thank you very much.
    Alex.
    • 31024
    Re: UMC UM8881F datasheet needed
    it's paired with the UM8886 to create the chipset for a 486 motherboard.
    why do you need it?
    • nicolae788
      • May 2015
      • 31
      • Romania
      Hi, thanks for the reply,. Yes indeed that's the case. I am rebuilding this 486 motherboard and i have a broken pin on this IC and i want to know what's used for, maybe i can get away with it.
      Thank you very much for your kindness.
        • 31024
        you would have more luck searching for a 486 motherboard schematic i suspect.
        if you feel the need, you could grind the package down and solder a link to the stub.
        this used to be done a lot on wii console dvd drives.
        • nicolae788
          • May 2015
          • 31
          • Romania
          yes a schematic would do fine also. But can you instruct me to a place were they have desktop boards schematics? The vast majority are keeping laptop MB schematics which it's fine, but on the desktop side i found the ice to be quite thin ...
          I really appreciate your help. Thank you.
          P.S. nice guide you shared thank you.
            • 31024
            maybe there are 486 based laptops?
            • nicolae788
              • May 2015
              • 31
              • Romania
              Yes, i could search for a 486 laptop schematic that used this same chipset...thank you ! However finding 486 laptop MB schematics won't be so easy, i presume. But in the likely event that i will not find the schematic, grinding the IC looks feasible.
              • asustuf
                Datasheet for it8225vg needed
                by asustuf
                does anyone know where to find datasheet for it8225vg chip? I can't find it on their official website.
                10-13-2023, 12:55 PM
              • Toueno
                Dyson Pure Hot+Cool HP00 - Datasheet needed
                by Toueno
                My Dyson Pure Hot+Cool, model HP00, no longer starts.
                After disassembling and accessing the electronic motherboard, I found that the 16A fuse soldered to the motherboard is dead. I decided to do an electronic shunt to see the reaction, and the Dyson turns on for a few seconds and then turns off.
                It is likely that a voltage control chip or a safety chip is dead, but without the electrical schematics, the repair becomes complicated…
                Thank you in advance for your help.
                Best regards
                08-14-2024, 10:38 AM
              • SoulFreeze
                Help finding datasheet for component marked G34662
                by SoulFreeze
                Hi, pulled this component, (I'm assuming it's a MosFET) from an LED COB video light. Im trying to find the datasheet so I can find an equivalent replacement but no luck. Any assistance with the datasheet would be appreciated.
                Failing that, a way to pick a suitable replacement component? If it's indeed a switching fet, I'm assuming I might need to measure the switching clock frequency and find a component that meets the power capacity?
                Its a pair of them driving a 130w Light. Takes in 19volts. I can borrow a scope to measure the switching freq....
                05-01-2025, 03:56 AM
              • Rainbow_Chameleon
                Searching Datasheet for AM113 IC by O2MICRO
                by Rainbow_Chameleon
                I got a dead HD6950 on Ebay to try my luck and repair it. There were a few broken off capacitors that I already replaced.
                Measuring the PCI-E lanes I got somewhat weird measurements, the gpu might or might not be dead.
                If I plug the GPU in, the core heats up and I also get VCore but on two inductors that measure 16 and 60 Ohms respectively (Memory and PEX I guess) there is no voltage.
                On one of the two buck-controllers (APW7165) the enable pin is pulled to GND and the other controller I just cannot find a datasheet for.
                So if anyone has a datasheet or at least...
                01-23-2025, 12:03 PM
                Surface Mount Fuses Fundamentals Datasheet
                TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                10-07-2024, 06:07 AM
