hay guys whats going on in this thread
So I setup a refreshed system with an old copy of XP Pro, with no service packs, of course.
The network setup is a Netopia router as well as a little 10Base hub. What I have is this newly added system with XP hooked up to the hub which is plugged into Port 1 of the Router. There is at least one or two of the other systems on the hub as well. All the existing systems seem to be running Windows 2000.
There are several printers on the network, and I can only see 3 of the 4, (those three run directly off the assorted systems on the network) and even when I try to add one of those three as a networked printer on this XP system, they all say access denied as if they want authentication. In any case, I can't see the big copier/printer machine I actually need to print to from this XP system. The big machine is plugged into Port 4 of the Router itself. All of the other systems can apparently print to it. I also cannot access the Router because I don't have the required username and password, which is long lost, and I'm afraid to reset the router and possibly mess anything up because it's a small business which can't afford to be down. Although, I imagine it shouldn't be a problem to throw back together, but you know; anxiety!
So am I having a problem because the added system is XP and the others are 2000? I've worked as a Techie for a few companies, but I've never been a network guy. :/ plz 2 halp meh
The network setup is a Netopia router as well as a little 10Base hub. What I have is this newly added system with XP hooked up to the hub which is plugged into Port 1 of the Router. There is at least one or two of the other systems on the hub as well. All the existing systems seem to be running Windows 2000.There are several printers on the network, and I can only see 3 of the 4, (those three run directly off the assorted systems on the network) and even when I try to add one of those three as a networked printer on this XP system, they all say access denied as if they want authentication. In any case, I can't see the big copier/printer machine I actually need to print to from this XP system. The big machine is plugged into Port 4 of the Router itself. All of the other systems can apparently print to it. I also cannot access the Router because I don't have the required username and password, which is long lost, and I'm afraid to reset the router and possibly mess anything up because it's a small business which can't afford to be down. Although, I imagine it shouldn't be a problem to throw back together, but you know; anxiety!
