Running CCD cameras from a PC PSU
  • Maxxarcade
    • Jul 2006
    • 973
    I have a Linux based DVR setup which I am soon upgrading the cameras on. I just bought 4 Sharp 1/3" CCD cameras off ebay that require about 400ma each, at 12V DC.
    I was hoping to simply run them from the DVR PC's PSU, which is a 300W Sparkle. My only concern is about noise coming from the PSU and affecting the picture. Can I just add another 2200uf or so low-esr cap in parallel with the 12V output, or will it cause problems with the PSU? I was just going to mount a barrier strip on the back of the PC for making a 12V bus for all the cameras, and just put the cap on that.
    EDIT: Oops, wrong topic... Should have probably posted this on the power supply forum.
  • gonzo0815
    • Feb 2006
    • 1600
    Re: Running CCD cameras from a PC PSU
    The problem is probably not the noise from the PSu, than probably the noise from the HDD`s and other 12v supplied HW.
    I have done this with the 5v and the 12v rails of my older system, to power the speaker and my USB hub with that and eliminating those cheap & hot wallplugs and clear off the mess on the desk.
    The USB hub does not have any problems with that, but my cheapo speakers get disturbed from the elektronic garbade produced by HDD`S adn GFX card.
    So there was a permanent humm probably the dc HDD motor and some fans.
    Additionally i could hear the mouse pointer moving and some other gfx related things there.
    I tried to fixe this by adding some ultra low esr caps, a coil (first some small coils, then the biggest one i have had in the junk box) and a few small HF ceramic caps to form a pi filter.
    But without succes.
    The system was not affeckted from the capcitance, as long as you do not attache them, when the system is running (i think this is obviouse).
    The other aspekt is, that you do not overdo it, as the ATX spec defines a max startup capacitive load.
    From my point of view, i would say, the only way to clear off the noise & garbage from the line, would be a linear voltage regulator sutch as the 78xx or LM317 or the low drop alternatives.
    A linear voltage regulator has very high noise rejecktion, if properly build.
    As the 12v is already the lower limit for my speakers, i could not do that, whitout putting in a step up circuit first (wich was a littel to mutch effort, to eliminate one wallplug...)
    Botom line: any digital device should work fine with the noise & garbage, but analaog circuits wich have some kind of amplifier in it are not easily decoupled.
    • dood
      Deputy dood
      • Mar 2004
      • 2462
      We used to run all our cameras off of an old AT PSU, before we upgraded to a real power center. It drove the cameras fine, but that's all it was doing, it wasn't powering anything except the cameras. Perhaps this would be a better route to take. I'm sure you can dig up an old AT PSU somewhere
      Ludicrous gibs!
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        it will work fine.
        i added a small blaupunkt car stereo amp to a garage pc so a friend could play her mp3's with some real speakers attached.
        had to put a 3300@16 lxz right at the amp to get rid of hdd whine at startup.
        no problem running full volume with this 40x2 amp on a cheap dell desktop box.
        • MegaZAC
          Onkyo TX-SR805 noise in one channel
          by MegaZAC
          Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
          Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
          There's some logic behind it. As soon as I select an input I get only left...
          04-23-2025, 10:09 PM
        • courtcircuit
          Philips HTS8000 home cinema noise problem
          by courtcircuit
          Hello
          I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
          Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
          Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
          I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
          Removed each of tyhe boards
          02-08-2025, 08:22 AM
        • FALKLAN
          Running Line Voltage and Integrating LED Pods - Automotive
          by FALKLAN
          Howdy everyone! I hope all is well where ever you are!
          I'm attempting to integrate a couple of LED pods into an automotive reverse lamp circuit. The problem being, while the vehicle is running there is a 8.5v current present on the reverse lamp power wire. Needless to say is that all LED pods and lights dimly illuminate while the 8.5v is present, so the LEDs are always powered on while the vehicle is running. When the vehicle is shifted into reverse, the voltage changes to 12 volts.
          I am uncertain how to convert this line into a switched 12v output line for the LED pods....
          02-05-2025, 12:30 AM
        • karatzdi
          Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
          by karatzdi
          I know some might say... just buy another one. Sell it as parts..!
          So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
          Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
          Spent some time downloading the Service...
          06-11-2024, 08:38 AM
        • tony359
          by tony359
          11-28-2023, 05:18 AM
