ADVICE please (asrock 4coredual-vsta Recap)
  • Jor3llBR
    • Jul 2007
    • 32
    Hi guys,
    Gonna recap the 1000 and 1500uf lines out of the box for the following reasons:
    But I have so many choices to make:
    *16v 1000uf:
    - Nichicon's models to choose:
    VR, VZ, HE and PW
    - Chemicon:
    KMG, KY and KZE
    *6.3v 1500uf:
    VR, VZ, HE and PW
    - Chemicon:
    KY, KZE and LXZ
    I need to maintain the 8mm diameter (no room for fat caps like Pana's FM).
    Thanks!
  • Super Nade
    • Jun 2006
    • 294
    Re: ADVICE please (asrock 4coredual-vsta Recap)
    I use UCC KZE or KY in my recapping projects.
    Q6700 @ 3.6 GHz
    Zippy GSM-6600P
    Curcial Ballistix PC6400 (4 x 1Gb) Micron D9GMH
    Abit IP35Pro
    ATi HD4870
    • Jor3llBR
      • Jul 2007
      • 32
      Tx Nade,
      I just found like there a bunch of 6.3v 1000uf short Evercon's!
      Evercons1
      Evercons2
      Which capacitors in that line are less than 1 inch tall?!
      • Spacedye69
        • Nov 2005
        • 698
        • US
        Forget the VR/VZ series. They are not low ESR. The HE are the longest life out of any of them, but I've never seen a bad PW. 6.3v 1000uf should be available in all the series at 8mm x 15mm or shorter.
        • gonzo0815
          • Feb 2006
          • 1600
          I would consider some of the Samxon series, maybe the GC, GD or GA ones.
          they should be available in the right dimensions & values.
          Apart from that may be Rubycon MCZ is wort to put into consideration.
          But if your choice is limited due to availability the KZE are the way to go.
          • Erroneous Hyphen
            AsRock P4i65G polycap/polymod advice?
            by Erroneous Hyphen
            Hello!
            I have a Pentium 4 motherboard, a AsRock P4i65G that I'm wondering whether it would be worthwhile doing a polycap upgrade on? The existing capacitors look fine to me, none are bulging or leaking that I've noticed. I was approaching it more from an 'upgrade' perspective, as to whether there would be any benefit to do such a mod even if the existing capacitors look fine?
            I believe that if I do go down this route, for the Voltage Regulation circuits that I should be sticking to the same capacitance and voltage, and that a higher ripple voltage and lower ESR can...
            04-03-2022, 07:41 PM
          • gabrieljma1
            Request: Full BIOS dump for ASRock Z790-CX (DDR5)
            by gabrieljma1
            I’m looking for a full raw 16 MB BIOS dump for an ASRock Z790-CX (DDR5) motherboard.
            The board powers on (fans spin, RGB lights on, RAM LEDs active), but there is no display output and the VGA and BOOT LEDs stay lit.
            I’m using an Intel i9-14900KF CPU (14th gen), and it seems the BIOS version on my board doesn’t support it yet. I tried to flash the official ASRock BIOS file (renamed .ROM → .BIN) directly using my RT809H programmer, but it didn’t work — monitor stays on but with black screen, so I believe the ASRock update file is not a complete...
            10-08-2025, 03:32 PM
          • DOBBELDUNK
            NEED Bios File ASROCK H61M-VS4 REV.G/A 1.01
            by DOBBELDUNK
            Mobo turn on, HSF on but no display, blank only in monitor.
            Here is bios backup of asrock h61m-vs4 rev. g/a 1.01
            11-20-2025, 10:07 AM
          • Exim
            ASRock N100M, no picture no boot, but semi-alive
            by Exim
            Hi guys,
            I managed to semi-kill an ASRock N100M board after updating Bios from 1.10 to 2.01. It's a zombie now, dead, but not dead.
            ASRock N100M special features:
            - CPU soldered to board, small Intel 12th gen
            - iGPU
            - four POST LEDs
            Problem after updating Bios to 2.01 using the in-Bios update tool: no picture, no boot.
            I am not sure anymore if it booted at least once successfully after updating the bios to 2.01, maybe not, I can't remember. I think it did not.
            Symptoms:
            - no picture/signal on any of the display connectors,...
            04-01-2025, 02:36 PM
          • MasterCap
            What IC does AsRock usually use to make the PWM signals for GPU fans ?
            by MasterCap
            I have an AsRock Taichi 7900xtx, and the minimum fan speed is way too high at 1000rpm, and thats with it's Quiet BIOS switch on, and me setting the fan profile as low as it goes, while on.
            Now 1 thing I could do is just make some circuit to put in between the fan the the GPU, and leave the fan on all the time, but anytime the GPU is sending the PWM for min speed, I'll just send something lower and quieter.
            But does anyone know what how AsRock usually sends the PWM to the fans on GPUs and mobo's? Is it from the MCU that's often near the 12V inputs and fan jack ? Or is...
            12-28-2024, 08:42 AM
