Dell inspiron 531 fans constantly blowing hard
  • Vivi
    Banned
    • Sep 2014
    • 101
    Well, after, (thinking) that the previous problem with this computer may have been fixed. something new occurred today. As soon as I powered on the computer, the fan i inside began running and blowing very loudly, constantly. Though, when I sign into account, it doesn't take as long as before. I still have SMART enabled in BIOS. but the fan, even right now, is constantly blowing loudly.
    Please help.
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Dell inspiron 531 fans constantly blowing hard
    The heatsink/fan hasn't been knocked has it ?
    Download speedfan from here http://www.almico.com/speedfan.php run it and see what temperature the cpu is.
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5042
      • US
      heatsink clogged by dust? it might be blowing loudly but is the air coming out fast or slow, and how hot is it?
      • Vivi
        Banned
        • Sep 2014
        • 101
        Its very hot, I keep smelling something like something's burning.
          • 31056
          if this is the one running slow in the other thread, then we already pointed out that the cpu heatsink is clogged wih dust and the whole machine really needs to be cleaned out.
          • Vivi
            Banned
            • Sep 2014
            • 101
            My master already cleaned out the computer yesterday, and this happens.
              • 31056
              post a fresh foto of the cpu area.
              either he missed it, or he messed up the fitting of the heatsink somehow.
              • TractorGear
                • Mar 2015
                • 40
                Heat causes system file corruption. Meaning, necessary Windows system files can become corrupt causing any problem imaginable, including freezes, crashes, BSOD's, slowness on boot, etc...
                I've also found a connection between overheating and hard drive errors, which can be repaired via the use of "chkdsk".
                Also using "msconfig" you can use Selective Startup to disable all non-critical functions. Sometimes you turn off the thing that's broken, as a way of helping to narrow where the problem is, Windows vs. non-Windows.
                A speedtest report should tell whether or not your system is still running hot. There are other temperature monitoring and reporting softwares available.
                Disconnnect all unnecessary peripheral devices during troubleshooting, such as printers, USB drives etc... as they can cause problems and removing them from the system can rule them out (or in) as a cause of the problems.
                • c_hegge
                  • Sep 2009
                  • 5219
                  Wrong. A hot running CPU does not cause file system corruption, unless it is shutting off all the time, which does not appear to be the case here.
                  Another possibility is that he damaged the fan (which could have happened if he windmilled it too fast). I've seen this happen once before to a customer after cleaning a HP pavilion. It turned out that he somehow damaged the fan's PWM circuit, so the fan was not responding the throttle commands from the motherboard. It just needed a new CPU fan.
                    • 31056
                    that would be pretty dumb given that you cant really clean the heatsink with the fan in place anyway - the dust cakes into a sheet.
                    • Vivi
                      Banned
                      • Sep 2014
                      • 101
                      So its the fan that is broken now? Is it safe to keep running it? Even though I see no problem so far.
                        • 31056
                        we didnt say that, we are speculating.
                        open the case and with the power off, make sure the cpu fan looks normal,
                        then power it up and make sure it spins o.k.
                        and take some more foto's
                        it could just be something stupid like it not being put back properly after cleaning.
                        • Vivi
                          Banned
                          • Sep 2014
                          • 101
                          I have the case opened, but I have no idea what the cpu looks like. I don't see anything spinning, but I could be looking in the wrong place, or not hard enough.
                          • c_hegge
                            • Sep 2009
                            • 5219
                            You are looking for the CPU fan. The CPU itself is hidden by the fan and heatsink (or radiator).
                            If it spins normally and isn't clogged with dust, then it should be OK.
                            As has been suggested earlier, though, you really should install SpeedFan and check the temperatures. That will tell us if it is a problem with the fan or if it is overheating
                            • Vivi
                              Banned
                              • Sep 2014
                              • 101
                              I'm not sure how to download it, not sure if it wants to buy it first.
                              • c_hegge
                                • Sep 2009
                                • 5219
                                http://www.almico.com/speedfan451.exe
                                Download and open that file
                                It's a free program, you don't have to buy anything.
                                • RJARRRPCGP
                                  • Jul 2004
                                  • 6304
                                  Very true when overclocking cores and overvolting the Vcore, due to a known phenomenon that rarely, if at all occurs at stock core clocks and stock Vcore.
                                  In addition, there appears to also be a phenomenon where OC'ing the cores to the edge and overvolting the Vcore to an xtreme level causes the processor to be fussy with temps, where it's possible that the core temps going higher than around 50 C causes a crash or error.
                                  ASRock B550 PG Velocita
                                  Ryzen 9 "Vermeer" 5900X
                                  Arc A770 16 GB
                                  eVGA Supernova G3 750W
                                  Alienware AW3423DWF OLED
                                  • Vivi
                                    Banned
                                    • Sep 2014
                                    • 101
                                    this is what I see:
                                    • c_hegge
                                      • Sep 2009
                                      • 5219
                                      Your temps all look normal. I'd say it's just a problem with the fan not responding the throttle commands (or the motherboard's fan controller not issuing them). As long as you can put up with the noise, it shouldn't be a problem.
                                      EDIT: Just noticed, it looks like the CPU fan is at 1700RPM and the Case fan at 1200RPM. That's not actually all that fast, or even close to full speed. On those Dells it's usually about 3000-3500RPM for the CPU fan and 2000-2500RPM for the case fan.
                                      • Vivi
                                        Banned
                                        • Sep 2014
                                        • 101
                                        So how do I speed up that fan to get the fastest speed it supposed to have?
                                          DELL Inspiron 3470 Inspiron 3000 i5-8400 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 3470 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3470 boardview and Inspiron 3470 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          09-12-2024, 03:44 PM
                                          DELL Inspiron 3250 Inspiron 3000 i5-6400 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 3250 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3250 boardview and Inspiron 3250 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          DELL Inspiron 3650 Inspiron i5-6400 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 3650 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3650 boardview and Inspiron 3650 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          DELL Inspiron 3650 Inspiron 3000 i5-6400 Specification for Upgrade or Repair
                                          DELL Inspiron 3268 Inspiron 3000 i5-7400 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 3268 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3268 boardview and Inspiron 3268 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
