Xubuntu 14.04 logs out instead of shutdown!
  • ivtec
    • Dec 2008
    • 1967
    Hi guys : i've been having this shutdown issue,some times i click in the icon in the corner to shutdown it presents me with 4 solutions,log out, Restart,shutdown,suspend,i click on shutdown and it goes to logout menu, it seems it only happens on my Dell P4 32Bit, i have a Lenovo I5 Intel desktop with the same Xubuntu 14.04 except 64bit and it doesn't do that,
    I've posted this before,no solution,has anybody encountered this issue and anybody has a solution?thanks in advance.
    frank@frank-DIM4500:~$ apt-cache policy xfce4-power-manager
    xfce4-power-manager:
    Installed: 1.2.0-3ubuntu4
    Candidate: 1.2.0-3ubuntu4
    Version table:
    *** 1.2.0-3ubuntu4 0
    500 http://us.archive.ubuntu.com/ubuntu/ trusty/universe i386 Packages
    100 /var/lib/dpkg/status
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Xubuntu 14.04 logs out instead of shutdown!
    probably a bug. All your packages up to date? If not, either check in software center... or run:
    Code:
    apt-get update; apt-get upgrade
    If you do the latter and get any errors, post them.
    (I am more of an arch expert, but I still have a headless debian server I maintain and used to use ubuntu).
    sigpic
    (Insert witty quote here)
    • mockingbird
      • Dec 2008
      • 5484
      More than likely something got deprecated or changed dramatically since the last properly functioning distro for such an old system. It's common with Linux. They don't go back and check compatibility with every scenario.
      If you go to a console (CTRL+ALT+SHIFT Fx) and type "shutdown now", what happens?
        • 31015
        the user account does not have access rights to use the shutdown command probably.
        it was a common problem in the past.
        open a shell,
        type "reboot" and hit enter.
        it should reboot.
        now open a shell and type "shutdown -ht1 now" and hit enter.
        it will probably ask for the root password - that's your probem.
        • ivtec
          • Dec 2008
          • 1967
          open a shell,
          it should reboot.
          Thanks, when i do!
          frank@frank-DIM4500:~$ sudo shutdown -ht1
          [sudo] password for frank:
          shutdown: missing argument: -ht1
          Try `shutdown --help' for more information.
          • ivtec
            • Dec 2008
            • 1967
            Thanks. What is Shift FX?
            if i do 'sudo shutdown -h now' it turns off,
            also it's not always that it doesn't shutdown, also when it logs off i'm presented with a log on xfce desktop that contains all the icons like shutdown and others ,if i click on the shutdown icons it shuts down all the time if not i put on my password and log in again and the i click on the shutdown and it shuts all the time,
              • 31015
              CTRL+ALT+SHIFT and a function key.
              F1>F9 will open a new shell
              F6&7 are often already used by X11
              to switch shell's wile in one jus use ALT and the function-key
              • ivtec
                • Dec 2008
                • 1967
                CTRL+ALTHIF+ST and a function key.
                Thanks stj; pressing any of these keys does nothing in this dell p4 pc!
                  • 31015
                  that makes no sense.
                  from the graphical desktop,
                  hold CTRL+SHIFT+ALT and press F1
                  tell me what happens.
                  • goontron
                    5000!
                    • Dec 2011
                    • 4108
                    • US
                    hmm, i thought it was CTRL+ALT+F# for a US keymap?
                    at least that's what it is with SUSE 13.1, Ubuntu GNOME remix, Centos, elementary OS, Linux MINT, and Arch.
                    Follow the white rabbit.
                      • 31015
                      yur right, i was thinking about something else when i posted.
                      • ivtec
                        • Dec 2008
                        • 1967
                        Thanks stj; it does nothing,
                        i also notice when i click on the shutdown it goes to a logout screen it has
                        Xf icon = languishes, shutdown icon
                        XF icon opens option; Xfce and Xubuntu secessions,which doesn't make any difference ,and also can choose guess,Notice i have it to log in automatically,so i don't have to log in every time i turn on pc,why should i go through the log out/log in process every time i turn off pc is beyond my comprehension, some is not right, i had xubuntu 12.04 and never had these issues in this Dell P4.Maybe i should get rid of xubuntu desktop and install just XFCE?do you know how without having to make a fresh install!
                        if i click the shutdown icon it presents me with log out,restart, suspend, shutdown, it shuts down from there, this is in log in screen.
                        • cruiser_
                          A1466 820-00165 intermittent shutdown
                          by cruiser_
                          hi there,
                          Got this macbook after liquid damage. Nothing major, cleaned and reflowed what was suspect. Now, the laptop turns on and boots up but shuts off intermittently - sometimes after a few minutes, sometimes after a few hours.
                          Can be immediately started from keyboard right after. Plug stays orange during this time. No battery.
                          Gives shutdown cause -128.
                          Seem to work fine in SMC bypass.
                          Same shutdown happens with disconnected TP/KB/KBLED/CAM.
                          Observations:
                          - SMC_RESET_L - when pulled down - plug goes orange/green and...
                          10-11-2022, 12:06 PM
                        • RATIM SIDDIQUE
                          hp fpw50-la-h323p rev 1.0 automatic shutdown after 30 sec, need help
                          by RATIM SIDDIQUE
                          automatic shutdown after 30 sec of display coming
                          do not shutdown without ramstick
                          someone give me idea plz
                          08-20-2024, 03:50 AM
                        • howardc64
                          P502UI-B1E shutdown automatically after 75s followed by power light blinking 15x
                          by howardc64
                          History
                          - Got TV free. Prior owner claims Vizio logo shows up then nothing. He found U202 EEPROM replacement info (I know NickTV says its never EEPROM haha). Lifted 5 pads removing U202 without proper tools and thought thats end of main board. Gave the TV to me.
                          - I repaired U202 pads and connections. Soldered on prior owner purchased aftermarket EEPROM (original EEPROM was tossed). TV boots to VIZIO logo, then goes blank, shutsdown after a min or so and power on light blinks a number of times.
                          - Fixed 2 circa 2015 Vizios before with classical main board...
                          11-28-2020, 04:25 PM
                        • ronelex
                          Acer MS2304 Shutdown when HDD or ODD Present
                          by ronelex
                          Model: Acer MS2304
                          Board Code: 09920-2
                          Issue: Unit Powers On with Display Without HDD or ODD attached
                          When ODD or HDD is present unit powers on then Shutdown it reaches current of 1A that looks like want to boot but it will shutdown
                          Unit wont shutdown when ODD or hdd attach if no ram is attach also
                          I have tried flashing bios, the only different it will not shutdown immediately reaching 1A but eventually will shutdown also
                          05-15-2021, 01:28 AM
                        • IamPritesh
                          Help - Auto starts after 1 minute of shutdown - Dell vegas/turis 15341-1
                          by IamPritesh
                          I have two such machines which is having this issue. After shutdown the system starts on its own in a minute. It does not start immediately. It takes around 20-40 seconds before it starts again on its own. This is driving me crazy and not sure where to start ..
                          Some very important points :
                          • Laptop does not auto starts after shutdown if adapter is connected.
                          • It will only auto start after shutdown if the laptop is in BATTERY only mode.
                          • I have tried replacing batteries with a known
                          • if I shutdown the laptop with adapter connected and lets say remove the adapter after 5-10
                          09-24-2021, 05:01 AM
