usb sharing hub
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    usb sharing hub
    a friend is asking whether he can share an adsl usb modem with two computers using a usb sharing hub. is this reliable? can they both use the modem at the same time?
    personally i would prefer to put a router but router + 2 network cards is too much money apparently
  • gonzo0815
    • Feb 2006
    • 1600
    Re: usb sharing hub
    OMG i fore shure would not even try to do this.
    Last USb ADSL modem is have had was a real pain in the ass, even without an sharing hub.
    In the end i trashed it and customer ordered a network modem.
    Even if the modem would work simultanousely (wich is IMHO not possible) both users would have to dial in, wich is usually not possible with most ISP.
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      Re: usb sharing hub
      hmm then i will probably suggest "internet connection sharing" service using a network between the two computers.
      • WNG
        • Sep 2006
        • 354
        Re: usb sharing hub
        I think the cheapest method is to get a 2nd NIC and use ICS with the computer using the USB modem.
        Speaking of ICS, does anyone know of a freeware alternative to Windblows XP ICS feature? It defaults to using 192.168.0.1 as the gateway, and that won't work with a router using it already.
        I need to be able to select the base IP address.
        TIA!
        “We the willing, led by the unknowing, are doing the impossible for the ungrateful.
        We have done so much, with so little, for so long, we are now qualified to do anything, with nothing.”
        • stretch0069
          Screwed Up Super Moderator
          • Oct 2003
          • 2662
          • oooo ess aaaaaaaaa
          Re: usb sharing hub
          Change the IP in the router. I'm almost certain I can change it in the three I have.
          "Its all about the boom....."
          Guns kill people like spoons made Rosie O'Donnell fat.
          We now return you to your regularly scheduled drinking.
          "Fear accompanies the possibility of death.....calm shepherds its certainty"
          Originally posted by Topcat
          AWD is just training wheels for RWD.
          • WNG
            • Sep 2006
            • 354
            Re: usb sharing hub
            I don't have access to the hw router table.
            • double_DD
              Why does my ISP router hate my "homemade" power supply??
              by double_DD
              It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
              So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
              For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,...
              07-12-2025, 03:09 AM
            • howardc64
              Samsung UN55JU650DF network/streaming problem
              by howardc64
              Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
              This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
              07-09-2025, 12:44 PM
            • BOSCHNJAK
              by BOSCHNJAK
              ABOUT ME INTRODUCTION FILE
              2
              024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
              2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
              2022 BEV, PROJECT ?
              2021 BEV, PROJECT ?
              2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
              2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
              12-28-2023, 02:09 PM
            • davg
              Home network connection problem
              by davg
              I just bought a new ThinkPad laptop and I need to connect it to my home network. I have several computers on my network and can see each other in File Explorer and the older ones can communicate with each other (even with the new one) but the ThinkPad can see the other computers but can't communicate with them. I get the (network error 0x80070035 The network path not found). I tried several scenarios that I found on line but none of them worked?? Since the other computers on the network can communicate fine I'm assuming the problem is with the setup of the ThinkPad? All computers are running Windows...
              03-06-2021, 07:13 AM
            • japlytic
              Maximum speed should be marked on network ports
              by japlytic
              I noted that a number of consumer entertainment devices have the maximum speed marked on the wired network port and considering that there are broadband plans faster than 100 Mbit, the wired network port can be a bottleneck since some routers do not have Gigabit (only 100 Mbit) support for the WAN port let alone the wired network ports.
              One other thing: Certain low cost network cables only have two pairs which limits speed to 100 Mbit.​
              12-19-2024, 05:04 PM
