Busted Win7
  • Junk Parts
    Court Jester
    • Jun 2006
    • 8953
    Busted Win7
    Well I trashed the Win7 OS on my HP. At least I think that I did. Here is what I did to it. I have this DVD of the PET scan that I had done. I was trying to copy that disc. I couldn't copy this disc at all but I could view the content on the disc. Now my Nero, DVDFab8 and my media player are dead in the water. The disc does have and exe file that has to be run before before the PET scan can be viewed. I can't find anything installed on my system that relates to this exe file now. I uninstalled the Nero, and DVDFab8. Next I did a sytem restore to a date before I tried to copy the PET scan disc. During the restore the OS found and reinstalled the Nero, and the DVDFab8. The system does see the E drive but it still can't see a Movie DVD or copy anything at all. I did another uninstall and clean reinstall of Nero and DVDFab8. This still didn't get anything to work again. The only disc the system can see is that PET scan disc. I have about 800 megs of family photo's stored on the PC that I need to save before I can do a full factory restore from D:restore. My wife has the very same PC as mine so I set hers up to do the DVD copy work for now. I still need to fix my beloved toy PC!
    "It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
    Mark Twain
    "I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way."
    John Paul Jones
    There is a fifth dimension, beyond that which is known to man. It is a dimension as vast as space and as timeless as infinity. It is the middle ground between light and shadow, between science and superstition, and it lies between the pit of man's fears and the summit of his knowledge. This is the dimension of imagination. It is an area which we call the Twilight Zone.
    Rod Serling
  • Sparkey55
    • Jan 2010
    • 1523
    Re: Busted Win7
    JP, I do not know much about Win 7 but the problem could be that the exe file on the disc is a proprietory software that installs a driver in order to view the other files on the disc. Can you show us the name of the exe file?
    • Sparkey55
      • Jan 2010
      • 1523
      Re: Busted Win7
      You might have to restart the computer in safe mode and then look for hidden devices in the registry in order to gain access to the driver. The driver could be loading on start up of Windows 32bit drivers. If 7 is like xp then make shure you have full admin rights when you attemt this.
      • Junk Parts
        Court Jester
        • Jun 2006
        • 8953
        Re: Busted Win7
        I just saved a few pics on my cameras memory card. I'm going to do the factory software restore now with a "format c:. I'm running out of hair to pull out over this one.
        Mark Twain
        John Paul Jones
        Rod Serling
        • Sparkey55
          • Jan 2010
          • 1523
          Re: Busted Win7
          Do not auto-run that disc that has the pics on your pc again or you might be doing this all over the next time. Please let me know what the exe file is named; do not let your optical drive auto-run on the disc, turn off auto-run. The reason I ask is because once you know what the drive needs to see the pics you might be able to find a viewer for it. Good luck.
          • Sparkey55
            • Jan 2010
            • 1523
            Re: Busted Win7
            This issue sort of reminds me of StarForce drivers thou they were a real pain to get rid of even with the removal tool that the creators relunctantly released.
            • Junk Parts
              Court Jester
              • Jun 2006
              • 8953
              Re: Busted Win7
              I'll find out what that exe file is by asking the Tech at the hospital. It might take a few days but I'll get you that answer. That CD isn't getting anywhere near my CD drive ever again.
              Mark Twain
              John Paul Jones
              Rod Serling
              • Time2Retire
                • Aug 2012
                • 256
                Re: Busted Win7
                Some exe files are actually compressed files. Others can be full of "cab" files.
                Both can be opened on Linux, so that you can view and/or copy the files contained within, using gzip and cabextract.
                I know, you don't use Linux.
                • Junk Parts
                  Court Jester
                  • Jun 2006
                  • 8953
                  Re: Busted Win7
                  I figured it out. My DVD/CD Burner is dead. It now reads nothing. Linux? No I don't use that drug.
                  Mark Twain
                  John Paul Jones
                  Rod Serling
                  • RJARRRPCGP
                    • Jul 2004
                    • 6304
                    Re: Busted Win7
                    Originally posted by junk parts
                    Linux? No i don't use that drug.
                    lol wtf!
                    ASRock B550 PG Velocita
                    Ryzen 9 "Vermeer" 5900X
                    Arc A770 16 GB
                    eVGA Supernova G3 750W
                    Alienware AW3423DWF OLED
                    • Sparkey55
                      • Jan 2010
                      • 1523
                      Re: Busted Win7
                      Unrelated maybe, but some StarForce Drivers were known for killing optical drives.
                      • Heihachi_73
                        • 713
                        Re: Busted Win7
                        Some EXE files are straight-out malware, and "drivers" designed to unlock files on a standard disc format like DVD UDF fits that category perfectly. All the more reason to disable autorun on Windows.
                        • Mrx3750
                          • Jul 2013
                          • 311
                          Re: Busted Win7
                          Oh yeah, I always disable autorun on Windows.
