Ammo needed for rmr (mosfets)
  • Vodka
    • Jun 2007
    • 6
    Hi everyone. I recently had some really bad luck with an asus p5n32-e sli. The mosfet above an optional fan pin exploded, closer inspection of the board revealed a somewhat tarnished color on the printed part listed as sata(near the io shield). As I have no clue what happened, what hypothetically would cause this? And is it all on the user end in terms of errors?
    psu is a thermaltake toughpower 850 watt
    And any place where metal on the riser pin areas could short were covered by mylar.
    Any info will be very much appreciated, as I just spent a good deal of change on this new system, and I'm hoping the problem is only the mobo.
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Ammo needed for rmr (mosfets)
    pics would be useful
    • Vodka
      • Jun 2007
      • 6
      This is the best i can do, cause the boards in the mail. opt fan 4 pin is 1st white pin to the left of satas in figure 9. And the browned part is labeled esata12 straight above the top most fin and 1st right next to the cap.
      hope that makes sense. :/
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        going where?
        • Vodka
          • Jun 2007
          • 6
          newegg, I haven't even had the board a month.
          • Vodka
            • Jun 2007
            • 6
            Forgot to mention, the board gets power, but prior to it being dead, I was was getting ide detection errors, random restarts, memory detection errors until finally it would continually restart, lockup on windows screen and then I didn't even get a post screen or beep.
            • pentium
              • Mar 2006
              • 2778
              Classic signs of badcaps.
              Find Nedry!
              Check the Vending machines!!
              • Vodka
                • Jun 2007
                • 6
                Can bad capacitors cause a mosfet to blow up though?
                • starfury1
                  • May 2006
                  • 1256
                  short circuit would destroy a Mosfet
                  if its nothing you have done
                  and its been playing up since you got it them most likely a dud MB
                  If you have RMA'd it then hopefully it it will be replaced under warrenty
                  Someone posted about they were surprised at the amount of MB being sent back to Newegg with faults.
                  without really knowing which parts died or knowing the MB its hard to guess what happend
                  pictures of the actual board may have been of help,but its in the mail now.
                  since you say its less then a month old,
                  MB fault and something possibly with a power rail in the area of the esata.
                  maybe some low resistance intermittent pcb track fault
                  Thats only guess work on my part and there are others that might have a better idea
                  A faulty cap, possibly but doubt it
                  like I said only guessing and this is provided it isn't something you have inadvertently done. (it happens to the best of us at times)
                  Hope they give you a new one thought...
                  it doesn't look like a cheap MB
                  which is a bit of a worry if it was supplied faulty
                  Anyone of our regular system builders, noticed an increase of new MB being Faulty from box?
                  For that matter the quality of MB's builds getting worse?
                  • willawake
                    Super Modulator
                    • Nov 2003
                    • 8457
                    • Greece
                    just an increase of people posting about their faulty boards on the net
                    • pentium
                      • Mar 2006
                      • 2778
                      I have.
                      Everyone at school knows me as the computer god so they always go to me. Within the last few months a few builders are telling me that they have had dead boards right out of the packaging. The caps are good and their tester cards usually show failures ranging from voltage all the way to a dead north bridge.
                      I personally question my K7N2 Delta2 which shows no visual faults or problems. and is stocked with good caps.
                      Find Nedry!
                      • Vodka
                        • Jun 2007
                        • 6
                        Thank you guys, you've all been very helpful. Just gathering the info in case newegg contacts me. And The board was pricey, hence my reservations about rmr (too much fine print when returning electronics). But newegg has a good rep, so I'll cross my fingers. I find it kind of strange that the board died 5 days before I'd have to contact asus for service.
                        • BlackScreen_22
                          Harman Kardon sub TS11 (ds15 amplifer) blows fuse and mosfets
                          by BlackScreen_22
                          Hi, I'll start by saying that I'm not an expert and I've reached a point where I don't know what to try/do anymore...
                          Starting from the beginning: I opened this subwoofer for the first time with a very strong smell of burnt electrical components, I realize that on the amplifier board there is a hole between V+ OUT and GND about the size of a finger, the damaged components were the shorted mosfets, two damaged zener diodes and two capacitors. I bought everything, I fixed the hole by cutting the pcb and putting a piece of a perforated board.
                          I had no problems connecting mosfets and capacitors,...
                          08-27-2024, 12:46 PM
                        • kotel studios
                          Intel D865PERL - no Vcore after replacing MOSFETs and MOSFET drivers
                          by kotel studios
                          Finally got time to fix this board up.
                          At first it didn't give any POST codes. Turns out it was an unsupported Celeron D cpu. After dropping in an Celery 2.6gHz the CPU came out of reset with clock signal, but still no post codes. For a while it did work when I applied pressure to the ADP3168 chip, but on next reboot the MOSFETs started to burn. Then I left it as is for months.
                          Now I came back prepared. Replaced the bad MOSFETs and the ADPxx18k drivers. Now I don't get any MOSFETs blowing up issues anymore. But sadly, the Vcore is missing. The whole VRM isn't...
                          04-22-2025, 05:08 AM
                        • flerre
                          Gainward Phantom GTX 980 - mosfets w/ integrated driver NCP5369
                          by flerre
                          Hi!
                          Managed to get a Gainward Phantom GTX 980 in an auction for a bin with components.
                          No video out so I started fault finding and found a blown fuse for 3 mosfets. Started checking for shorts and found what I think is a short through all of those 3 mosfets; 0.1 ohms between "VIN" input and "VSWH" output. All mosfets in this gpu are the same ones (NCP5369) with integrated drivers and when I tried measuring the other ones through these ports they were somewhere in the kilo-ohms range.
                          So, could I safely assume all of these 3 mosfets are...
                          03-13-2022, 12:14 PM
                        • DrDos
                          kenwood kr-6030 Mosfets?????
                          by DrDos
                          Hello everyone, I have decided to try and replace the mosfets in my power amp (the one with relay and left and right sides) on my kenwood kr-6030. I'm trying to get the A side of my speakers working. I have replaced all the caps in the power board and I thought why not change the mosfets. They seem to be working since I have great music coming out of the B side speakers and since I am not an electronic guru (but I am learning) I don't want to make any mistakes. The mosfets I have are listed A913 so I guess 2sa913 and 2sc1913. Can't really find those in mouser or digikey at least with the info...
                          09-20-2025, 04:42 PM
                        • NanoTesting
                          Lenovo Ideapad 15IIL05, turns on and off with charger BUT works by injecting 20v after main mosfets
                          by NanoTesting
                          I got a 15-IIL05 that failed to turn on BUT IT DID TRY TO TURN ON and then turned off after 30+- seconds, i disassembled it and found a screw loose inside the case.
                          With charger it turns on, fan spins but gives no image.
                          Tested main mosfets no short, tested 3.3v,5v,DRAM, CPU etc and they were present.
                          Reflashed BIOS, same problem.
                          Replaced both main mosfets.
                          Checked main mosfets again and i noticed that they closed once the laptop shut down, so i decided to bypass them and used a bench PSU to check how much power the laptop was drawing while trying to turn on, 20v@3A,...
                          10-30-2024, 10:48 PM
