Hi, I'm having a problem signing up for the forum Teknisi Indonesia. The captcha asks "what's the president of Indonesia" but it keeps saying captcha failed. From a google search I've tried Prabowo Subianto and Prabowo Subianto Djojohadikusumo and neither works.
Teknisi Indonesia Signup Issues
Do you manage to register, Im having a headache haahah -
Thanks but accoeding to ai they also use qwerty and engliah. I try all the suggested ai answer but failed heehe. I realy dont know if its worth it but, Om watching some youtuber that teaching mobo repair and manage to see the schematic from there. Im saving schematic sources so if its not available here I can get it somewhere ornpost here if anyone needed. ThanksComment
Try with the previous president?
https://id.m.wikipedia.org/wiki/Joko_Widodo
Or his nickname "Jokowi" according to that Wikipedia article in Indonesian
https://indonesia.go.id/profil/presiden
Or just the last name? "Prabowo"
https://id.m.wikipedia.org/wiki/Prabowo_SubiantoComment
I already test that and all previous presidents, even first name only and combination all caps and small. I try all the combinations on what ai gave me like brute forcinb it but nothing works heehhe. Thanks anywayyTry with the previous president?
Having the same issue here, has anyone figured anything out? maybe it is a misspelling or something we don't expect??Comment
by grettiI have a MSI Z370-A Pro. The board does not reboot or shut down from the Windows recovery console. USB communications stop and the status light on USB 1 stays on and does not blink. I have programmed a new BIOS with a CH341A programmer already, swapped RAM, PSU, CPU. The board will power off when the power button is held and resets when the reset switch is pressed, but it will not react to the reset switch if already told by software to shut down or restart. The board will reboot from BIOS after a save and exit command.
The MSI BIOS included the ME firmware for the board. The size... -
by SoulFreezeHi, trying to troubleshoot some problems with this laptop I just finished repairing which had power issues (Burnt Buck converter - SY8883DFC shorted to ground).
After repairing the above issue, I realized the following remaining problem,
Sound only comes from bottom speakers, top palmrest speakers don't work. Neither does the headphone jack (static/buzzing).
The computer recognizes headphones are connected and displays a popup in windows
Sometimes, the computer will boot up and the sound will be working fine. However, if I run intensive programs and the computer... -
by NagyeszI have a Lenovo IdeaPad Gaming 3 15ACH, which has started exhibiting the well-known issues of the Lenovo IdeaPad 3.
All stress tests run perfectly, and there are no performance issues. However, the solder joints are almost certainly starting to fail. If the top two screws on the back are not screwed in, moving the screen results in a BSOD or, in some cases, a slight artifact and freeze. This is a 2023 notebook..
How can I extend its lifespan? Could reflow help?
It has ryzen 5 5500h, rtx 2050, no soldered ram.
Example of the artifacts:
...03-01-2025, 11:11 AM -
by pwnjuiceCustomers laptop had a Motherboard go bad and replaced it. they want to try to get data but. I am having bitlocker issues. I will list below
Issue 1: When connect the drive to my computer to decrypt it I get this message. "there are no supported protectors on this drive the drive cannot be unlocked"
Issue 2: When I run powershell as admin and try manage-bde -protectors -get e: I get this message. " ERROR: An attempt to access a required resource was denied. I also get the same error when I try manage-bde -status e: When I try the same with terminal with...-
by SkgodHey I am having Asus Rog strix g15 g513ih hn0865 and it's having display issues while running on igpu. Works fine when I open any game or whatsapp windows application. The issues are :
Black screen, freeze
The weird thing is that when as long as the laptop is running on igpu the problem keeps happening. But as soon as I open any game or whatsapp windows application, the laptop works completely fine.
When the screen freeze or black screen I used to move the display lid up and down and it usually works like that.
So can anyone tell me what would be the possible cause?... - Loading...
