Pentium's Server
  • pentium
    • Mar 2006
    • 2778
    Re: Pentium's Server
    That can be done.
    I omitted the parts that will be taken out of use.
    Those being everything IDE related (the new board has no IDE), the motherboard obviously, and the video card which is built-in on the new board.
    Find Nedry!
    Check the Vending machines!!
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16958
      <-- is a windows brat. Windows can be just as fast as *nix if configured right. Win2k on a machine sub-300MHz would tend to get a little choppy, as would linux for that matter. lack of horsepower will kill ANY operating system. The biggest thing you need to watch for on a win server is security, windows just has too many security breeches, so make sure you keep it updated and firewalled (especially if it has a live IP). Apache for win32+win2k Pro = very nice web server without IIS, and of course apache's VHOST support if you run multiple sites off one IP. Typing commands died for me with DOS, I don't want to do it anymore. Console admin on windows isnt hard either if you really want to type commands, but I found that remote desktop is a very nice thing. Both Win and *nix have their strong points and weaknesses, it really comes down to what's the most versatile solution for your partiicular scenario, and what OS you're most comfortable with.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • pentium
        • Mar 2006
        • 2778
        Exactly!
        I have had xp run pretty well on a 233, and it only had 64 mb ram.
        I'm fine with dos, *nix command line is still scary for me.
        In my case, Windows.
        Find Nedry!
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          i agree regarding console commands. i have always wondered if linux admins go around with little notebooks. i certainly have forgotten the command by the time i next need to use it.
          i have a new book called "linux phrasebook" its a highly recommended little reference for the bash shell.
          • Tom41
            • Oct 2005
            • 336
            • England
            My Compaq Proliant server has been happily running Debian Linux since I got it. It has capability for up to 4 CPUs, but at the moment it only has a single Pentium Pro CPU in it - along with 256MB of RAM. I don't have the XWindow system installed, or indeed any GUI; I can administrate it fine from the console.
            The 200MHz CPU performs very well for web serving, and the low speed is only noticeable when doing something CPU-intensive... such as running an SQL Delete query on a huge database while people are trying to browse the documents on the web server
            You know there's something wrong when you open your PC and it has vented Rubycons...
            • pentium
              • Mar 2006
              • 2778
              Linux does have the option of being installed without the GUI but then you are immediately subject to ommand hell.
              I know those linux phrasebooks. For about $50 I can get the Unix version. It'a about three times as thick and a bible to some.
              Find Nedry!
              • willawake
                Super Modulator
                • Nov 2003
                • 8457
                • Greece
                #27
                not if you know the command to install webmin
                • Topcat
                  The Boss Stooge
                  • Oct 2003
                  • 16958
                  Webmin is the Godsent for Linux IMO.... I have a mix of Windows and *nix servers. Another useful one if your server is a web server running multiple sites is ISP config. It's a lot like Cpanel, except its free.
                  Team : 49813
                  Join in!!
                  Team Stats
                  • willawake
                    Super Modulator
                    • Nov 2003
                    • 8457
                    • Greece
                    #29
                    good info. these control panels are a godsend for webhosting. i have always used cpanel and once you use it in its full whm capability (actually its pretty goddamn daunting in the beginning) but it makes a task that would be incredibly difficult otherwise to be just a few clicks.
                    still webmin and cpanel still need some more work to make it more user friendly but they supply a not so steep learning curve for those who want to get into linux. lots of linux apps have hosted config pages, like cups (print server) for instance. if you have compatible printer its just a few clicks to get a print server running then some small config in samba
                    • pentium
                      • Mar 2006
                      • 2778
                      Sutpid Notches!
                      Out of my entire 1 KG bag of Dimm's, not one fits the board!
                      By the looks of the notches (and the key I have for memory), I need 5V Buffered memory. I only have 3.3V unbuffered memory.
                      On the plus side, it fits the case I had for it...just barely, and my VRM modules fit too (no suprise there).
                      EDIT: Here is the type it really needs.
                      Shoot, my powermac uses the same stuff!
                      Find Nedry!
                      • Per Hansson
                        • Jul 2005
                        • 5895
                        • Sweden
                        #31
                        I might have some memory, if you're interested I'll look ;-)
                        • Rainbow
                          • Aug 2005
                          • 1375
                          #32
                          Looks like DIMMs in my Sun Ultra 5...
                          • pentium
                            • Mar 2006
                            • 2778
                            Sometimes a server can be like a house with a shady past.
                            It may look good but it has lots of problems.
                            I was putting the cover on when I noticed that I couldn't make the cover fit.
                            Yes, the board is too big.
                            for the salke of safety, I googled up the board and came to several conclusions:
                            -the board and case are brand specific (it's not an AT or ATX form factor)
                            -The case is HUGE! (see pics)
                            -Finding support for the system is going to be real hard with a lack of info I can find
                            -This is a server that is right up there in quality. It took two years to design from scratch and can be compared to Alpha Servers of the same age.
                            I think I bit a little too much off this time.
                            To show what the origional case was, I managed to find these small images posted by a foriegn Computer store:
                            Thanks for the ram offerings but I might have some floating around here.
                            I'm gonna need more coffee.......
                            Find Nedry!
                            • Spacedye69
                              • Nov 2005
                              • 698
                              • US
                              #34
                              not as weird as the case on my IBM PS/2 80!!
                              LOOK!!!
                              • pentium
                                • Mar 2006
                                • 2778
                                I actually saw one of those earlier this year at a local second hand store. I wish I bought it.
                                Transistors: 275,000
                                Is it really necessary to post how many transistors the CPU has?
                                Find Nedry!
                                • pentium
                                  • Mar 2006
                                  • 2778
                                  Okay, thanks guys for the help (and pointers).
                                  It looks like I am going to have to find a case first before I even start going into software. I sure hope I can find one.
                                  Find Nedry!
                                  • dood
                                    Deputy dood
                                    • Mar 2004
                                    • 2462
                                    BTW- For the longest time I was running Win2k Server on a P133 w/ 128mb RAM. I think Pentiums server should be just fine for 2k serv.
                                    Of course, all I did w/ my server was backups, a distributed.net pproxy, and DHCP. I never got into the whole active directory thing, since it was at home and there were only two users at the time
                                    Ludicrous gibs!
                                    • Per Hansson
                                      • Jul 2005
                                      • 5895
                                      • Sweden
                                      #38
                                      Hehe, that is what I am running Win2K server on right now ;-)
                                      It works pretty well as a WINS and caching DNS server... I also had it to monitor my big ass UPS but now the batteries in it are done and I haven't bought new ones yet...
                                      • Spacedye69
                                        • Nov 2005
                                        • 698
                                        • US
                                        #39
                                        I can't compete with you rich guys. I am running NT 4.0 Server.
                                        • pentium
                                          • Mar 2006
                                          • 2778
                                          Me?....Rich?
                                          I'm just lucky I can find this stuff at good prices.
                                          Find Nedry!
