Acer MS2304 Shutdown when HDD or ODD Present
  • ronelex
    • Oct 2016
    • 195
    • Philippines
    Model: Acer MS2304
    Board Code: 09920-2
    Issue: Unit Powers On with Display Without HDD or ODD attached
    When ODD or HDD is present unit powers on then Shutdown it reaches current of 1A that looks like want to boot but it will shutdown
    Unit wont shutdown when ODD or hdd attach if no ram is attach also
    I have tried flashing bios, the only different it will not shutdown immediately reaching 1A but eventually will shutdown also
  • Sametbey
    • Jan 2021
    • 229
    • Turkey
    Re: Acer MS2304 Shutdown when HDD or ODD Present
    Have you tried booting with Live Linux on a usb flash drive? Is there any component that draws excessive current on + 5V ALW?
    I'm not happy to be so strong. because it's not humanly
    • ronelex
      • Oct 2016
      • 195
      • Philippines
      not yet tried to boot live linux, 5v rail is ok, it will just shutdown if odd or odd is attached i tried other odd and hdd same issue
      • Sametbey
        • Jan 2021
        • 229
        • Turkey
        Have you tried it with a blank hard drive. If it shuts down while trying to boot windows from the hdd, you may have a VGA chip problem.
        • ronelex
          • Oct 2016
          • 195
          • Philippines
          Done, thank you, suddenly upon testing the main reg failed, the ldo output are missing so I tried to replace to a new and the shutdown issue solved, thanks a lot
