It's 2025: do you know where your 5¼" floppy drives are?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Oh wow.
    As in the other thread I was trying to revive/re-bootstrap an old Apple IIe and wasn't successful reading or writing any disk. Both drives behave similarly.
    Then I was wondering, what about my PC floppy drives? I have a HH 5¼" HD drive and a combo 5¼+3½ drive. I tried formatting the disk that wouldn't work in the Apple and it didn't work in the PC either!
    Then I tried a HD 5.25 disk ... it won't even touch the disk either! Just like the Apple DD disk, "Not Ready!"
    Weird. Seems the PC drive is having trouble clamping on the diskette and not spinning (should be a direct drive so no belt). (The PC is an K6-233 on 82430TX running an old copy of Linux and just the DOS portion of Win98).
    The Apple IIe does use a belt, so perhaps it's suspect. But then I realized, do I have any more fluorescent lamps that blink at 60Hz? All are LED or high frequency electronic ballasts!?! Ugh... then I found a LED hooked up to a transformer with no filter caps. Ahh that should work!
    The Disk ]['s speed check ring came up pretty solid didn't move all that much. So I guess it's spinning okay at least.
    So now is the question... what's your success rate on reading/writing 5¼" disks today? Surprised I'm having no luck at all.
    The 3½" disk party is going to be another issue, though I have a small pile of 3½ drives (and an HP OB600 and another USB 3½" floppy drive) to go through to find a working drive. 5¼ drive? Not so much, just those two PC drives and the two on the //e...
  • CapLeaker
    Leaking Member
    • 8146
    I don’t have any Apple disks, but I DO know where my 5.25” and 3 1/2” disks are. Remember those huge 8” floppy disks? I guess I should be in a museum too.
      • 31015
      3.5" disks are shit,
      always where.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        sometimes I wonder, were the number of 5¼" disks ever made more or less than the number of 3½" disks?
        But yeah, already having readability losses in 3½" disks, leading to believe 5¼" disks are older and worse...
        • CapLeaker
          Leaking Member
          • 8146
          The 5.25” and 3.5” were a ton more popular than the 8” ones. But the most produced floppy disk was the 3.5”.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            Yeah seems so, though probably the largest contributor was the PC and partially mac. Amigas and other systems were minor consumers. But there were so,so,so many 5¼" computers out there that one would think there were a lot too.
            Granted every single 5¼" HD (15spt) disk was PC I think, though not all 80 track 5¼" disks were PC. DD 35/40 track disk were all over the place...
            • CapLeaker
              Leaking Member
              • 8146
              There were a lot of 5.25” disks, true… but there were more 3.5”. Also the programs got bigger needing more disks.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                Uh wow. not related to your post but this new version of forum software put an irrelevant inline ad in your reply as if you wrote the ad and trying to peddle the product... I'm not sure I'm liking this version...Click image for larger version
                • CapLeaker
                  Leaking Member
                  • 8146
                  Originally posted by eccerr0r
                  Uh wow. not related to your post but this new version of forum software put an irrelevant inline ad in your reply as if you wrote the ad and trying to peddle the product... I'm not sure I'm liking this version...Click image for larger version  Name:	Screenshot_2025-07-11_06-34-46.png Views:	0 Size:	300.0 KB ID:	3680044
                  I hope that is getting taking care of!
                  were you logged in and got the add?
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    Yes I'm getting ads while I'm posting. I don't think I can post this without being logged in... Some of these ads are obtrusive and distracting and TBH if it's trying to get me to leave this platform, it's working...
                    BTW back on topic, I just got some known good formatted disks. Was able to verify one of my Apple Disk II's as working as well as my dual combo drive. My single 5¼" HD drive however is sick... just a mechanical issue however: the hub clamp is not working. A bit of extra force on the clamp and the drive reads once more!
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8701
                      Ugh ... back to square one. just lost a working disk, think something's pooping in the soup, or rather, one of the bad disks is contaminating the head.
                      • CapLeaker
                        Leaking Member
                        • 8146
                        Take the drive apart and clean it? While your at it fix the clamping mechanism.
                          • 31015
                          3.5" disks had a higher track density, when i used them i was throwing them away pretty often after less than a year.
                          also the drives wore out!
                          i learned real fast with the Amiga that CHINON drives are the good ones.
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8701
                            The drive I'm currently trying to fix is a half height chinon 5.25" floppy drive. It's mechanically broken 😢 probably will have to design a fix. Then also having to deal with the apple disk ii... find which disks that need to be disposed of...
                            Damn where can I get cheap 5.25" DD's...
