MSI KT4AV not booting.....at all.
  • Dan81
    SNES-powered
    • Oct 2013
    • 1865
    • Romania
    Well,I've got myself a KT4AV for using it as a spare 3rd system (mainly for late DOS/1998-2004 gaming)and it doesn't post at all.
    I tried 3 CPUs and 2 types of DDR memory,nothing worked.
    There is absolutely no bad cap,as the board is all full of Panasonic caps,along with Sanyo caps.
    Any ideas?All 3 CPUs are good,and have been tested before.
    The CPUs are a 950MHz Duron,an Athlon XP 1700+ and a Sempron 2400+.
    Main rig:
    Gigabyte B75M-D3H
    Core i5-3470 3.60GHz
    16GB DDR3-1600
    Samsung SH-224AB DVD-RW
    Delux MG760 case
  • tmiha71
    • Apr 2010
    • 130
    Re: MSI KT4AV not booting.....at all.
    Test them again, in known good mobo... Chances are - that they're good no more, after being in that board...
    As suggestion, try to poly-mod that board, there's group of 5 vrm-out (put here 4 poly's 820uF or higher) caps and group of 3 vrm-out caps (put here 2 poly 820uF or one size lower)...
    • Dan81
      SNES-powered
      • Oct 2013
      • 1865
      • Romania
      I have tested them before in a K7VZA,and all POSTed.
      And why to poly-mod it if there are Panasonic and Sanyo caps,which are already good?
      Main rig:
      Gigabyte B75M-D3H
      16GB DDR3-1600
      Delux MG760 case
      • mariushm
        • May 2011
        • 3799
        Check for shorted mosfets..
        • Dan81
          SNES-powered
          • Oct 2013
          • 1865
          • Romania
          Checked it,none are shorted.
          Main rig:
          Gigabyte B75M-D3H
          16GB DDR3-1600
          Delux MG760 case
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            Does it beep if you remove the RAM? What about if you don't install a video card (assuming there is no on-board video)? If it doesn't beep, BIOS probably isn't even able to get to that point.
            If that's the case, start by checking if all of the voltages on the motherboard circuits good? You'll probably have:
            V_core (CPU voltage) - about 1.5 to 1.7V depending on CPU
            Vcc for Northbridge (sometimes combined with CPU voltage)
            AGP connector voltage - 3.3V, 1.5V, or 0.8V depending on what video card you have in it)
            RAM main voltage - 2.5 to 2.6 V for DDR
            RAM secondary voltage - I think 1.7 or 1.8V, I don't remember exactly
            and possibly a number of 1.7V, 1.8V, 3.3V, and 5V linear regulators.
            Let me know if you need help finding these. You'll need a multimeter to find them.
            • larrymoencurly
              • Oct 2004
              • 960
              Not even the CPU fan spins?
              • Dan81
                SNES-powered
                • Oct 2013
                • 1865
                • Romania
                It beeps only if no thermal paste is applied.
                It spins.
                The computer powers up,but I have no POST.All parts I use are good.
                Main rig:
                Gigabyte B75M-D3H
                16GB DDR3-1600
                Delux MG760 case
                • ant3202
                  • Jun 2006
                  • 275
                  • Singapore
                  hmm... does your mobo has has a d bracket from MSI ...
                  • Dan81
                    SNES-powered
                    • Oct 2013
                    • 1865
                    • Romania
                    Nope,from where I bought it they only had the board.
                    Main rig:
                    Gigabyte B75M-D3H
                    16GB DDR3-1600
                    Delux MG760 case
                      master hoarder
                      • May 2008
                      • 12175
                      • Bulgaria
                      Oh boy. I sure hope you didn't try this with all of your AMD CPUs. They won't throttle down when they overheat. If you did, they are likely all dead now.
                      The fact that the board beeps means that it might actually be posting or attempting to and stopping somewhere.
                      Check CPU voltage. A dead CPU could have killed something in the VRM.
                      • Dan81
                        SNES-powered
                        • Oct 2013
                        • 1865
                        • Romania
                        Don't worry because as soon as the board finds there's no thermal paste it cuts power(fans stop spinning,HDD stops spinning and DVD stops spinning)and it does one high beep and one low beep.
                        However,applying thermal paste makes the board just turn on and it sits on a blank screen,no matter what video card I use,if it's PCI(S3 Trio 64)or AGP (ATI Radeon 7000).
                        Tried all CPUs and none died so far after doing that,as the thermal protection kicks in.
                        Main rig:
                        Gigabyte B75M-D3H
                        16GB DDR3-1600
                        Delux MG760 case
                        • cheapie
                          null
                          • Jul 2010
                          • 849
                          If it has onboard video, it might be defaulting to that.
                          • pfrcom
                            Oldbie
                            • Jun 2006
                            • 1230
                            Could be that BIOS has been corrupted, especially considering MSI spruik their god-awful Live Update 5 on page for that board
                            Not beeping if thermal paste has been applied, but memory has been removed, is not a good sign
                            Consider getting a POST card, which might give some indication whether BIOS is doing anything - or get an MSI D-bracket like ANT3202 suggested, and see if its lights flash in some pattern
                            better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
                            • Dan81
                              SNES-powered
                              • Oct 2013
                              • 1865
                              • Romania
                              BIOS isn't corrupted,as the person I bought this board from didn't even know about BIOS flashing.
                              Also,I can't get a POST card or D-Bracket at all.
