Blackberry
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Blackberry
    new blackberry delivered to IT after 15mins as user manage to change language to..........Turkish.
    IT not allocated blackberry so proceeding learn USERS blackberry
    user to be punished later
    ok got it with help of turkish dictionary
  • pentium
    • Mar 2006
    • 2778
    Re: Blackberry
    A proud and addictive canadian invention.
    Looks good.
    Find Nedry!
    Check the Vending machines!!
    • jarocks
      Blackberry Q30 Passport (SQW100) Schematic
      by jarocks
      Hey all, I'm having a decent amount of trouble finding a schematic/boardview and hope someone here might be able to assist.
      name: Blackberry Passport (Q30)
      model: SQW100
      board: (any variant)
      04-06-2025, 02:14 PM
    • Francisco.s
      Samsung Galaxy Book NP750XED
      by Francisco.s
      Hi, need bios for Samsung Galaxy Book NP750XED-KC4ES.
      This board mounts a intel alder lake, and seems that the bios is corrupted.
      I tried two versions of flash image tool 16, and shows some errors and can't open it.
      This are the errors:
      Command Line: X:\MEA\FIT 16.0.15.1531\fit.exe
      INFO : Start decompose 'X:/MEA/samsung.bin' image.
      INFO : MFIT version used to build the image: 16.0.15.1554
      INFO : Generate layout dictionary <xpath, container wrapper>
      INFO : Layout dictionary generated successfully
      ERROR...
      06-17-2024, 12:48 PM
    • sikocan
      Lenovo X1 Carbon 9th Gen Black Screen
      by sikocan
      I believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
      SN: PF3G1REP
      MODEL: 20KW-00J1AU
      PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
      Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
      06-24-2025, 09:01 PM
    • l3emarsh
      Panasonic Rc42129 string code?
      by l3emarsh
      Hello, can anyone give me the string code for Panasonic/Vestel remolt control Rc42129M
      Thank you to anyone who Knows this as is not listed in the dictionary file after downloading software with vestel toolbox, i have tried all the one's liisted in dictionary file and all of them did not work so i have to keep changing back to my all in one remote code for the tv to work.
      Any help ia am thankful for.
      Lee
      04-20-2022, 07:00 AM
    • vbogoev
      IR lamp Medisana IR 850 ,Identifying 14 pin chip
      by vbogoev
      I have a non-working IR lamp Medisana IR 850.
      Initially, when I plug the item into mains I had to press the button once to start it. The function is pretty simple - every button press add 5 min to timer (probably the unknown IC I am looking for) up to 15mins. The main problem was that the relay was not closing for some reason and the lamp did not glow.
      I found the problem which was a blown zener dionde, but unfortunately while measuring on live my probe slipped and shorted the black capacitor next to the zener diode with mains and it blew up... ...
      12-13-2023, 11:59 AM