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8701
                              Glued the broken piece back together. Still weak but the drive works once more. Don't recall when it broke or if I acquired it broken, alas glad the drive is otherwise working.
                              Odd that I ran into a bunch of HD 5¼" disks that have bad sectors or won't format. And 3½" disks that had bad sectors... should just toss all the bad disks I suppose.
                              hmm...need a better way to test disks if they're really still good or not...
                              • Agent24
                                I see dead caps
                                • Oct 2007
                                • 4951
                                • New Zealand
                                3.5" was probably more popular too since idiots can't put it through a hole-punch and stick it in a ring binder...
                                -David VanHorn
                                • CapLeaker
                                  Leaking Member
                                  • 8146
                                  That is the BEST answer I’ve heard for a long time!
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8701
                                    I thought that write protect hole/high density media detect were for the ring binder...
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8701
                                      BTW are these advertisements trying to sell me 5¼" DD's?
                                      (How do I get rid of these ads?)
                                      Click image for larger version  Name:	Screenshot_2025-07-20_11-03-29.png Views:	0 Size:	260.5 KB ID:	3686840
                                      • Hondaman
                                        • Sep 2008
                                        • 1061
                                        I still have my 5.25" and 3.5" drives. My first computer was a 386 DX-40 with 4 Megs of RAM. Later, I increased RAM and added the 387 math coprocessor.
                                        Am I the only one here who remembers the Windows 3.1 error where all colors would become inverse (green would become violet, etc)? And am I the only one who remembers the Windows 3.1 "0xDEADBEEF" error?
                                        I envied Apple users. They paid a lot more money for their computer, and a lot more for their printers IIRC. But part of that was the royalty for PostScript. So they could produce fine manuscripts FAR BETTER than my Windows machine with my dot-matrix printer !
                                        • reformatt
                                          Intel iMacs, 3rd party SSD failures and Fusion setups
                                          by reformatt
                                          I thought I'd throw out some of my personal experiences in the last 12 months with Intel iMacs, 2.5" SATA SSD drives and Fusion drive data recoveries.
                                          As a backgrounder, Apple never fitted a 2.5" SSD's to these iMacs. Apple's SSD option was a system of 32GB NVMe blade drive (NGFF connector) and Seagate 1TB 2.5" HDD, married together in software to become a Fusion drive. Non Fusion systems have just the 1TB Seagate HDD.
                                          So, the most common reason an iMac comes across my bench is because it's either ridiculously slow, or it fails to boot at all. The most...
                                          12-18-2024, 10:34 PM
                                        • a_p3rson
                                          Apple Watch Charging Controller Schematics / Boardview - 820-02601
                                          by a_p3rson
                                          Hi there,
                                          I'm looking for anyone who might have information on Apple's embedded Apple Watch charging daughterboard, ID 820-02601. This is currently used by Anker in their Apple Watch charging products, but likely by other Apple partner brands as well.
                                          You can see the board referenced in ChargerLab's teardown of the Anker Y1811 3-in-1 MagSafe cube - they discuss the "Apple Watch wireless charging circuit" about 2/3rds down the page. It's not pictured, but the board ID reads 820-02601-A, which sure sounds like Apple.
                                          This daughterboard uses an interesting...
                                          04-21-2025, 11:41 PM
                                        • ktmmotocross
                                          Apple A1370 after flash shows no disk
                                          by ktmmotocross
                                          Hello.
                                          Have this Apple A1370 that have bad bios. i have trouble with my programmer RT809F and must use A341CH with Asprogrammer. Now laptop start but not see my hard drive.
                                          I dont work much with apple, is there something that must be done to run os on disk? or i should search for why disc is not recognized. Dump for flash was confirmed working from here...
                                          01-26-2024, 02:17 AM
                                        • Eleways
                                          Apple Macbook A1707 Hard disk
                                          by Eleways
                                          Hi
                                          I've an Apple macbook A1707 with Hdd defect.
                                          This product don't work with a normal Hard disk, but the hard disk it's a BGA component on the logic board.
                                          My question is:
                                          Can i exchange the hard disk, by desolder the bga Hard disk and replacing this?
                                          Can i replace with a different one (es 500 gb instead of 250 gb)
                                          This Macbook has T1 security check.
                                          Thanks and best regards
                                          Luca
                                          02-18-2022, 04:23 AM
                                          HP ProDesk 600 G5 + Apple AirPods ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                          This specification for the HP ProDesk 600 G5 + Apple AirPods can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + Apple AirPods boardview and ProDesk 600 G5 + Apple AirPods schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                          09-12-2024, 02:30 PM
