USB to SATA 2.5 hack to use on Sata 3.5
  • domas
    News Hater
    • May 2013
    • 323
    • Denmark
    I have a usb controller from external 2.5" hard drive. It supplies +5V from usb port. Therefore it does not function on 3,5" SATA drive (missing 12V input).
    Typically 2,5" drives say +5V 0,7A on them
    Typically 3,5" drives say +5V 0,7A and +12V 0,55A on them
    Pins on the board of controller that are supposed to be +3.3V and +12V are not connected anywhere.
    What if i used the same controller and added a step up converter for 12V?
    Total load taken max values of hard drive and 100% efficiency of step up converter would be 0,7A + (12/5*0,55) = 2.02A @ 5V
    Would this work and would it cook the f.. out of my usb port? I have PowerShare ports on my laptop.
    I would use something like this:
    http://www.eleccircuit.com/lm2577-5v...age-regulator/
  • brethin
    • Dec 2008
    • 1907
    Re: USB to SATA 2.5 hack to use on Sata 3.5
    3.5 drives can run much higher than .7A +5v, .55A +12v. If I were looking to convert the 2.5 drive controller to support 3.5 drives I would want at least 1.5A +5V and 1.5A +12V, so just adding a step up converter for 12V would not do the trick as I am sure that controller would not support that kind of load. Without a outside power supply your USB port will not provide near enough power to do what you want.
    • ddscentral
      • Mar 2008
      • 151
      • Lithuania, EU
      USB only provides up to 0.5A at +5V.
      You could probably use a 2.5 converter (since it's just a USB to SATA bridge) but you would need to power the drive externally.
      3.5" drive requires an enclosure with it's own PSU to be used as external drive.
      • domas
        News Hater
        • May 2013
        • 323
        • Denmark
        I know that it normaly requires +12V ext supply. I am just trying to think of a less complex solution. My laptop has 2x usb 3.0, 1 USB 2.0 Powershare, and one eSata + powershare port. The last one should supply +12v, but it is a grey area as this standard was never standartized by any organization. Again, I would need a separate cable for that.
        500mA output is old standard, some people say that powershare has up to two amps, and usb 3.0 has more than 500mA.. Info is not confirmed though.
        What if i used two ports from my computer, one for 5V and data, another just for 12V?
        Will investigate. I have two 3.5 drives to test, and one 2.5 controller. The problem is that if i hook the HDD directly to ATX PS then the controller plug doesn't fit for data as the controllers plug is a single unit for data and power, if you understand me. Than i do have to use extension cable for data between controller and HDD, which i do not have, as normal sata cables are Female-Female and i need male-female for this purpose.
        Will continue to look for solutions
        • brethin
          • Dec 2008
          • 1907
          Its actually 400ma per port so it is possible to power it all via usb if the controller will handle the load and you don't mind using 4 usb ports all at the same time (1 for data and 3 for the extra power) for just for 1 drive. That's why you never see external 3.5 drives powered just from USB. Many 2.5 drives require 2 usb ports just for this reason.
          • domas
            News Hater
            • May 2013
            • 323
            • Denmark
            Also for powershare ports?
            Especially for eSATA+powershare port?
            • brethin
              • Dec 2008
              • 1907
              Before we go any further is the 2.5 usb controller sata or PATA (I assumed PATA). Because if you have eSata ports just connect the 2.5 drive to that and skip the 2.5 external controller.
              • domas
                News Hater
                • May 2013
                • 323
                • Denmark
                all of the drives i was talking about are sata.
                You need a special adapter cable for esata+powershare port to hdd anyway, i guess? But if that was a solution, would a combo esata/powershare port supply enough of 12V to 3,5 sata HDD?
                I will snap some pics when I am home later tonight
                • brethin
                  • Dec 2008
                  • 1907
                  I suggest you read this for starters.
                  http://en.wikipedia.org/wiki/ESATAp
                  Then ask your question again because it sounds like you want to connect 3.5 sata drives to a machine with eSatap ports but somehow a usb 2.5 external drive controller got tossed in the mix which is not needed to do this.
                  • domas
                    News Hater
                    • May 2013
                    • 323
                    • Denmark
                    Ok, this clears things up a bit. That actually simplifies everything. Damn I didn't know what eSATA was for.
                    But still I am using a laptop computer, and most of sources say that they do not supply +12V even though it is eSATA/powershare combo, they mostly do for desktops only. It is definitely worth acquiring the cable if i have 12V in that hole.
                    And yes of course, there is no info about if my computer has 12V on the internet. Anybody got schematic for dell xps 17 L702x? No idea about mobo code.
                    I might try to measure voltage with DMM. I can only do that after work later tonight, and i will try to do that without shortening usb pins
                    I have just taken a close look to my eSATAp.. No 12V pins
                    On the contrary, does eSATA mean that I can now hook a drive directly and access s.m.a.r.t information that I wasn't able to do before over usb controller?
                    • shadow
                      • Feb 2007
                      • 732
                      You should be able to see the SMART information if the drive is connected through eSATA.
                      • ddscentral
                        • Mar 2008
                        • 151
                        • Lithuania, EU
                        Most USB to SATA controllers do allow access to SMART. Only some oddball controllers don't.
