NLTDR missing....
  • stevo1210
    • Oct 2006
    • 4156
    NLTDR missing....
    Hello Everyone,
    My server PC which was fine until this afternoon when it started to show an error when booting from the hard drive.
    The error says: NLTDR missing Press CTRL + ALT + DEL to restart and that's about it. I have backups of the drive so I am not in a panic situation at the moment. But I don't want to have to reformat/reinstall the drive and lose all my information and then have to reload all the backups etc.
    The Windows XP drive is a Fujitsu MPC3043AT 4.3GB IDE drive and I've had it for about 8 years now since 1999.
    The error is very strange because If I use the secondary Seagate drive, which has Windows 2000 Pro installed, I can actually select Windows XP on the boot menu and boot off the Windows XP drive.
    Is there any way that I can fix this error without doing a full reinstall. I was thinking of a Windows XP repair, but I don't know how that's going to perform.
    Thanks.
  • Fizzycapola
    • Oct 2006
    • 423
    Re: NLTDR missing....
    Can you confirm whether boot drive root file ntldr is missing
    Rubycon Rubycon Rubycon
    • Paul S
      • Sep 2006
      • 326
      It's been a while since I saw this on a system, I think that the hard drive may have some bad sectors. We had one at work do this. If I remember, it had a RAID drive. There was an option (at boot) to configure the RAID. In side of that there was an option to map the bad sectors.
      This was never done, as I am not allowed to do this stuff at work ( I don't know anything!). But if you can do this, then boot into the windows disk and do the recovery mode option. I'm not 100% sure on the exact name of the option.
      The PC at work was accessible by putting the HD in another computer (as you found), so the drive wasn't trashed. You may want to try and recover important files before trying to fix it. Your drive may actually be OK, just some of the important windows files have become corrupted.
      • acstech
        GrumpyModerator
        • Jul 2007
        • 1432
        Sometimes I get that if I've overclocked the memory too high.
        So check your memory for corruption first.
        A man convinced against his will is of the same opinion still.
        • pixl
          • Oct 2007
          • 5
          Try to run scandisk on the drive in another computer. There is a slight chance that could fix it.
          • reformatt
            Intel iMacs, 3rd party SSD failures and Fusion setups
            by reformatt
            I thought I'd throw out some of my personal experiences in the last 12 months with Intel iMacs, 2.5" SATA SSD drives and Fusion drive data recoveries.
            As a backgrounder, Apple never fitted a 2.5" SSD's to these iMacs. Apple's SSD option was a system of 32GB NVMe blade drive (NGFF connector) and Seagate 1TB 2.5" HDD, married together in software to become a Fusion drive. Non Fusion systems have just the 1TB Seagate HDD.
            So, the most common reason an iMac comes across my bench is because it's either ridiculously slow, or it fails to boot at all. The most...
            12-18-2024, 10:34 PM
          • ramzi2019
            Hasee M2152 won't boot to any Drive + f2 and f10 not responding
            by ramzi2019
            Hi Everyone,
            I'm facing a problem with a Hasee m2152 AIO pc that cannot boot to any drive (hdd, ssd, pen drive,...) and the f2 and f10 prompt is showing at start-up but nothing respond.
            The problem started after making some changes to the bios settings precisely after enabling the fast boot option.
            I attached a copy of the bios with hope someone can clear the changes made.
            Also The clear-cmos jumper is useless
            Thanks for your help....
            02-04-2025, 05:53 PM
          • perfm2
            HP EliteBook Folio 1040 G2 won't detect a drive after reformat.
            by perfm2
            So I've worked on dozens of HP and Dell laptops and have never encountered this before.
            Steps taken in my usual process.
            Reset security settings in the BIOS
            Ensure existing HD comes up into the OS
            Shut down the laptop and disconnected the main battery
            Removed old M2 drive and replaced with a new 1tb Mushkin Temptest NVME drive. (I'm aware the bus is Sata III but the drive should still work at a slower speed right? Been my experience in other laptops)
            Replace battery connector and close up the laptop
            Insert my USB drive with my Windows 10 image I've...
            03-21-2023, 08:45 PM
          • eltano4i20
            [HELP] SAMSUNG NP270E4E-K01AR
            by eltano4i20
            1) Error trying to enter the BIOS
            --> [F2] won't let me enter the BIOS. To enter the BIOS, I had to create a shortcut and then type C:\Windows\System32\shutdown.exe /r /fw /t 1 in the destination. This forced it to restart and enter the BIOS.
            Once inside, I went to the BOOT menu, but, surprise, it wasn't there. I got the following message:
            BOOT PRIORITY ORDER (img-05)
            1- Windows Boot Manager
            2- SATA HDD
            3- NETWORK
            4- Debian
            2) Error trying to access the BOOT MENU
            --> I restarted the notebook and pressed [F10] but the BOOT...
            07-04-2025, 12:39 AM
          • theflyingsquirrel
            Samsung Chromebook Pro missing 1.2V power rail and no boot
            by theflyingsquirrel
            I am trying to repair my Samsung Chromebook Pro. There is no boot. Upon turning on, the screen is blank and there is no backlight. Power LED is blue. I tried refresh with power and esc refresh with power with no avail.
            When I measure the 1.2V rail, it is pulsing. It will jump from 0 to 1.2V then 0 again. I replaced the 2 MOSFET and even power management IC and it is the same. Resistance from midpoint between mosfet to ground is 0.5 kOhm but it will show 250 Ohm first before jumping to 0.5 kOhm. So it feels like it was charging up some capacitor. Since MOSFET and IC was replaced, I...
            06-11-2025, 08:11 AM
