hp probook 430 G4 liquid metal damage
  • dogfish404
    • Jul 2022
    • 5
    • austria
    hi just a few days ago i had a VERY similar thing happening which led me to this forum, ie this post!
    it all began with me applying liquid metal to my probook 430 g4 7200u AND buyin a backlit keyboard on ebay.
    after few hours everthing went well. plus then i ordered myself a new hdd door, some 16gb ram, etc.. a new FAN, the old was too loud, etc..
    so i ended screwing on my laptop few more hours opening and closing.. in this procedere TWO things happened:
    some lquid metal escaped and was teared around the bios chip , special not on it but on the ics around the rom (i did not recognize in the first place)
    AND i ripped off the small cable leading to the backlit keyboard on the upper side, causing me to manipulate around with the connnector and shorting the whole plug with a flat screwdriver. (some electric flash appeared, but only 1-2 times, then dead..)
    HOWEVER ordered new keyboard again, and SEE caps lock and NUM flashing 5 times..
    NOW opened up everything (was 1 week since) cleaned the mess up, tried removal of battery, cmos bat, controller reset, bios reset, etc whatever i could find, using ch341a (had one left from former bios flashing on my main pc) bios it self looks kinda situated, however flashing an alternative one from THIS site didnt work either.
    WHEN looking all the main chips, tranistors dont look bad or burned, solder ok as well couldnt find the error.
    so its stuck in boot loop with 5 times blinking then fan up and after 5 mins or so off
    btw it might help the power button alone doesnt power on, need to plug ac to get blinking and boot, BUT removiong ac stays on and poerbutton 5sec turns of..
    CAN I REPAIR THIS ANYHOW?? or do i need new mainboard ?
    i have multimeter by hand but no idea where to start from.
    edit: i remember first when the short happened i smelled little smog in side the site where it appeared but was not so heavy as if something burned just the sort of electric short that you can smell (btw, i do KNOW how it smells if an resistor or transistor burned of current, but that was not the case... cya)
  • hoaca388
    Badcaps
    • Jan 2022
    • 12438
    Re: Need bios hp probook 430 G4
    Post your discussion here : https://www.badcaps.net/forum/forumdisplay.php?f=23
    There must be a short on your motherboard, I don't know the hardware so can't help.
    • dogfish404
      • Jul 2022
      • 5
      • austria
      Re: hp probook 430 G4 liquid metal damage
      i see, just removed the nearest transistor where the short happened, cuz it was shorted by the backlit keyboard assembly...
      btw can u have a look on this file is my current bios, if its in a good condition.. + f.ex. im interested in removing the ME part or at least deactivating it as i read its ver 11 and must be present for cpu and OS to load !!??
      regards..
      • silver60618
        How to clean Liquid Metal from under CPU?
        by silver60618
        Hi all, Im working on a board, that my customer brought to another shop, and smeared liquid metal all over the board.
        The laptop powers on, then shuts off. I noticed traces of Liquid Metal near the edge of the CPU, but I fear some maybe underneath.
        Has anyone ever tried Ultrasonic cleaning, or compressed air to remove or agitate the liquid metal?
        07-11-2025, 01:47 PM
      • av4x
        Fujitsu U7511 liquid damage, wont turn on anymore, does not respond to charger in any way.
        by av4x
        Good morning, everyone!
        I've gotten my hands on a few laptops with various defects because I want to get more involved in repairing electronics.
        First up is a Fujitsu Lifebook U7511.
        It won't turn on anymore and doesn't respond in any way when you plug in a power adapter.
        Model: Fujitsu Lifebook U7511
        CPU: Intel Core i5-1135G7
        GPU: Intel Iris Xe Graphics
        RAM: 16GB DDR4 - 3,200 MHz
        PCB manufacturer: ASKPCB?
        PCB serial numbers: CP801602, CP7984241-Z4, E239218, CP809978-01
        Damage: Liquid damage
        The liquid probably...
        11-01-2025, 03:09 AM
      • mon2
        A1466 Macbook Air (Liquid damage repair)
        by mon2
        Hi. Recently serviced a damaged A1466 Macbook Air. Thought to post the issues and resolution for each.
        Macbook AIR Model A1466 Diagnostic 09-01-2021
        Issue: Liquid damaged (beer spill) Macbook AIR will not power up.
        Problems & Resolutions
        1) Attached Apple magsafe power adapter. No green / no orange light. This confirms the absence of the PP3V42_G3H voltage rail. The PP3V42_G3H rail is the primary voltage rail necessary to communicate with the magsafe power adapter to report the green or orange light status to the end user....
        09-01-2021, 09:31 AM
        HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or Repair
        This specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
        09-07-2024, 07:12 AM
        09-07-2024, 06:40 AM
