External Charger for Online UPS
  • minitt
    • Jan 2009
    • 24
    Lets start with the Objective
    1.To increase the backup time of my Double conversion Online UPS
    2.Ensure fast recharge for both internal & external batteries
    3.Make sure external charger remains completely isolated from the UPS internal charging circuit.
    A brief description:
    The UPS internal battery is connected to a AC powered timer relay.
    The AC powered timer relay also connects to the external battery bank and an external battery charger.
    This is a DPDT( Double Pole Double Throw) Relay. Contact rating is 120A@28VDC. Relay Coil runs on 220 AC and directly powered by utility power.
    So, when the relay is powered, it will connect the external batteries(75A Batt @ 24VDC) to the external battery charger.
    But when power goes out the relay looses power and connects the external battery bank to the internal UPS battery in parallel.
    There is a 60mv voltage drop due to relay contacts on both contacts (+ & -) Is this something I should be concerned of?
    I've applied this with a Online UPS which has two 9A SLA(Yuasa) at 24VDC bus. Which roughly gives around 30 minutes@ 160 watt load. The internal charger can put put out max 1A.
    The two 75A flooded lead acid batteries connected in series with an external SMPS charger which only charges the 75A batteries with a float voltage of 27.29V
    A hand sketched design is attached which illustrates the whole modification.
    Looking forward to your suggestions, tips to improve my mods.
    Thanks in advance.
    • 30944
    Re: External Charger for Online UPS
    cant you just double up the battery's in parallel?
    2 chargers are going to be a pain to syncronise so they dont mess wih each other.
    • minitt
      • Jan 2009
      • 24
      The internal charging circuit will take around 5 continuous days to charge those two 75A batteries. Thats where the external charger comes in.
      As for synchronization, which really isn't an issue here since the relay will connect the External batteries to the External charger after disconnecting the external batt from the UPS and vice versa.
      This means the charger will be always isolated from the UPS internal charging circuit.
      here C1 is External Batt +
      and C2 is External Batt -
      A1 & A2 is UPS (+ & - respectively)
      B1 & B2 is External Charger (+ & - respectively)
      So at NC position( relay coil has no power= Grid power failure) C1 & C2 will connect to A1 & A2 respectively
      and when the relay coil is energized C1 & C2 will disconnect from A1&A2 and then connect to B1 & B2(External Charger) (grid power comes back)
      • minitt
        • Jan 2009
        • 24
        • joshnz
          • Feb 2011
          • 969
          • New Zealand
          seems ok i have not look at diagrams though
          My pc
          CPU : AMD PHENOM II x4 @ 3.5Ghz
          MB : ASUS M4A89TD PRO USB3
          RAM : Kingston ValueRAM 16gb DDR3
          PSU : Cooler Master 850W Silent Pro
          GPU : ATI Radeon HD 6850
          • minitt
            • Jan 2009
            • 24
            Could you have a look the attached picture which pretty much outlines the whole concept.
            Concern:
            But someone informed me that the smaller 9A (SLA) batteries will be damaged very soon by the bigger external batteries (Flooded Lead acid) due to circulating current.
            IF the above scenario is a real fact, then how come APC or others ups manufacturer offer external battery banks that has much higher capacity than internal ups batteries, work in parallel with the internal ones but not suffering from this same effect?
            • minitt
              • Jan 2009
              • 24
              bump....
              • cheapie
                null
                • Jul 2010
                • 849
                The main problem that I see is that if one set (internal or external) of batteries is near-charged while the other is near-discharged for some reason, then when the power goes out and the batteries are connected together, one set will start charging the other. While this shouldn't ever happen, placing a fuse (with a sane value) in the external string should prevent damage if it does.
                • minitt
                  • Jan 2009
                  • 24
                  The system has been running as expected. Had to change the dpdt power relay once.
                  • japlytic
                    • Oct 2005
                    • 2086
                    Beware, the battery can be at mains potential in some units, as I have seen.
                    • joshnz
                      • Feb 2011
                      • 969
                      • New Zealand
                      Found that out the hard way on my old unit.
                      My pc
                      • minitt
                        • Jan 2009
                        • 24
                        could you please explain a bit as to what do you mean by mains potential?
                        tia
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8677
                          Mains potential, meaning it's not isolated from the wall socket. This is an electrocution danger if you work on the batteries.
                          • carrzkiss
                            Cyberpower cps1500avr not charging batteries
                            by carrzkiss
                            Hello, all.
                            Cyberpower Battery Backup Unit.
                            I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
                            When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
                            In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
                            Checking the voltage, it was down to 22v.
                            I quickly removed everything...
                            06-15-2024, 02:10 PM
                          • Petr0x
                            Bosch 12V and 18V chargers modification
                            by Petr0x
                            Hi, I would like to share with you small modification to your Bosch tool 12V and 18V chargers.
                            You can use it for almost all Bosch chargers what I have seen, for example part numbers GAL 18V-20, GAL 18V-40, GAL 1880, GAL 18V-160, AL 1820, AL1115CV, AL1130CV.
                            Bosch (today also other brands using the same system like Wurth, Fein) does not care if you destroy your batteries, because they can sell you new ones. So the marketing is telling you only about speed of the charging, so you will not wait for your batteries to charge too long. Me as a customer want the tools and batteries...
                            05-24-2024, 01:00 PM
                          • Johndill
                            Dell Inspiron 7567 LA-D993P odd charger issue
                            by Johndill
                            Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
                            There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
                            I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
                            Here are the tested scenarios:
                            1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
                            2. With the laptop off, plug in charger (LED says on) & the front charging...
                            11-16-2022, 10:55 PM
                            HP ProBook 430 G6 + Samsung ?5 500GB External Portable SSD + 15.6" Classic Briefcase & Mouse Notebook 400 Specification for Upgrade or Repair
                            This specification for the HP ProBook 430 G6 + Samsung ?5 500GB External Portable SSD + 15.6" Classic Briefcase & Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Samsung ?5 500GB External Portable SSD + 15.6" Classic Briefcase & Mouse boardview and 430 G6 + Samsung ?5 500GB External Portable SSD + 15.6" Classic Briefcase & Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will...
                            09-06-2024, 08:52 AM
                            HP EliteBook 840 G5 + Samsung ?5 500GB External Portable SSD + 15.6" Classic Briefcase & Mouse Notebook 800 Specification for Upgrade or Repair
                            This specification for the HP EliteBook 840 G5 + Samsung ?5 500GB External Portable SSD + 15.6" Classic Briefcase & Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G5 + Samsung ?5 500GB External Portable SSD + 15.6" Classic Briefcase & Mouse boardview and 840 G5 + Samsung ?5 500GB External Portable SSD + 15.6" Classic Briefcase & Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will...
