UMC UM8881F datasheet needed
  • nicolae788
    • May 2015
    • 31
    I would highly appreciate if someone has in reach a datasheet for this IC. It's about the UMC UM8881F
    Thank you very much.
    Alex.
    • 31161
    Re: UMC UM8881F datasheet needed
    it's paired with the UM8886 to create the chipset for a 486 motherboard.
    why do you need it?
    • nicolae788
      • May 2015
      • 31
      Hi, thanks for the reply,. Yes indeed that's the case. I am rebuilding this 486 motherboard and i have a broken pin on this IC and i want to know what's used for, maybe i can get away with it.
      Thank you very much for your kindness.
        • 31161
        you would have more luck searching for a 486 motherboard schematic i suspect.
        if you feel the need, you could grind the package down and solder a link to the stub.
        this used to be done a lot on wii console dvd drives.
        • nicolae788
          • May 2015
          • 31
          yes a schematic would do fine also. But can you instruct me to a place were they have desktop boards schematics? The vast majority are keeping laptop MB schematics which it's fine, but on the desktop side i found the ice to be quite thin ...
          I really appreciate your help. Thank you.
          P.S. nice guide you shared thank you.
            • 31161
            maybe there are 486 based laptops?
            • nicolae788
              • May 2015
              • 31
              Yes, i could search for a 486 laptop schematic that used this same chipset...thank you ! However finding 486 laptop MB schematics won't be so easy, i presume. But in the likely event that i will not find the schematic, grinding the IC looks feasible.
