MS recolonizes 2 Hp DV-5 /DV-6 as one?
  • ivtec
    • Dec 2008
    • 1967
    Hi guys:i suspected that My 2 HP Pavillion DV-6 1259DX and DV-5 1254 US, were recognized by MS as Key activation as concern.
    But today i've over come all my suspicions by putting HDD from DV-6 into DV-5 with Win 7 installed and it recognized it right away,
    both Hp laptops are running Win 10 Preview installs made the same way from same Win 7 ISO and upgraded same way,showing same Activation # ID#.
    Note:both HP Dv-5/and DV-6 show in the Bios that both were installed Win Vista from Factory, But DV-6 was upgraded to Win 7 by the previous owner,and DV-5 still is Win Vista, but it accepted win 7 upgrade and from there on i upgraded to Win 10 Preview.so it means that i could use the upgrades activation as one only PC,which is great,
    remember i bought DV-6 Pavillion with Win 7 Installed for 50 bucks,
    so my Luck;in a god way.
  • SteveNielsen
    Retired Tech
    • Jun 2012
    • 2327
    Re: MS recolonizes 2 Hp DV-5 /DV-6 as one?
    Nothing surprises me concerning Windows activation crap.
    • diif
      • Feb 2014
      • 6978
      • England
      Why not just download the Windows 10 iso ? Then you don't need to install a dodgy Windows 7.
      http://windows.microsoft.com/en-gb/windows/preview-iso
      • ivtec
        • Dec 2008
        • 1967
        Good question! but as i remember what has been stated by MS,Win7 users will have free upgrade to Win 10,not Vista users!
        i tried to make a clean install with win10 Iso you mentioned, but it asked me for drivers but did not specify which ones, see pic.
        http://postimg.org/image/95csfsvmv/cf752e29/
        • SteveNielsen
          Retired Tech
          • Jun 2012
          • 2327
          There is an Enterprise download that includes some extra tools, did you try that one?
          https://www.microsoft.com/en-us/eval...hnical-preview
          • ivtec
            • Dec 2008
            • 1967
            Thanks for the link; now my 2 HP Laptops are running great, with this win 10 set up, if i run in any problems in feature i'll give that a try.
            besides when i said that my 2 PC's DV-6 and DV-5 Hp Pavilion laptops were validated by MS, i meant in relation to Win 7 and not Win 10.
            • diif
              • Feb 2014
              • 6978
              • England
              The free upgrade is only for genuine Windows. Is there a Windows 7 sticker on the laptop ?
              There is a big difference between a Windows machine that shows activation and one that has been validated by Microsoft.
              • diif
                • Feb 2014
                • 6978
                • England
                What is the hard drive setting in the BIOS and are you installing what are you using to install Windows ? Internal or external DVD or USB ?
                • ivtec
                  • Dec 2008
                  • 1967
                  there is a Sticker on both HP Dv-6 and Dv 5,but is for win vista, it's mentioned in the bios that win vista was the factory default,but the DV-6 had Win 7 installed over Vista,you can install or upgrade from vista to win 7 by buying a legit key from MS or any other legit MS seller.It's what happens with HP DV-6.
                  You say;( There is a big difference between a Windows machine that shows activation and one that has been validated by Microsoft,)
                  i know when it's a legit Key,i've tried to install Win 7 from Iso's on some machines and they have a Grace time of a month for activation,but you can check that all the time on the Update or upgrade section.MS doesn't give you nothing for free so far,the HP DV-6 has a legit key,
                  Also i always use DVD for installations
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    You can also download or install from a legitimate Windows disc/iso run an activator and Windows looks and behaved legit, passing validation and getting updates.
                    However Microsoft do know the difference. How do you ?
                    • ivtec
                      • Dec 2008
                      • 1967
                      I know because Hp Dv-6 with Win 7 installed was running great without any issues with all updates from MS, how you measure if it's legit or not?,the only way i know is when you try the updates from MS,it won't run right, special after the 30 days grace of a Legit ISO of Win 7 and you always have a flag saying 'ACTIVATE" after that it will go to a chaos state.
                      http://www.howtogeek.com/182847/htg-...tivation-work/
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        Running great is no indication of legitimacy as i have said.
