Smart status pending sectors Returned to zero
  • joshnz
    • Feb 2011
    • 969
    • New Zealand
    Pending sectors returned to zero from 8
    and reallocated remains at zero ??????
    My pc
    CPU : AMD PHENOM II x4 @ 3.5Ghz
    MB : ASUS M4A89TD PRO USB3
    RAM : Kingston ValueRAM 16gb DDR3
    PSU : Cooler Master 850W Silent Pro
    GPU : ATI Radeon HD 6850
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    Re: Smart status pending sectors Returned to zero
    I've only seen such a thing after using HDD Regenerator.
    • ddscentral
      • Mar 2008
      • 151
      • Lithuania, EU
      This is by design.
      When a HDD detects read errors in some sectors, it marks them as "Pending".
      A Pending sector is reallocated only if a write operation to it fails. If write operation to it succeeds, it is unmarked.
      • brethin
        • Dec 2008
        • 1907
        Originally posted by ddscentral
        This is by design.
        ^ exactly.
        • Mad_Professor
          A Mech Warrior
          • Feb 2011
          • 1587
          I had few drives do that, they usually fix themselves but for those that won't I wipe the drive, usually fix those pesky pending sector.
          • SteveNielsen
            Retired Tech
            • 2327
            I have wiped/zero-filled drives and it doesn't reset all SMART data but it does clear pending sector count.
            • cheapie
              null
              • Jul 2010
              • 849
              If a read fails on a sector, it is marked as pending. The next time it is written to, the drive checks if it can be read. If it was readable, the drive clears the "pending" marker and the sector is returned to normal operation. This can be caused if, for example, the drive got bumped during the writing just enough to make it mess up. If, however, the freshly-written data is unreadable when the drive checks, the sector is marked as "reallocated" and the data is written elsewhere.
              What's happening to Mad_Professor and SteveNielsen is that a read failed at some point, the sector got marked as pending, then when they wrote something else to it, the drive checked the data it just wrote, and after finding it readable, removed the sector from the pending list.
              • SteveNielsen
                Retired Tech
                • 2327
                Exactly. Good explanation which I was too lazy to do A zero fill is nothing more than writing zeros to every available sector on the drive, which includes pending sector errors. It isn't capable of working beyond the drives internal sector mapping/re-allocation, which SMART interfaces with. I've seen things claim they can set all SMART data to "zero" but have yet to see one that actually does and fail to understand why it would be desirable to be able to do so in the 1st place.
                • joshnz
                  • Feb 2011
                  • 969
                  • New Zealand
                  So the media is ok just somthing went wrong causing 8 sectors to be marked as pending.
                  I'm used to drives I zero fill to turn pending into reallocated.
                  All 8 sectors were in the space one file occupied only knew somthing was wrong when copy the file.
                  Ran hd tune smart showed 8 pending sectors run a media scan 8 sectors un readable.
                  So zero filled it.
                  My pc
                  • RJARRRPCGP
                    • Jul 2004
                    • 6303
                    Seen HDD wiping clear "UNC" error reports before.
                    ASRock B550 PG Velocita
                    Ryzen 9 "Vermeer" 5900X
                    Arc A770 16 GB
                    eVGA Supernova G3 750W
                    Alienware AW3423DWF OLED
                    • joshnz
                      • Feb 2011
                      • 969
                      • New Zealand
                      The 8 sectors are back as pending also can't read some of the data.
                      My pc
                      • joshnz
                        • Feb 2011
                        • 969
                        • New Zealand
                        now is 16.
                        My pc
                        • joshnz
                          • Feb 2011
                          • 969
                          • New Zealand
                          now is zero wtf.
                          My pc
                          • joshnz
                            • Feb 2011
                            • 969
                            • New Zealand
                            The device, \Device\Harddisk3\DR3, has a bad block.
                            event log is full of that lol.
                            Smart is still reading zero pending.
                            My pc
                            • goontron
                              5000!
                              • Dec 2011
                              • 4108
                              • US
                              check your controller. the one on my system always reports ONE bad sector, even on a drive that is brand new and report none on other controllers.
                              Follow the white rabbit.
                              • joshnz
                                • Feb 2011
                                • 969
                                • New Zealand
                                This is the second pc i'm testing it on.
                                My friend gave me this drive after he could not copy a file off it and i found smart to contain pending sectors.
                                also the bad sectors showed up in a surface scan.
                                What I find interesting is they showed up as a block of 8 then 16
                                My pc
                                • joshnz
                                  • Feb 2011
                                  • 969
                                  • New Zealand
                                  Looks like it is taking a shit pending has gone 500+ and attribute B8 is failed
                                  My pc
                                  • goontron
                                    5000!
                                    • Dec 2011
                                    • 4108
                                    • US
                                    0xB8 = End-to-End error. This attribute is part of the S.M.A.R.T Error Detection and Correction process. it is a count of parity errors which occur in the data path to the media via the drive's cache.
                                    this attribute failing is an indicator of imminent electromechanical failure and can also lead to a bad sector count when trying to read a sector and failing because of a parity error.
                                    • RJARRRPCGP
                                      • Jul 2004
                                      • 6303
                                      May be a bad board. Or a bad IC on the board. Good luck with doing a swap.....
                                      Arc A770 16 GB
                                      • joshnz
                                        • Feb 2011
                                        • 969
                                        • New Zealand
                                        I will see if errors are all over or just in one loacation to me it seems like there is head failuer I wil do tests on start of drive errors were occoring on last third.
                                        Been a 3TB drive it takes some time to do end to end scan.
                                        Smart extended test passes so that no help
                                        My pc