                              The board only beeps when no thermal paste is appplied.Otherwise,not even if I remove RAM it doesn't beep.Same for the video card.Both RAM and video card are good,as I used them on my Chaintech MPM800.
                              KT4AV doesn't have onboard video.
                              Main rig:
                              Gigabyte B75M-D3H
                              16GB DDR3-1600
                              Delux MG760 case
                              • pfrcom
                                Oldbie
                                • Jun 2006
                                • 1230
                                Did the seller demonstrate it working ? - if not, the problem is just speculation
                                MSI's overview page shows a so-called feature "Automatically Detect the BIOS/Driver/VGA/Utility Update"
                                How do you know vendor didn't OK some prompt, then decide to part out computer when it didn't work next time they turned it on ?
                                The way I see it ...
                                Board probably includes hardware to beep if overheating is detected - so you get beeping when no thermal paste is applied
                                If overheating is not detected, it transfers control to firmware, aka BIOS, to continue booting
                                If BIOS gets corrupted, it just hangs, doesn't even detect absence of RAM early in boot process, and beep to warn about it
                                ... if it was mine, I'd accuse the seller of selling me a faulty board, or just cut my losses and scrap it
                                I've lost an MSI board to their crappy Live Update process, where they don't even offer the option to download a specific BIOS image which can be updated by a firmware tool or good old reliable DOS flashing program
                                • Dan81
                                  SNES-powered
                                  • Oct 2013
                                  • 1865
                                  • Romania
                                  I got it at a fair for 10 bucks.
                                  Well,if I can't get it work at least it makes for a good K7VZA recap when I get around it.
                                  The K7VZA is another great board next to K7S5A but this one uses VIA chipset.Sadly it doesn't support Semprons.
                                  Main rig:
                                  Gigabyte B75M-D3H
                                  16GB DDR3-1600
                                  Delux MG760 case
                                  • ugamazing
                                    Procedural question about BGA rework and removal of CPUs
                                    by ugamazing
                                    I have been working to develop a consistent and reliable method/workflow for removing, re-balling, and replacing CPUs on various MacBook Pro models (2015-2020).
                                    I have done OK so far, but there's one detail I need to sort out. I'm hoping someone much more experienced than myself may be able to shed some light:
                                    I am noticing the pulled CPUs (to be re-balled) come off fine, and they "look" fine as well, immediately when I pull them. However, within a few minutes, after cooling, the CPU chips develop a very, very slight curve/bend. It's SO SLIGHT, maybe a 1-2%...
                                    07-12-2022, 03:11 PM
                                  • Nebukadnerzar_V
                                    Dell Optiplex 760 USFF BIOS Mod Request for QuadCore CPUs
                                    by Nebukadnerzar_V
                                    Hi guys!
                                    I have a Dell Optiplex 760 USFF (Ultra-Small Form-Factor).
                                    It currently only supports Dual-Core CPUs and will halt with an error message, when a QuadCore is installed.
                                    I have seen people running QuadCores in these machines, but the BIOS needs to be modded.
                                    Since I have not found the modded BIOS to download anywhere, I am asking you guys for help:
                                    Could you please add support for QuadCore CPUs (in my case the Core2Quad Q9550) to the BIOS?
                                    I have attached the Dump of my machine.
                                    S/N: SRW2K4J
                                    Reg Model: DCTR...
                                    09-27-2024, 02:43 AM
                                  • ducky29
                                    Working with Bga chips especially CPUS
                                    by ducky29
                                    Hello. I mostly do small electronics and tv repairs. I am confident with small bga chips but I never was successful with removing large chips especially cpus. Is it possible to remove them just using a preheater and hot air gun or I need something more advanced like a bga machine with temperature profiles, cooling fans, etc etc.
                                    Any suggestion on aliexpress/ebay are welcomed. I am on a tight budget, max I can do is about 200$. Please anyone with more experience can give me some suggestions?
                                    Thanks in advance.
                                    09-23-2024, 03:56 PM
                                  • Windows8RTMUser
                                    Repair knowledge for -55c CPU temperature on AMD Ryzen CPUs in bios, the AMD Sideband temperature sensor interface (SB-TSI)
                                    by Windows8RTMUser
                                    Recently I came across an x570 Aorus Elite where the temperature in bios was reporting -55c, i had checked the CPU_TEMP line connected to the IT8688
                                    In my particular case, the SIC line going to the X570 chipset (PM_SIC) was shorted to ground, so far disconnecting the 0 ohm resistors connecting APU_SID and APU_SIC to the chipset has fixed my -55c issue, it seems like -55c is the fallback reading for CPU_TEMP which is just pulled up to VREF on most gigabyte motherboards
                                    I wanted to post this as even the ever-reliable vlab forum was stumped on this issue
                                    tags:...
                                    07-28-2025, 07:26 PM
                                  • bigbeark
                                    Asus M2N-E uses AM3 CPUs?
                                    by bigbeark
                                    Accordng to the ASUS website, if you apply BIOS 5001 you can use Socket AM3 CPUs on the M2N-E motherboard.
                                    I have two of these boards that are working. The CPU support info on the ASUS site says you can use ATHLON II X2 CPUs, Athlons II X3, and even Athlon II X4 CPUs.
                                    These CPUs seem to be readily available at reasonable prices. There are some that consume as little as 45 watts.
                                    The notes say "Due to Bios ROM size limitation remove LAN PXE ROM and change Crashfree3 to Crashfree".
                                    I assume these are options in the BIOS setup you can...
                                    02-04-2020, 03:19 PM
