Is there someone who has a boardview for a HP Pavillion gpc70 la-j652p REV 1.0? I have my first laptop to repair/diagnose for a friend. If someone can help me, i would appreciate this much.
Boardview for HP Pavillion gpc70 la-j652p REV 1.0
Hi all, I see previously these HP Pavillion hp 13-s150sa boardview and schematics have been asked for but were unavailable.
Wondering if anyone may yet have anything.
TIA.-
12-05-2022, 09:10 AM -
by javiermiHi this laptop had liquid damage: I found a couple of burned contacts on the keyboard connector, and it worked for a while after I cleaned them. After that, the keyboard stopped working completely I replaced the sfp connector and still the same. I doubt the problem is the keyboard, as it was working ok until it stopped completely. I suspect either a DC line is broken or there is a fuse failure.
if I get an schematic I will check.
There are several compatible boards, the models are: 827824 , 827823 , 809842 depending of the installed CPU
Alternatively, if somebody can confirm...-
I have problem with my graphic card GV-N3060GAMING OC-12GD.
2 smd elements are missing.
I've already bought a boardview but it's not complete - that specific area is not attached. I tried with different similar models but without success.
This is my PCB
And this is screen of boardview
As you see those missing capacitors or resistors are not on boardview.
Also i compared every single transistor from boardview to real card and everything is related.
It seems that this one is like extra.
Could anyone...-
08-09-2025, 10:26 AM -
by ronaldopdiasDell latitude 5490
DDM70 LA-F401P
Schematics, BoardView...-
Channel: Schematics and Boardviews
First of all, I hope I got this into the right section. Apologies if I did not.
I was working on my Asus ROG Strix G17 (2021) G713QM-RS96, and I guess I pre-heated the board too much replacing the DC Jack and one of the small parts came off. I looked for it on my soldering mat, and it was nowhere to be found. So now, the laptop is powered from the new DC Jack I installed, but it will not charge the battery from that jack. Only powers the hardware.
I looked at the boardview diagram in another post for the G713QM, and it looks like the diagram displays it as X450, a 4 contact... - Loading...