                        You the user can't tell if a key is legit or not. Windows 7 doesn't even need a key to be activated and pass all of the legitimate Microsoft tests. Fake keys can also be purchased online.
                        Maybe they'll allow any version showing as activated, maybe they won't. Time will tell.
                        • ivtec
                          • Dec 2008
                          • 1967
                          Ok diiff; you made work and made me curious,so i installed the HDD that contains Win 7 not on the HP DV-6 were it belongs, but on the HP DV-5 that has win vista legit key activated, and checked for legitimacy; here the Pic.
                          • diif
                            • Feb 2014
                            • 6978
                            • England
                            As i keep saying, it means nothing. I have a laptop here with exactly the same screen.
                            This laptop does not have a genuine key in it though.
                            • ivtec
                              • Dec 2008
                              • 1967
                              diif i don't want to argue on this with you no more; you have your opinion and i respect it; but for me what matters is that my PC's work right with this Win7 and don't see in it nothing that makes me believe otherwise;
                              Besides you think i care that my win7 is not 100% legit,besides Win doesn't do more for me than Linux, on contrary i get better off Linux,besides if it fails nothing missing here, in 1 minute i have it running in Linux.
                              • diif
                                • Feb 2014
                                • 6978
                                • England
                                Microsoft yesterday announced that all as long as the device is supported, all versions of Windows 7, pirated or not will get to updates to Windows 10 for free.
                                • mkdj
                                  Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
                                  by mkdj
                                  Dear all,
                                  I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
                                  Here the steps I have taken to fix the laptop:
                                  - downloaded latest BIOS from Lenovo Website...
                                  10-18-2025, 03:43 AM
                                • Zilicon
                                  Elitebook 840 G1 HDD not recognized, Please help
                                  by Zilicon
                                  Greetings everyone.
                                  please, help assist me with the above PC problem.
                                  The boars number is 6050A2559101-MB-A03. The PC does not recognized HDD, neither does it recognized NGFF SSD.
                                  i discovered that the HDD does not spin.
                                  there were activities at the SATA connection.
                                  Pin 2,3,5,6 rises to 400mv then jump to about 4v, again to mv. It continues in loop that way. Same behaviour at pin 20,21,22.
                                  5v is present at 14,15,16.
                                  Pin 18 which is reserved has about 1.8v, sometimes it increases to 2v+.
                                  Pin 8,9,10 is...
                                  06-16-2025, 12:11 PM
                                • martimarti
                                  RX 6700 XT PowerColor not recognized in any OS
                                  by martimarti
                                  The title explains the issue. The additional information is:
                                  - GPU was never disassembled
                                  - not recognized in Windows/Linux, not even with error, totally not recognized like it's not plugged in
                                  - GPU fans don't spin but work. When I turn on the system, the fans twitch for that second when I press the power button. Same thing happens when I power off the system.
                                  - GPU does not get hot no matter for how long I let it run even though not recognized
                                  What I have to done so far:
                                  - played with the BIOS switch without any luck. OC/SILENT...
                                  03-31-2023, 09:34 AM
                                • Carl0s-
                                  iPad 5th gen (A1823) - No charge but recognized by finder
                                  by Carl0s-
                                  Sooo - our IT got a pile of old iPads that the sales guys have been mistreating. These are free for grabs if you want to try to get one working. Thought I'd give it a try - if I get at least some life to I can give to my kid to entertain during a car rides.
                                  But the iPad it self - its a 5th gen cellular model. When I initially plug it in it was completely dead. It was not recognized by my Mac nor it started to charge. Disassembled it opened up the battery connector and checked the battery voltage. My multimeter showed 0,7v. Had a spare micro-usb charging board lying...
                                  04-15-2024, 12:51 PM
                                • kikki1979
                                  Boardview for HP Pavillion gpc70 la-j652p REV 1.0
                                  by kikki1979
                                  Is there someone who has a boardview for a HP Pavillion gpc70 la-j652p REV 1.0? I have my first laptop to repair/diagnose for a friend. If someone can help me, i would appreciate this much.
                                  10-23-2025, 03:07 PM
