Windows update KB3033929 very picky.
  • joshnz
    • Feb 2011
    • 969
    • New Zealand
    I was affected by the KB3033929 restart to install updates update failed rolling back issue.
    turns out my issue was related to bios set to boot from non windows drive (grub bootloader for Cent os.)
    solution was set to set bios to boot drive with windows boot loader.
    My pc
    CPU : AMD PHENOM II x4 @ 3.5Ghz
    MB : ASUS M4A89TD PRO USB3
    RAM : Kingston ValueRAM 16gb DDR3
    PSU : Cooler Master 850W Silent Pro
    GPU : ATI Radeon HD 6850
  • 0xx
    2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
    by 0xx
    Hi folks,
    My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
    What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
    I assumed that Windows Update was interrupted due to closing...
    09-14-2025, 03:46 PM
  • Stanley1843
    Windows 11 disk no boot
    by Stanley1843
    I tried to install Linux on a secondary disk in my PC and after a failed Linux grub installation my PC didn't boot in Windows 11. I saw the message (Reboot and select a proper Boot device).
    I made a bootable USB windows 11 and I run the below commands on the cmd but with no succeed.
    DISM /Online /Cleanup-image /Restorehealth
    The DISM.... command shows me the error 87.
    sfc /scannow
    chkdsk
    bootrec /FixBoot
    bootrec /ScanOs
    bootrec /RebuildBcd
    For some reason it writes(Total identified installations 0) like there no...
    10-18-2025, 04:41 AM
  • eltano4i20
    [HELP] SAMSUNG NP270E4E-K01AR
    by eltano4i20
    1) Error trying to enter the BIOS
    --> [F2] won't let me enter the BIOS. To enter the BIOS, I had to create a shortcut and then type C:\Windows\System32\shutdown.exe /r /fw /t 1 in the destination. This forced it to restart and enter the BIOS.
    Once inside, I went to the BOOT menu, but, surprise, it wasn't there. I got the following message:
    BOOT PRIORITY ORDER (img-05)
    1- Windows Boot Manager
    2- SATA HDD
    3- NETWORK
    4- Debian
    2) Error trying to access the BOOT MENU
    --> I restarted the notebook and pressed [F10] but the BOOT...
    07-04-2025, 12:39 AM
  • Eotis
    Framework 13 laptop ,Nvram locked ,TPM issue
    by Eotis
    Hi folks. I have a Framework 13 laptop with these specs.
    Motherboard: Framework FRANBMCPOC AC
    Processor: 11th Gen Intel® Core™ i7-1185G7 @ 3.00GHz 3.00 GHz
    Graphics: Intel Iris xe
    Installed RAM: 64.0 GB (63.8 GB usable)
    System type: 64-bit operating system, x64-based processor
    Bios: Uefi InsydeH20 3.24
    Edition: Windows 11 Pro/ AtlasOS
    Version: 23H2
    Installed: ‎9/‎16/‎2024
    OS build: 22631.4169
    Intel Chipset driver: 10.1.19502.8391
    This processor seems to...
    Yesterday, 08:55 PM
  • coasterghost
    Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
    by coasterghost
    For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
    Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
    Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
    System Hardware:
    Processor: AMD Ryzen 7 PRO 5850U
    Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
    09-08-2025, 10:46 PM
