Hi guys; what of this installed programs should i get rid in win 7 see pic attach.?
Uninstall program?
Re: Uninstall program?
I wouldn't have thought you need to run Malwarebytes and Security Essentials. Both do real time scanning and like all antivirus its only as good as its user and can give a false sense of security.
Are you wanting to uninstall for a reason ? -
None of these programs are a problem, although you can get much better antivirus programs than MSE
Our current AV of choice is Bitdefender with Kaspersky a close second.
Malwarebytes is a great thing to run along side a decent AV, especially if you have the premium version.Comment
I don't really want to uninstall anything,i just wanted to know if there is any software that i really do not need! i use Free Malwarebytes and it's better then defender,i had to use it a couple times to get rid of some browser that installed itself and could never uninstalled it,don't remember the name now.Comment
I use Media Player Classic Home Cinema (MPC-HC), it has all that's needed built in, just like VLC. So you don't need codec packs or other things.
I like MPC-HC more because its interface is more similar to how proper Windows applications behave and does more things better (hardware decoding, better 5.1 support etc)
You can download it from here: https://mpc-hc.org/Comment
by shamsudeenEpson M3170 Monochrome inkjet printer adjustment program tool.
Hi, i want to reset a epson reset program tool needed to reset the EPSON M3170 PRINTER's Maintenance box,
anyone having it, please share
Thank you -
by desone01I have dug through my Dell utilities and located an old Dell Engineer's program which changes the Dell Asset Tag. I have used this SUITE of programs in the past to amend the Asset Tag on second hand motherboards I have installed.
I don't know if it works with the newer Dell laptops. You should use extreme caution in using these programs. As you can see the program is fairly old one.
Here are the instructions from the README file:
SVCTAG.EXE
Dell Internal Use...-
Channel: BIOS Requests ONLY!
by Nikan.eGreetings and salutations!
I have a device that uses an N32G455RE. Unfortunately, its flash got corrupted. I have a dump of a working chip.
How can I program a specific region of the flash or the whole flash without touching the RAM, option registers, etc.?
I do not have a J-Link debugger and won't buy one, as I am not rich.
I have flashed a Nucleo board with an ST-Link to a J-Link just to find out that the ST-J-Link only supports ST chips.
What would be the cheapest and easiest option to program the Nations chip's flash without touching registers etc.?...-
by peterwangSamsung NP750QGK-KG3US BIOS program error seeking help
PCB:BA41-03025A BA92-25486B
I opened the Modular Flash Image Tool-v16.50.00.1120 software and encountered the following error message. I am seeking help.
by lapfixECFinder program for searching for firmware of multicontrollers and a number of BIOSes inside any binary files: dumps or unpacked update files.
Just Drag your dump in and choose capacity
Mod edit: link https://comsystem-tlt.ru/forum/viewtopic.php?t=759-
- Loading...
