Killed a 1TB hdd
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Killed a 1TB hdd
    It appears my samsung (seagate) ST1000LM024 died. It doesn't spin up and the motor tries to start but makes a nasty sounding fast weh-weh-weh noise for a few seconds before giving up.
    it was being unreliable earlier... but now it's done. But then, it was spinning up...
    What sucks is that it was an external drive (pulled from an upgraded lenovo P400 and put in an arctic cooling enclosure) and I pocketed it yesterday while moving it... I guess that may have been what killed it... then again, before I moved it, it suddenly quit copying files (it was a hot enviorment and I assumed it overheated)... great, bye bye nice drive and my backup data (the imortant parts seemed to have copied before the failure).
    Since it was pulled from a laptop that I bought used, does that void any samsung/seagate warranty? The drive was made in 1/'13. Or do I have any recourse to get a fresh drive?
    sigpic
    (Insert witty quote here)
  • c_hegge
    • Sep 2009
    • 5219
    Re: Killed a 1TB hdd
    HDDs that are supplied to manufacturers never have a warranty to void in the first place. You have to get the manufacturer of the laptop to deal with it.
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      one thing about seagate: they run hot, but they dont like hot!
      according to research done by google the best temp for an HDD is around the 32c mark. https://cdn.badcaps-static.com/pdfs/...0fb92118d6.pdf
      Follow the white rabbit.
      • cheapie
        null
        • Jul 2010
        • 849
        The only drive I've ever seen self-destruct due to heat was a 250GB WD Caviar SE desktop drive. All of my Seagates run cool.
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          That's what I thoguht. Damn. Being pulled from a lenovo, I'm SOL since it's not still in a laptop with a non-void warranty (any hardware change requires breaking the warranty).
          Anybody want a dead 1TB?
          sigpic
          • ant3202
            • Jun 2006
            • 275
            • Singapore
            i have less luck with seagate..... somehow.... NAS keep reporting on failing HDD (seagate), even replacement barely stays long, shortest is about 5 mins and it turned red. ...
            fed up and changed all to HGST.... solved.
            also hit by 7200.11 issues badly...
            • shovenose
              Send Doge Memes
              • Aug 2010
              • 6575
              Keep in mind that laptop was dropped at least once... But I never had problems with the drive. That said, it may have lead to a premature failure.
              • jetadm123
                • 2169
                Since you bought the laptop used, it may not be the original drive that came with it. Regardless, I suggest you go to Seagate's website and enter the serial number to see if there's any warranty coverage.
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  It is the factory drive.
                  sigpic
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    Smart indicated no issues prior to enclosuring the drive... But yup, that's the drive.
                    sigpic
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      FML. Seagate says for this drive "contact the OEM". Which means lenovo will tell me to fuck myself as I didn't play nice with the warranty.
                      IMHO it's a bunch of BS since this wasn't an OEM specific model (or OEM specific labeled from the factory). It's ultimately their part they made, so they should honor it IMHO. Since I voided lenovo's warranty but not Seagate's (if it were a retail drive), Unless no warranty was part of the deal between lenovo and seagate (which if it was, another FUCK YOU to lenovo), I really think it's a bunk policy.
                      sigpic
                      • mockingbird
                        • Dec 2008
                        • 5488
                        Seagate drives are in a class of their own above any other consumer drive on the market. You just have to know which models to get and how to set them up before you start using them.
                        That being said, I successfully RMA'd a Samsung manufactured 2.5" Spinpoint a while back (More than a year ago). I got back a Seagate branded model. Having said that, they changed the RMA system now that the websites have merged, and I don't know exactly how to RMA Samsung drives through Seagate (Could never get it to work).
                        You can probably RMA that drive. I don't think Samsung kept records of which drive was sold as integrated and which were OEM/Retail. If you can't check the warranty status on their website, then call them up and clarify it. If you are asked whether this drive was purchased apart from the system, then remember the old dictum that "You cannot lie, but you are not compelled to offer the truth".
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          They did keep records, as my serial number came up as "See your OEM for warranty info; no warranty through us" when I tried it on seagate's site. So no, I can't RMA it as it's a serial number they won't honor. I was pretty pissed to put it lightly at it, trust me...
                          sigpic
                          • ratdude747
                            Black Sheep
                            • Nov 2008
                            • 17136
                            FUCK YOU LENOVO.
                            My warranty was only 1 year. The drive in retail packaging ($70 at newegg) has a 2 year warranty from samsung (seagate). The drive is the EXACT same model as the retail drive... This is a racket if I've ever seen one...
                            sigpic
                            • Heihachi_73
                              • Jun 2012
                              • 713
                              Seagates aren't supposed to run beyond 32°C? My old 60GB has been running 24/7 at over 50°C for over half a decade! Even at the start of Australia's winter it's running at 51°C (according to SpeedFan) without the heater even being turned on.
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8716
                                I'm not surprised at this, IBM/Hitachi does the same thing with their OEM drives, I tried to get an RMA for an Travelstar years back and it said "see OEM"...whose warranty had expired already by then. I get a magnet out of that drive...
                                The OEMs get a great discount out of these drives but when they fail early, the consumer gets the short stick.
                                • goontron
                                  5000!
                                  • Dec 2011
                                  • 4108
                                  • US
                                  Not seagate in perticular, just any drive in general.
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    Yeah, hence my high level of pissativity. I guess it's a good thing I put in an different drive (a 120GB SSD) or the whole laptop would be screwed. I still don't get the ethics in making a mid-high level consumer laptop non-upgradeable w/o breaking the warranty sticker... that's BS.
                                    sigpic
                                    • cheapie
                                      null
                                      • Jul 2010
                                      • 849
                                      I don't use hard drives as boot devices (at least in my computer). I have a 120GB Seagate Barracuda 7200.7 (IIRC) drive being used for backups. It has had one reallocated sector for a few years now, and no signs of getting worse. It spins up for about 3-5 minutes per day. I also have a 500GB Toshiba laptop drive that has data that I don't really care about. It spins up for 5-10 minutes every few days (basically whenever I want something from it). Neither one has seen temps over about 32 degrees (C) ever since they were retired from boot usage.
                                      My sister, however, has a 160GB Seagate Barracuda 7200.9 as her boot drive. It usually runs around 35-40 degrees, depending on usage. It's spinning 24/7, as her SATA controller gives all sorts of CRC errors if the drive is allowed to spin down (it's the controller, not the drive).
                                      My mom has a 500GB Seagate drive in her laptop. It's used about 2 hours/day. It runs the hottest out of all of our drives, but I've never measured the temperature. About 2 months after she got the computer, the drive started clicking and the computer randomly froze. Eventually, it reallocated 5 sectors and has worked fine ever since (over a year now).
                                      • brethin
                                        • Dec 2008
                                        • 1907
                                        Send me a bill via paypal for the shipping and I will look at it. If I can repair it or get it replaced I will let you know if not I will use it for parts.
                                          HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green EliteDesk 800 i5-7500 Specification for Upgrade or Repair
                                          This specification for the HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green boardview and EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                                          09-12-2024, 02:00 PM
                                          HP ProBook 430 G7 + Seagate Expansion 1TB Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 430 G7 + Seagate Expansion 1TB Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + Seagate Expansion 1TB boardview and 430 G7 + Seagate Expansion 1TB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-06-2024, 08:10 PM
                                          HP ProBook 450 G7 + Seagate Expansion 1TB Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 450 G7 + Seagate Expansion 1TB Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G7 + Seagate Expansion 1TB boardview and 450 G7 + Seagate Expansion 1TB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
