Remove thermal compound from AM2+ socket
  • Uniballer
    • Jul 2013
    • 334
    I bought an AM2+ motherboard with a low-end CPU on ebay. It works fine, but I need to upgrade to a better CPU. When I tried to take the heatsink and fan off I found it was really stuck, but eventually I got it to slide off. There is about 10 times the right amount of some unknown thermal compound, and it is on the edges and some pin holes of the CPU socket. It does not dissolve in isopropyl alcohol. Seller says someone built the computer for him, and he was not aware of the issue, nor what compound was used.
    So how do I clean up the socket? Flush it with ArctiClean and pray? Or is there a better way?
  • Compgeke
    • Feb 2014
    • 524
    Re: Remove thermal compound from AM2+ socket
    I would give it a wash in the sink then let it dry for a bit. The water pressure will hopefully be enough to clean out the holes.
    Afterwards let it sit a day or two to dry in the warmest part of the house such as by a heater or something.
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      Try and get some of the compound off and see what it will dissolve in?
      • brethin
        • Dec 2008
        • 1907
        I use 2 things one of which normally work depending on the compound I am removing.
        Isopropyl Alcohol (rubbing alcohol) or Acetone (nail polish remover).
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16956
          That works....but be careful with the acetone on a plastic socket, it will melt/disfigure it, so use it very lightly and carefully.
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
          • Uniballer
            • Jul 2013
            • 334
            I don't think washing the stuff further into the socket is a good thing to try. And I'm a little nervous about some solvents on plastics.
            I managed to get the socket apart without breaking anything. I found this link, which was helpful. So I removed the heatsink retaining bracket and pulled the lever out of the ZIF socket. Then I pried the edges of the top (sliding) part of the socket out very slightly with a dental pick until I could separate the parts. Now I can clean the individual pin contacts still attached to the board as well as the pin holes in the sliding part of the socket.
            Obviously, I'm not finished at this point so I could still break something trying to put it back together, or dissolve one of the pieces of plastic with the wrong solvent. Wish me luck.
            P.S. I wish I had known more about how to get the ZIF socket apart without breaking it when I was dealing with the broken AM3+ socket. I might have been able to replace the socket top without having to RMA the board.
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16956
              If the board is functioning then, just leave it there. the stuff is non-conductive, so its not going to cause a short or a catastrophic meltdown. Clean it up as best you can and run with it.
              Team : 49813
              Join in!!
              Team Stats
              • Uniballer
                • Jul 2013
                • 334
                This worked out rather well. It was much easier to clean the socket parts when they were disassembled, and reassembly was no problem. Thanks for the input.
                • Mad_Professor
                  A Mech Warrior
                  • Feb 2011
                  • 1587
                  I remembered my first experience with acetone. I had a cheap casio watch, which was a good watch since the battery never seem to die and kept time to the tee. I got paint on it one day and it dried. I couldn't get it off so I ask my grandmother what I could use to clean it, she give me a can of acetone, so I pour a little into a bowl and dip the watch and about minute later the watch melted, the lens was all disfigured and everything I mean it was piece of work from salvador dali. The watch still work though but you had to look at it like a piece of art and try to figure out what time it was.
                  • brethin
                    • Dec 2008
                    • 1907
                    Again it's about knowing what you are doing. I said Acetone (nail polish remover) which is diluted to be safe with plastic (ie fake fingernails and has never caused any socket or plastic part on a motherboard to melt on me). Yes straight 100% Acetone can melt plastic. Anything you use can be bad not used correctly.
                    • Uniballer
                      • Jul 2013
                      • 334
                      I tested the ArctiClean product on parts from an old Pentium 4 socket (478) because it seemed to be made from identical plastic (probably a polyamide - i.e. similar to nylon). There was no problem (ArctiClean instructions warn that it damages styrene). So I used it after all the mechanical cleanup I could manage. After using both ArctiClean chemicals per their instructions I washed any residue away with isopropyl alcohol. I reassembled the socket after all the alcohol had evaporated.
                      • howardc64
                        by howardc64
                        Problem
                        08-04-2024, 10:36 PM
                      • Gcnewbie
                        Dell Latitude 5570 Ambient thermal sensor reading -127 Degrees C
                        by Gcnewbie
                        Forgive me this is my first request for help on this forum, so if i've screwed up or not followed the rules i should have i apologise profusely.
                        I have a Dell Latitude 5570 that was randomly shutting down, on further investigation i found that the machine had been shutting down due to thermal events as noted by windows event viewer.
                        My investigations lead me to the dell diagnostics screen, where i found that there were two sensors out of range which had been causing the shutdowns, one of which was the GPU thermal sensor and the other the ambient sensor.
                        I opened the...
                        03-29-2024, 06:55 AM
                      • Veyron7887
                        Laptop overheating after replacement thermal paste
                        by Veyron7887
                        Hi. I have Asus X55C laptop from year 2013. It has i3-2328M CPU. I replaced stock thermal paste with high quality thermal paste. Before thermal paste replacement, I measured CPU temperature Around 65-70 degrees Celcius with stock thermal paste. If after the replace thermal paste, I measured CPU temperature around 80-84 degrees Celcius and fan don't stop when system is idle. I replaced the thermal paste several times but still did not change. Where is the problem?
                        11-24-2024, 05:08 AM
                      • warsztat
                        Acer AN515-57-577G JDIMM1 socket not working.
                        by warsztat
                        Hello, Acer AN515-57-577G JDIMM1 socket does not work. GH51G LA-L181P, 2x DDR4 RAM, both good, both work well in JDIMM2, neither works in JDIMM1. The laptop displays BIOS, when the JDIMM2 socket is occupied, you can run Linux on USB, then everything seems to work ok, there is internet access and you can browse the contents of the 512 GB SSD in Windows, but starting Windows ends with an eternal spinning circle, maybe there are corrupted files. When the RAM is inserted into the JDIMM1 socket, the laptop starts but there is no image and the downloaded current does not change and the output is ~2.25A....
                        11-18-2024, 09:13 AM
                      • longmt1990
                        Panasonic Cf-w5 bios password remove
                        by longmt1990
                        Hi, i have a Panasonic Cf-W5 with the bios password, I tried remove cmos but problem didnot solve.
                        I uploaded the picture after remove cmos battery, It look like this is a Phoenix bios. The bios dump file in the link i attached
                        Please help me remove bios password.
                        Thank you so much
                        07-06-2025, 10:50 PM