                          • Junk Parts
                            Court Jester
                            • Jun 2006
                            • 8953
                            Re: Busted Win7
                            OK Best Buy has a Hp DVD Burner at and ok price. I'm getting one after I see my Doctor today. I have a question about my old drive. Who made it? In "system" it shows up as something like "HP DVD A DH16ABLH SATA.
                            Mark Twain
                            John Paul Jones
                            Rod Serling
                            • Junk Parts
                              Court Jester
                              • Jun 2006
                              • 8953
                              Re: Busted Win7
                              My system is all fixed now. I replaced the bad drive with and Hp dvd1260i. Everything is working as it should.
                              Mark Twain
                              John Paul Jones
                              Rod Serling
                              • Time2Retire
                                • Aug 2012
                                • 256
                                Re: Busted Win7
                                Drug? It is a tool to get things done.
                                But, you don't seem to mind being one of the drugged sheep that follow Windows along aimlessly. Go figure.
                                • Junk Parts
                                  Court Jester
                                  • Jun 2006
                                  • 8953
                                  Re: Busted Win7
                                  Windows 7 does everything I need it to do. Why would I need Linux on my desktop pc anyway. I use the internet and I burn DVD's. Drugged sheep? Thanks for the laugh. You must feel like a real Rebel with all your Linux usage.
                                  Mark Twain
                                  John Paul Jones
                                  Rod Serling
                                  • goontron
                                    5000!
                                    • Dec 2011
                                    • 4108
                                    • US
                                    Re: Busted Win7
                                    ^ when you run servers you will understand. 12 linux and 4 BSD servers so far.
                                    Follow the white rabbit.
                                    • Junk Parts
                                      Court Jester
                                      • Jun 2006
                                      • 8953
                                      Re: Busted Win7
                                      The fact is that I do understand, and I'm not running servers. Its one simple Desk Top pc. Linux has no place and no use here on my system at all.
                                      Mark Twain
                                      John Paul Jones
                                      Rod Serling
                                      • Time2Retire
                                        • Aug 2012
                                        • 256
                                        Re: Busted Win7
                                        You asked for help with a problem, one that could (and may still be) a Windows malware problem. I gave you a very safe and secure method to open your files, and you replied with an insult.
                                        The fact still remains, Windows is an insecure operating system. The fact I choose an operating system that is one of the most secure (Linux) does not make feel like a rebel.
                                        The malware you may have introduced into your system may only infect older hardware. It has to be more than a coincidence that your drive died when you tried to run a program from it.
                                        I won't offer you any help in the future.
                                        • Junior††
                                          PS5 Disc Not Supported/ Disc Not Recognized Board Num: EDM-020
                                          by Junior††
                                          Good Afternoon fellas,
                                          Issue:
                                          Disc is showing as not supported when a disc is put in.
                                          Here's what I've done, you can skip this if you just wanna know the question:
                                          - replaced with a disc drive from a donor ps5 (honestly questionable if this is known to work)
                                          - reflowed the disc drive connector
                                          -reflowed the chip in question (shown on image)
                                          - I will say this console was very dusty so it's conceivable that it got so hot that it made the chip joints cold and potentially other things on the board
                                          Question:
                                          I...
                                          02-19-2025, 12:48 PM
                                          LG GRAM NOTEBOOK NERO 16.0 I7 Notebook Specification for Upgrade or Repair
                                          This specification for the LG GRAM NOTEBOOK NERO 16.0 I7 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GRAM NOTEBOOK NERO 16.0 I7 boardview and GRAM NOTEBOOK NERO 16.0 I7 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 04:10 AM
                                          LG GRAM NOTEBOOK NERO 16.0 I5 Notebook Specification for Upgrade or Repair
                                          This specification for the LG GRAM NOTEBOOK NERO 16.0 I5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GRAM NOTEBOOK NERO 16.0 I5 boardview and GRAM NOTEBOOK NERO 16.0 I5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          LG GRAM NOTEBOOK NERO 17.0 I7 Notebook Specification for Upgrade or Repair
                                          This specification for the LG GRAM NOTEBOOK NERO 17.0 I7 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GRAM NOTEBOOK NERO 17.0 I7 boardview and GRAM NOTEBOOK NERO 17.0 I7 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          Copy DMI info easily with Hex editing software and Macro script
                                          by SMDFlea
                                          Copying DMI information from an old bios to a new one is difficult for some members, often they have no experience with a hex editor,or some that have tried find it too hard.There is an option to make things easier for those members so that they don`t need to post their own bios backup for the DMI copying.
                                          Experienced bios modding members can help by posting in other threads the DMI offsets,macro script generated by the software and a download link to the software at softpedia mentioned in this guide,or post your macros in the comments here with a link to the bios request thread ....
                                          02-28-2023, 02:14 PM
