Dell Inspiron 1721-Battery Works-A/C not
  • gigabyte
    • Jan 2014
    • 11
    I would appreciate any help here. Hopefully someone else had this happen. I have a Dell Inspiron 1721 that will work just fine when using battery for power, but when I plug in the A/C adapter it will not see the battery or use the power from the A/C adapter.
    If I remove the battery it will not power on, nor does it charge the battery. I did not see anything burnt or otherwise obvious. Any help would be great!! Thank you
  • dj_ricoh
    • 2073
    • uk
    Re: Dell Inspiron 1721-Battery Works-A/C not
    check the FETs near the charging port
    • proman28
      • May 2014
      • 9
      • uk
      hi
      and please resolder the dc jack even if solder looks ok.
      • gigabyte
        • Jan 2014
        • 11
        Thank you-I will try it
        • Agent24
          I see dead caps
          • Oct 2007
          • 5037
          • New Zealand
          Doesn't Dell use a 1-wire ID system in their power supplies, and if that goes faulty the adapter won't be detected by the BIOS and won't work?
          -David VanHorn
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            Yes, but IIRC that throws an error.
            gigabyte, have you tried another dell brick? If you were local I'd hook you up (I'm the Dell Latitude D series hoarder of the greater Louisville area )
            sigpic
            (Insert witty quote here)
            • dj_ricoh
              • 2073
              • uk
              o snap had the same problem with a samsung notebook.
              it had water dmg near the charging IC
              • gigabyte
                • Jan 2014
                • 11
                I ordered one this week-hope to get it within a few days-let you all know-Tnx
                • gigabyte
                  • Jan 2014
                  • 11
                  Thank you for the response - I did re-solder and that did not correct it. I will replace it and see if that fixes it. Txs
                  • Bowline
                    by Bowline
                    06-11-2025, 10:13 AM
                  • danielsak
                    Dell Inspiron 3542 (Cedar_Intel-MB 13269-1) - RTC battery self-discharging and Realtek LAN issue
                    by danielsak
                    Hello, I have issue with Dell Inspiron 3542.
                    Motherboard marking:
                    Code:
                    PWB FX3MC REV: A00
                    The laptop works just fine (on battery and power supply) and doesn't cause any problems, except those described below:
                    1. The first problem is that the RTC/CMOS battery self-discharges after about 2-3 weeks after installing a new battery. I have been installing different batteries (GP, Duracell, Energizer) and the problem still exist.
                    1. The second problem is the LAN network card (Realtek RTL8106E), which is not detected at all in Windows. The BIOS is
                    10-11-2024, 04:36 PM
                  • ipatch
                    dell inspiron 5567 laptop battery lipo WDX0R
                    by ipatch
                    recently i was gifted a dell inspiron 5567 for wiping the data on the hard drive. (yay me). however i already have a computer that i use, so i have no need for this computer. this computer wasn't without its problems though.
                    1. i had to purchase an adapter to retrofit my older style dell laptop battery cable. (not too expensive) ~= 10 bucks for a 2 pack via amz.
                    2. after that i had to find a spare cr2032 (easily found in my parts bin) and assemble a makeshift cmos battery thanks to some copper foil tape and some heat shrink tubing.
                    got the computer...
                    04-02-2023, 04:45 PM
                  • lawrenceptrini
                    Battery not charging - Dell Inspiron 3593 FD155 LA-JO81P (REV 1.0) (A00)
                    by lawrenceptrini
                    Hi Guys,
                    I am seeking some assistance with a Dell Inspiron 3593 FD155 LA-J081P (REV 1.0) (A00) laptop
                    The laptop is working fine with the adapter plugged in and also with a charged battery.
                    Problem is that the laptop is not charging the battery. The battery is recognized in the bios but the
                    ac adapter is listed as 'Not Installed'. So for instance, when a charged battery from another source
                    loses its charge, it stays on 0%.
                    Measurements taken
                    Charging IC (ISL95522HRZ) 32 pins
                    Voltage to ground with ac adapter only plugged in:
                    1)...
                    08-26-2024, 06:45 PM
                  • HTR-Informatique
                    Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
                    by HTR-Informatique
                    YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
                    I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
                    On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
                    I also changed the screen because the PC fell and the screen was broken.
                    I changed the battery with a new and original battery.
                    I also had corrosion/oxidation on the...
                    02-09-2025, 06:51 AM
