CPU Cooler Suggestions?
  • canadaboy25
    What is normal?
    • May 2013
    • 509
    Hey guys I have an AMD FX-8350 Processor on an Asus M5A99FX PRO R2.0 motherboard.
    The cooler that came with the CPU just isn't paying the bills. I can have 3 gigs of memory used and 30% CPU utilization and my temperature will be up in the 70°C range. I know that is not off the charts hot but its hotter than I would like and I am willing to pay a bit extra to keep the heat down. The fans also go full throttle when it's that hot and it is really annoying to listen to them for no reason.
    If anyone could suggest a cooler that would be bigger and fit my motherboard that would be great.
    Watercooling isn't really an option because in don't have the time, nor patience to fool around with that.
    canadaboy25
    -Sometimes the light at the end of a tunnel is an on-coming train
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: CPU Cooler Suggestions?
    What compound did you use? how much?
    sigpic
    (Insert witty quote here)
    • brethin
      • Dec 2008
      • 1907
      Remove the heat sink and clean it and the cpu. Then apply the thermal compound and reassemble. The type or brand of compound is not nearly as important as making sure you have used some and that the heat sink is flush (well seated) on the cpu.
      Changing from generic compound to a high grade might net you a 3 degree temp change but a improper mount of the heat sink will cook your cpu.
      With no load and proper cooling it should be around 55°C on the core and 60°C on the socket. 70°C is high with no load and tells me you heat sink is not flush on the cpu.
      • canadaboy25
        What is normal?
        • May 2013
        • 509
        The CPU came with a nice thick square of even compound already on it.
        The PC was built on valentines day this year
        canadaboy25
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          Yuck. "Nice and THICK" is not NICE at all. I'd throw a small amount of AS5 on that, after cleaning with alcohol swabs. Just enough to coat the heat spreader on the CPU when the cooler is latched and nothing more is ideal.
          sigpic
          • mariushm
            • May 2011
            • 3799
            I have FX-8320 (pretty much same thing) and I use a Zerotherm FZ-120 cooler with a Noctua silent fan installed instead of the original one.
            The FZ-120 wasn't that expensive when it was new, maybe about $30.
            The stock cooler is designed as a compromise between price, cooling capability and noise. It's noisy and not so capable, because it had to be cheap.
            At 70c, the processor is probably already throttling itself down to lower frequencies when needed, so don't have to worry about damaging it. But it would help to install a better cooler.
            As for thermal paste, the ideal application is a thin layer of paste. Best way is to clean both surfaces and put a drop of thermal paste in the center of the cpu, about the size of a pea. When you put the heatsink straight down on the cpu, the pea of paste will be flattened in all directions and therefore the paste will spread out by itself.
            If you spread the paste in advance, you won't get an even spread, and as the heatsink goes down it could trap small molecules of air between the paste layer and the heatsink, which will cancel all the benefit of having paste in that spot.
            • c_hegge
              • Sep 2009
              • 5219
              It's not that thick. Just like on the Intel stock coolers, the TIM is pre-applied - it's just a fairly thin layer on the bottom of the cooler, and it usually works nearly as well as appropriate layer of AS5. The problem is that the AMD stock coolers just don't handle those 125W 8 core CPUs well.
              OP: I'd suggest a Cooler Master Hyper 212 Evo. They are very well priced for what they offer.
              • canadaboy25
                What is normal?
                • May 2013
                • 509
                No it wasnt very thick i just meant there was sufficent surface coverage.
                Like i said I'de prefer to pay a bit to keep it cooler
                canadaboy25
                • rhomanski
                  nowhere man
                  • 5157
                  • U S of A
                  Mine has a six core socket 2011. The one they said was a server chip cut down. I used a dremel to cut holes for tubes and mounted a thermaltake water cooler outside the chassis. It had two holes for 120mm fans side by side. I just put the screws in the existing holes and put two sets of fans on it, pushpull. The thermaltake is maintenance free. No hassles. They were even on sale for about a hundred bucks recently. I think mine was about $130 when I bought it a year ago.
                  sigpicThe Sky Is Falling
                  • Hondaman
                    • Sep 2008
                    • 1079
                    I have the original BARAM heatsink from Korea on an 8-core AMD 8150 (it took a great deal of looking around to get the last couple of first-generation BARAM coolers available anywhere). You buy whatever 120mm fan (or two, for push-pull) that you want to use, fans are not included. The first generation BARAM, that I have, has a nickel base. The second generation had a copper base touching the CPU.
                    I used this computer to do protein folding a while back. I don't remember how hot it got, but it was not "hitting the limit". Don't quote me, but it might have hit 53-57 degrees C maximum. For a very high "torture-testing" CPU load level.
                    (The factory-included heatsink is a compromise IIRC - size, cost, noise and effectiveness under lighter "business" use. It is very easy to get a far better cooler, although the "bridge" chips and the caps near the VRM won't be cooled as well by modern CPU coolers.)
                    • canadaboy25
                      What is normal?
                      • May 2013
                      • 509
                      Thanks I bought that one and I am very, very happy with it! It even fit in my case! Now my highest temp is around 50°C which is a slight improvement over the 90°C that it was hitting at half load before.