                        • domas
                          News Hater
                          • May 2013
                          • 323
                          • Denmark
                          Well i couldn't with my crappy one. It used to be Packard Bell Ext. hdd with samsung or toshiba hdd inside, i couldn't identify who produced the controller itself though. I think this is a list of supported usb -> sata controllers: http://sourceforge.net/apps/trac/sma...ed_USB-Devices
                          Now I am looking for eSATAp to SATA cable with additional input of 12V. It seems that they are not on the market, so I have to buy just a normal cable an tear it aparat on day one. I hate to do so..
                          • domas
                            News Hater
                            • May 2013
                            • 323
                            • Denmark
                            yaaaaaaaay found it, spent more than a day for that )
                            http://www.dcscsi.com/product/200.html
                            Now I just need to get a source for it.
                            • domas
                              News Hater
                              • May 2013
                              • 323
                              • Denmark
                              seems like you can't get one in western world
                              • domas
                                News Hater
                                • May 2013
                                • 323
                                • Denmark
                                So I am still using my usb controller before i get my esata cable. Both of them will running of separate 12V P/S whenever 3.5 inch drive is hooked to it.
                                I have one question though. My chip OXU931S-MLCG http://www.plxtech.com/products/consumer/oxu931s on the controller is getting quite hot. not sure how much that is in degrees, i can keep my finger on it, but it is hot. Any ideas why? It is just the nature of the chip?
                                What about if I sinked it with a tiny heatsink? I do not have any ideas for mounting it though, i was thinking about some glue based heatsink marterial as i do not want to drill holes in the board.
                                I have my GF's laptop which is an ultrabook and does not have esata port so i will continue to use the controller solution. I use 2.5" 160GB drive for her backup and 3.5" 250GB drive for mine.
                                • joshnz
                                  • Feb 2011
                                  • 969
                                  • New Zealand
                                  I would say it is just a hot running chip you could stick on a small heat-sink if you want.
                                  My pc
                                  CPU : AMD PHENOM II x4 @ 3.5Ghz
                                  MB : ASUS M4A89TD PRO USB3
                                  RAM : Kingston ValueRAM 16gb DDR3
                                  PSU : Cooler Master 850W Silent Pro
                                  GPU : ATI Radeon HD 6850
                                  • DynaxSC
                                    GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
                                    by DynaxSC
                                    I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
                                    There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
                                    The board is generally working now, all PCIe ports are working, Windows installs normally.
                                    However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
                                    The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
                                    03-10-2025, 12:27 PM
                                  • questore
                                    Looking for a DC-DC step down converter module to replace a 0.75v_ALW output and enable pin
                                    by questore
                                    Hello Everyone,
                                    I need your help, maybe you have know where to buy a replacement.
                                    I have a NM-D562 laptop motherboard that has a burned 0.75_ALW converter. (the layers and the pins also burned so i dont want to restore it but i need a replacement)
                                    I have checked with lab power supply output (0.77V) laptop works, so i need a DC-DC module that can do its job.
                                    According to schematic datasheet what i need on 0.75V_ALW:
                                    Vout=0.75V±37.5mV
                                    Vset=0.752V±1.46%
                                    Vref=0.6V
                                    TDC=4A
                                    OCP=9.5A TYP=10.5A MAX
                                    OVP=(1.15~1.25)*Vout
                                    UVP=(0.6~0.7)*Vout​...
                                    11-10-2025, 03:36 AM
                                    MT3608 Step-Up Converter IC Datasheet
                                    The MT3608 is a constant frequency, 6-pin SOT23 current mode step-up converter intended for small, low power applications. The MT3608 switches at 1.2MHz and allows the use of tiny, low cost capacitors and inductors 2mm or less in height.
                                    Internal soft-start results in small inrush current and extends battery life.
                                    The MT3608 features automatic shifting to pulse frequency modulation mode at light loads. The MT3608 includes under-voltage lockout, current limiting, and thermal overload protection to prevent damage in the event of an output overload. The MT3608 is available...
                                    10-07-2024, 05:02 AM
                                  • YellowJacket
                                    Identifying a DC/DC step down converter
                                    by YellowJacket
                                    Hi folks.
                                    Any help with identifying this IC? Should be some DC/DC step down converter. 'ACF G45' ... I thought, it is Monolithic Power Systems ( based on this topic --> https://www.badcaps.net/forum/troubl...and-datasheets ), but can't find this marking there.​ Will be thankful for any hint. Thanks in advance....
                                    05-08-2024, 05:37 AM
                                  • DriversScrew
                                    Need help to identify SOT23-5 step-down converter to 3.3V marking E16q9
                                    by DriversScrew
                                    Hello everybody,
                                    I need to replace a shorted SOT23-5 step down converter in a consumer audio device marking E16q9. What I found out from the board layout and measurements:
                                    Vin: 5,0V
                                    Vout: 3,3V (connecting to all 3V3 inputs of a N32905U3DN)
                                    Pin1: ? (perhaps enable)
                                    Pin2: GND
                                    Pin3: Vout - connected to 3µ3 coil
                                    Pin4: Vin
                                    Pin5: Feedback, voltage divider, two resistors connect Vout-Pin5-GND, 680k+133k
                                    I searched many datasheets, but no one seemed to match according the surrounding components.
                                    Best similar parts I found were...
                                    12-21-2023, 07:06 AM
