Wresting with Deepfreeze and SurferQuest
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    So I have this Optiplex GX280 that is really giving me a hard time. It was, at one point, installed in one of those crappy ATM's you find in gas stations. They use a hodge podge of security software that really makes it difficult to use the computer for anything else.
    For one, they have deepfreeze on there. Ok, thats not that hard to disable, but then they have a custom program written by a company called SurferQuest that is the ATM interface you would interact with. The only problem is, when starting up normally the SQ software starts up instantly and locks down the computer, completely disabling any USB devices (I.E. keyboard and mouse). In dell's infinite wisdom, they did not equip the GX280 with PS/2 ports.
    So here's the problem. Its stuck in a loop. I can only make changes to deepfreeze in normal mode. I can boot into safemode and poke around, but deleting or uninstalling anything is useless as deepfreeze just puts it back to normal next boot. I can't make any changes to deepfreeze in normal mode as the stupid SurferQuest software locks everything out.
    And to top it off, they either have some sort of setting or software installed that prevents booting from anything other than the hard drive, or this computer is just as big of a POS as it really is, as the CD drive will not boot anything, and trying to boot from a USB drive just freezes up the computer.
  • cheapie
    null
    • Jul 2010
    • 849
    Re: Wresting with Deepfreeze and SurferQuest
    Pop the hard drive in a different computer and disable it from there?
    • 370forlife
      Large Marge
      • Aug 2008
      • 3112
      Normally that would be the case, but right now I lack a working computer with Sata capabilities (the WD 320GB in my main computer just took a dump.)
      • pfrcom
        Oldbie
        • Jun 2006
        • 1230
        That's usually done by the BIOS
        Is a password needed to get into BIOS settings ?
        If there is, and you don't have it, get hold of a manual for the system and find out how to clear CMOS settings
        Once you get into the BIOS, look for settings related to Boot sources
        better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
        • 370forlife
          Large Marge
          • Aug 2008
          • 3112
          There was no password on the bios, and I reset it as well. I also don't see any device inside the computer so I think its just a Dell being a Dell not being able to boot from USB. It must just be coincidental that the CD Rom also doesn't work.
          I'm going to try hooking up a different CD rom drive, it has a slimline style drive in it now. The power supply also does not have any Molex connectors, so I'm going to have to rig up another power supply for the time being. I thought I had another CD rom drive from a big ol' Dell server, but it was SCSI. I have drastically fewer parts than I had in the past, so doing these things now becomes more of a challenge .
          • RJARRRPCGP
            • Jul 2004
            • 6301
            IIRC, boards since the USB 2.0 era (since 2002, IIRC) should be able to boot from USB.
            ASRock B550 PG Velocita
            Ryzen 9 "Vermeer" 5900X
            Arc A770 16 GB
            eVGA Supernova G3 750W
            Alienware AW3423DWF OLED
            • pfrcom
              Oldbie
              • Jun 2006
              • 1230
              From GX280 user's guide: ftp://ftp.dell.com/Manuals/all-produ...uide_en-us.pdf
              Booting to a USB Device
              NOTE:
              To boot to a USB device, the device must be bootable. To ensure that your device is bootable, check the devicedocumentation.
              Memory Key
              1.
              Insert the memory key into a USB port and restart the computer.
              2.
              When
              F12 = Boot Menu
              appears in the upper-right corner of the screen, press <F12>.
              The BIOS detects the device and adds the USB device option to the boot menu.
              3.
              From the boot menu, select the number that appears next to the USB device.
              The computer boots to the USB device.
              • 370forlife
                Large Marge
                • Aug 2008
                • 3112
                I assume there must be some sort of stability issue with the bios and booting from USB. I formatted 3 different USB sticks I had sitting around, all three would be detected but would freeze the computer when selecting them to boot.
                • RJARRRPCGP
                  • Jul 2004
                  • 6301
                  May be a bad USB port.
                  Arc A770 16 GB
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    gx280 with stability issues?
                    look at the caps on the mobo and power supply first.
                    i have gotten plenty of quirky ones in that a recap fixed right up.none were bulging on the board but always at least 1 in power supply.
                    another possibility is an intentionally bugged bios since it was in an atm.
                    • 370forlife
                      Large Marge
                      • Aug 2008
                      • 3112
                      Well, I hooked up another IDE drive and a different power supply and it was able to boot from that CD and reinstall XP. Seems to be fine with the supplied power supply now. The motherboard itself is all Pannys, none bulging and the power supply is a little HiPro unit that doesn't have any visible bulging, but they're all Ltec with some little Nichicons, so I may go through and replace the Ltec's. The BIOS revision is A00 which indicates it is the original BIOS, so it may just need a BIOS update to get the USB booting properly.
                      Other than that its doing what I wanted it to do, which is to act as a wireless receiver/router for some old PPC Macs.
                      • Instafixx
                        Macbook A2179 820-01958
                        by Instafixx
                        Have a Macbook A2179 with liquid damage. Customer showed it some shop which has done an ultrasonic cleaning of the board.
                        The board pulls 0V but doesnt turn on. No Fan SPIN. NOT IN DFU.
                        I checked the Power Sequences below and found this -
                        Once a valid external power source (Charger or battery) is connected, the following rails will come online.
                        PPBUS_G3H: Normal voltage is ~12.6v on the charger with the battery disconnected. Produced from the ISL9240 (U7000, which uses PPDCIN_G3H as its VIN.
                        PP3v3_G3H_RTC: Normal voltage is ~3.3v. Produced...
                        05-20-2023, 05:19 AM
                      • privato89
                        Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                        by privato89
                        I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                        Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                        Let's begin:
                        Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                        03-26-2024, 06:37 AM
                      • eltano4i20
                        [HELP] SAMSUNG NP270E4E-K01AR
                        by eltano4i20
                        1) Error trying to enter the BIOS
                        --> [F2] won't let me enter the BIOS. To enter the BIOS, I had to create a shortcut and then type C:\Windows\System32\shutdown.exe /r /fw /t 1 in the destination. This forced it to restart and enter the BIOS.
                        Once inside, I went to the BOOT menu, but, surprise, it wasn't there. I got the following message:
                        BOOT PRIORITY ORDER (img-05)
                        1- Windows Boot Manager
                        2- SATA HDD
                        3- NETWORK
                        4- Debian
                        2) Error trying to access the BOOT MENU
                        --> I restarted the notebook and pressed [F10] but the BOOT...
                        07-04-2025, 12:39 AM
                      • Luke Anders
                        Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
                        by Luke Anders
                        A few details about the laptop itself:
                        Name: Lenovo Legion 5
                        Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
                        BIOS Version: GKCN60WW
                        EC Version: GKEC65WW
                        Serial Number: PF39AQ7Z
                        Board Model: NM-D562 Rev 3.0
                        RAM: 16GB Installed, DDR4 (brand new)
                        NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
                        I bought this laptop recently from eBay as a faulty device....
                        10-12-2024, 05:13 AM
                      • NolesFan
                        Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                        by NolesFan
                        Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                        10-24-2024, 06:36 PM