                      Thanks for showing me that cooler!
                      canadaboy25
                      • c_hegge
                        • Sep 2009
                        • 5219
                        Yeah. I have one in my current main rig now, and I can't fault it. My 3770K barely gets warm with it.
                        • SuperDuty
                          • Mar 2011
                          • 299
                          • France
                          I have the Hyper 212 Evo as well on my Phenom II X4 965 @3.6Ghz and it's barely over 60°C in full charge, 57°C with an additional fan.
                          I know it could be better but my cable management isn't the best so airflow could be improved with a newer case (I have a huge but old Chiefter Dragon tower). The very hot GTX480 underneath doesn't help either.
                          • canadaboy25
                            What is normal?
                            • May 2013
                            • 509
                            Yeah I have the Cooler Master N600 and it allows you to run almost all of your cables behind the motherboard. So my case is pretty neat, I only have a couple of sata and power cables running out in the open. Along with one IDE cable for my soundblaster card.
                            I guess the stock coolers just can't handle a 125W CPU
                            canadaboy25
                            • SuperDuty
                              • Mar 2011
                              • 299
                              • France
                              Actually the stock cooler isn't bad at all for what it is. It wouldn't even need to be replaced if there was a way to install a larger, quieter fan. I did have an improvement with the Hyper 212 Evo but it wasn't huge (the Phenom II X4 965 is 125W as well and it's the same IHS).
                              Here's an interesting topic : http://forums.anandtech.com/showthread.php?t=2300800
                              I'd say, start by changing the thermal compound and see what you get. I'm sure you'll get a serious improvement.
                                • 31091
                                anybody tried changing the paste under the cpu cap/heatspreader ??
                                i dont mean can it be done, it can - i mean any noticable improvement?
                                • SuperDuty
                                  • Mar 2011
                                  • 299
                                  • France
                                  From what I've found, the 125W AMD processor have the heat spreader soldered to the CPU die. So there's no reason to replace it, ever.
                                  But I've seen people change the thermal paste on intel CPUs with a slight improvement.
                                    Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
                                    The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
                                    Securing a good thermal interface between...
                                    10-07-2024, 04:35 AM
                                  • Hondaman
                                    Liquid cooling?
                                    by Hondaman
                                    I hope my computer does not randomly reboot while typing this. My main system is the AsRock 970A-G/3.1 motherboard with the AMD 8150 chip. I am experiencing FREQUENT and RANDOM reboots once the system is used for a couple of hours (sometimes it reboots before I even get to the Win7/Linux Mint dual-boot screen). The problem MIGHT be the DRAM controller chip (I recently upgraded to the maximum 64 GB RAM). It also might be the VRM chips. I am using a typical aftermarket CPU cooler, which does NOT blow air DOWN onto the VRM heat sink.
                                    (After previous generation hardware [Gigabyte] didn't...
                                    05-08-2025, 09:37 PM
                                  • MyBrainIsAStrainer
                                    Asrock H87-Pro4 Rev. G/A 1.04: Power cycling on reset only
                                    by MyBrainIsAStrainer
                                    Hi!
                                    I have a weird one for you. I have a H87-Pro4 from Asrock that power cycles. But only when you do a restart after it was already running!
                                    Symptoms in detail:
                                    1. I switch off the ATX PSU for ~15-20 seconds, then switch it back on again.
                                    2. I press power button. The board boots without issues.
                                    3. I can shut down the board any way I want (via OS* menu, or pushing the power button - either in the OS or the boot manager).
                                    4. Push power button again, board boots fine.
                                    5. This shutdown/powerup can be repeated multiple times without problems.
                                    6. BUT: If I do a restart instead
                                    06-25-2023, 02:44 PM
                                  • davidebaldini
                                    ATX power supply keeps blowing PFC mosfets — Cooler Master RS-550-ACAA-E3
                                    by davidebaldini
                                    This is an ATX PSU rated for 550W powering 24/7 a computer load of about 200W, fed by a line-interactive 1500VA UPS. Mains is 230V.
                                    1. First issue: the PSU blew a mosfet on what I think is the active PFC boost converter, shorting its G D S pins together causing a short across the + and - lines produced by the rectifier on the 230V mains. The surge protector of the house tripped. When this happened I found that the UPS was unexpectedly disconnected from the wires of its battery. The UPS wasn't damaged, but I suspect this spontaneous detachment of a battery wire caused a condition that blew
                                    01-25-2023, 02:23 PM
                                  • Zippie
                                    Troubleshooting Old Chiefmax 650Watt ATX Switching Power Supply
                                    by Zippie
                                    I’m looking for some advice troubleshooting an old Chiefmax 650w power supply in a PC, if it’s advisable to dig into it.
                                    Worst case I can replace the PSU, I’m just interested in learning the troubleshooting process. However, it’s out of my area of expertise and I could use some direction.
                                    During PC operation I heard a loud pop noise, like a cap gun and the tower lost power.
                                    Initially there is no power output 3.3v, 5v, or 12v when jumping the power on pin to ground. Also, no fan power.
                                    Opening the PSU the only things visible initially...
                                    03-07-2024, 07:58 PM
