Dell Poweredge 2400
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Dell Poweredge 2400
    So my local college has a surplus sale about 3 times a month for half the year. Today, I went there during my lunch break and poked around at the old computer stuff. I was really hoping to score a nice 486 system to install Windows 3.11 on, but all there was were gutted P4 Optiplex's and powermac G3 's.
    Shame. But I continued to poke around a bit more and found this beast. They have a no-opening policy to prevent people from pocketing ram when no ones looking, so I just picked it up, yup, fells heavy, both power supplies are there, and for $10 I could get that back in the amount of scrap metal in the thing. Get it home and apart. Its got a SL4BS P3 1GHz in it, 512MB of ECC Registered PC133, a couple of network cards, and a SCSI controller. No hard drives though, and missing the caddys to hold them. So I was thinking of a few things to do with it -
    Get some caddys online (they seem to go for about $6 a piece) and use it as a fileserver
    or
    I have a MB/CPU/RAM combo from a different poweredge server that I believe will transplant in. The motherboard has the same funky formfactor, but this board has two 1GHz Xeon P3's with 2GB of ram. May require some creative-ness to get the power supplies to work though.
    or
    Casemod it for ATX and use it as a computer case.
  • Elysarian
    • Mar 2013
    • 200
    Re: Dell Poweredge 2400
    You could add another PIII into the existing server as far as I can tell - specs I've found say it supports a pair, you likely will need a second VRM module though (every Dell I've worked on has them as plug in modules)
    Max ram on the 2400 is 2GB (PC133 ECC)
    I have a 2600 (dual S604 Xeons) as a fileserver here and I'm looking to fill the 4 spare bays in it when time and money allows - I have some 80-pin SCSI drives but they're full height so won't physically fit in the hotswap bays.
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      Hey just so you know, I have four 1GB sticks of REG ECC PC133 sticks, and some Tualatin-S P3's (1.4GHz) if you are interested I haven't touched them in years. And you should add pics
      • Logistics
        • Apr 2007
        • 721
        Is anyone actually familiar with the supported CPU's on these boards? I have one that has a 550 in it, I believe--haven't touched it, yet. But I read others trying to put in a single 933 and having no luck making it come up. Some info says it will only run 133MHz FSB if the CPU is a 256k L2 cache, while 512k will only run at 100MHz. Regardless, can this thing push dual 1GHz? (I'm not really interested in going through the hassle of doing converters to run dual Tualatins, even if it's possible in this case.)
        • TELVM
          • Oct 2012
          • 547
          • Spain
          Originally posted by Logistics
          ... Some info says it will only run 133MHz FSB if the CPU is a 256k L2 cache, while 512k will only run at 100MHz ...
          Microprocessor type: one or two Intel Pentium III microprocessors with an internal operating frequency of at least 500 MHz and an external operating frequency of 100 or 133 MHz
          Internal cache: 32-KB L1 cache; 256- or 512-KB L2 cache (512 KB L2 cache only in 100 MHz FSB processors)
          http://capita.wustl.edu/CAPITA/Peopl...nual/intro.htm
          ^ That means PIII Katmai (512KB L2) or PIII Coppermine (256KB L2), which were made up to 1.0GHz for Slot-1. Any of these should run OK after a BIOS update.
          To run Coppermines above 1.0GHz (s370) a decent slotket would be needed, and to run Tualatins extra tinkering with CPU pins and slotket connectors.
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            I have four slokets sitting on a shelf, new in box (opened a couple to inspect). Three are MSI, one is ASUS. If you want some to use/mod, let me know, they were freebies that ever since my AMI meagaDUAL took a dump I never had a use for.
            sigpic
            (Insert witty quote here)
            • TELVM
              • Oct 2012
              • 547
              • Spain
              The best, bug-free slotkets are those which have a TVC15222 or TVC16222 voltage clamp chip.
              • Logistics
                • Apr 2007
                • 721
                Add polymers and that should probably be about /slotket, if you know what I mean.
                • Bowline
                  by Bowline
                  06-11-2025, 10:13 AM
                • maximus-bullitt
                  Request: Dell PowerEdge R340 iDRAC9 SPI dump (Winbond 25Q032)
                  by maximus-bullitt
                  I’m working on a Dell PowerEdge R340 (Service Tag: JTMLKB2).
                  The iDRAC is bricked — system hangs at “iDRAC initializing,” fans at 100%, and no VGA output.
                  The cause is a bad firmware flash to the iDRAC SPI.
                  Board details:
                  - Model: Dell PowerEdge R340 (14G)
                  - iDRAC version: iDRAC9
                  - Flash chip: Winbond 25Q032 (32 Mbit / 4 MB)
                  - Tool used: CH341A programmer
                  What I need:
                  - A clean, working 4 MB `.bin` dump of the 25Q032 from another R340...
                  09-28-2025, 04:22 PM
                • andrew25
                  Dell PowerEdge R740 bios
                  by andrew25
                  i have 4 Dell PowerEdge R740 servers, they all have same problem of no display on monitors. they all power up and running okay but nothing displaying on monitor, am suspecting server attack... i attached 1 bios dump and an update exe from dell website, if anybody can rebuild new bios i will really appreciate..
                  mobo ID: F6MXH
                  Service Tag: CSPF903...
                  02-07-2024, 12:53 AM
                • Akhlz001
                  by Akhlz001
                  09-20-2025, 07:15 PM
                • master3112
                  by master3112
                  07-29-2025, 01:55 PM
